rayar3 Samba Member
Posted: Mon Aug 27, 2012 6:35 pm Post subject: 1973 air cleaner |
I have a 73 Beetle autostick (std, not SB). It has a generator but has the paper air filter. Date on the filter housing says 8/73. Anyone know if it should be there or it should be an oil bath? Any reason for me to stick with this one or change back to an oil bath type?
And yes, I know there are missing vac hoses. Beetle was in storage since the early 90's. It's a work in progress!
bluedirtbeetle Samba Member
Joined: January 30, 2012 Posts: 121 Location: Tierra Azul, NM
Posted: Mon Aug 27, 2012 6:39 pm Post subject: |
The Bentley manual actually recommends the replacement of the oil bath with the paper element for ease of maintenance. I'd leave it... _________________ 1973 Standard Beetle All stock
1969 Standard Beetle All ??
Do not fear mistakes. You will know failure. Continue to reach out.
- Benjamin Franklin |
docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Mon Aug 27, 2012 6:47 pm Post subject: |
Keep it and hook all the vac hoses up correctly!
_________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
rayar3 Samba Member
Posted: Mon Aug 27, 2012 7:08 pm Post subject: |
Thanks for that picture! My pic was old. I hooked up all the lines today and it started without any argument. Tune up tomorrow. I got lucky because the fuel tank was clean and non of the lines on the car were dry rotted. Either way I've got all new soft lines for it anyway and I'm going to relocate the fuel filter out of the fire zone. |
IHC Samba Member
Joined: April 30, 2012 Posts: 204 Location: Washington state
Posted: Mon Aug 27, 2012 8:50 pm Post subject: |
I was at the Port of Vancouver Washington VW terminal, which recieved all VWs for the Riviera distributorship (Oregon /Washington / Idaho and?), in September 1972 and saw the first load of curved windshield Supers. I checked several of them and they all had generators and oil bath aircleaners .At that time I also worked a block away from a VW dealer and dont recall seeing a alternator /paper airfilter Bug until later in the 73 model year. |
Posted: Mon Aug 27, 2012 9:27 pm Post subject: |
Check the vin# build sticker on the drivers door post...see when your car was built... _________________ Doc
buzz93 Samba Member
Joined: October 04, 2011 Posts: 10 Location: South Florida
Posted: Tue Aug 28, 2012 10:38 am Post subject: |
I have a '73 standard that I have had since it was new. It has an oil bath cleaner, but if I remember correctly VW changed to paper sometime in mid '73 |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
GatorJZ Samba Member
Posted: Tue Aug 28, 2012 4:02 pm Post subject: |
19super73 wrote: |
There are those that will say the oil bath is better and they prefer it. |
Urban legend and a very limited one at that (mainly here). _________________ 1973 Sports Bug (Super) |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
Posted: Tue Aug 28, 2012 4:10 pm Post subject: |
I had a '73 bug with paper air cleaner and alternator, it was a late model year build. Early builds may have had paper with generator. Then again, I see a cut off EGR valve ('74 model year) next to the generator so who knows what's been messed with.
What's the build date on yours? _________________ Mike
Sold my sedan
Parts... |
rayar3 Samba Member
Posted: Tue Aug 28, 2012 7:22 pm Post subject: |
Okay the first 6 of the vin is 113229 meaning it was built sometime between Oct 4-31, 1972. The air cleaner top has an 8-73 molded into it. I assumed that was the manufacture date? Maybe a dealer ad-on? The car was also hit at some time early on because there's a fuel injected rear apron that was replaced very well. I do not know if the engine lid was changed. It doesn't have any drill holes for the VW logo in it either.
The EGR also stumps me a little. I've been looking at a lot of 1973 pictures but none of them have a male end so close to the valve. Most have a long tube attached to the EGR and it connects to the bottom. I thought that maybe the PO modified or cut the tube, but it looks factory since there's a threaded end on it. Could it be something that he modified to pass an inspection and then removed? I don't know.
I'm trying to decide whether or not to reconnect the EGR system. I don't really care about the emissions aspect of it, but will the car run better with the system operational?
My goal is reliability because this car is for my mom and for the rest of the family to enjoy. I don't want a 100 point car. Just something that looks factory that I can bring to the local shows.
But for now the car runs and I'm in the middle of trouble shooting the generator light that stays on. One thing at a time... |
Superbug Scott Samba Member
Posted: Wed Aug 29, 2012 10:08 am Post subject: |
FYI, my early build 73 had paper with generator |
idono Samba Member
Posted: Wed Aug 29, 2012 11:25 am Post subject: |
docdanracy wrote: |
I'm putting mine back together now with the same air cleaner. It's never had the hoses hooked to it. I see one on the front goes to the diaphragm thing on the intake but where does the other go? what does it do? how important is this? |
