zimad Samba Member
Joined: August 24, 2010 Posts: 94 Location: New Zealand
Posted: Thu Jun 13, 2013 4:51 am Post subject: Brake lines and master cylinder |
Working on the brake lines the the moment. Picked all new metal lines made to length off my old ones and also new flexible lines, so going to get these bent to shape and installed soon.
Dug out the original type 3 dual master cylinder, will need a little restro job done on it - think I will take it into the local brake specialist for re sleaving and all the rubber parts to be replaced.
_________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
zimad Samba Member
Posted: Sun Jun 16, 2013 5:05 am Post subject: |
Little bit if fun time in the garage tonight-
Had these new metal lines, made up off measurements i took off the old ones, (some of them were a little long as a measured with a little extra but all worked out ok) and flexible lines
Rear lines install, original 'T' junction cleaned up ok.
Front lines installed, master cylinder still needs to be reconditioned, just being used to mock up lines. After standing back and reviewing I have realised that the two right hand lines need to be re shaped and swapped over so that both the front lines are coming off the same circuit. I hate it when that happens, all part of learning I suppose. Should look a little neater as well, as I was wondering why, one line seems too long and the other too short.
Oh and another couple of pictures just because.
Pedal assembly in.
57 RHD Type 21 |
zimad Samba Member
zimad Samba Member
68notch Samba Member
Joined: August 16, 2007 Posts: 544 Location: Perth, Western Australia.
zimad Samba Member
Posted: Mon Jul 29, 2013 2:10 pm Post subject: |
68notch wrote: |
Nice job.
I am curious which supplier you got the 4 stud cosmic wheels from? It seems most suppliers only have the 5 stud (Porsche) pattern. |
Cosmics are original, brought them second had in average condition and reconditioned they, empi now do a repro 4 stud version which I am going to get one of as a spare wheel. _________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
Posted: Mon Jul 29, 2013 5:29 pm Post subject: |
zimad wrote: |
68notch wrote: |
Nice job.
Cosmics are original, brought them second had in average condition and reconditioned they, empi now do a repro 4 stud version which I am going to get one of as a spare wheel. |
Where do you plan to get the new spare from? I knew the 4 stud is available but I am yet to find a supplier that sells them?? _________________ John
68 Aussie notch
2011 Citroen Berlingo
https://www.facebook.com/Fastacraft
RHD dash pad project http://www.thesamba.com/vw/forum/viewtopic.php?t=475227 |
zimad Samba Member
Posted: Tue Jul 30, 2013 1:43 am Post subject: |
68notch wrote: |
zimad wrote: |
68notch wrote: |
Nice job.
Where do you plan to get the new spare from? I knew the 4 stud is available but I am yet to find a supplier that sells them?? |
My local air cooled VW guy "The Metric Nut ltd" _________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
zimad Samba Member
Posted: Tue Aug 13, 2013 4:27 am Post subject: |
inside faces of all panels underway with colour.
Masking up the body to paint the roof out first less area to back mask for when the body is painted .
One of the whole shell
Roof colour is standard l41 vw black
4 bolt on panels (2 front guards, deck lid and one rear guard)fully painted this afternoon, and being baked over night.
4 more to be done tomorrow night (one rear guard, doors and the bonnet) then comes the shell. _________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
zimad Samba Member
Posted: Sat Aug 17, 2013 3:07 am Post subject: |
Well here are the plans for the new engine.
1956cc engine
Specs as follows:
New alloy Super case
76mm crank.
90.5 Piston / Cylinders
E110 cam
H beam rods
8 doweled flywheel
Clutch, flywheel, crank, rods and type 3 fan all balanced.
CB Heads 044 CBC ported ultra mag plus
Cb low profile manifolds welded and matched to heads
DUAL 40HPMX CARBs
Push Rod Tubes - Original JayCee (Black)
External oil filter / cooler
Will be trying to run this setup for ignition if enough room.
Pertronix Plug 'N Play Billet Distributor Ignitor II Type 1, Black (including leads and coil to match) _________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Sat Aug 17, 2013 7:41 am Post subject: |
Looks good, and the colors compliment each other. I'm just not sold on the louvers in the front fenders though.
It's really interesting looking at how OZ did their cars, versus how Germany did theirs. On USA spec 69's, we would get IRS, but ya'll still got the swing axle, which was discontinued after 69 for the USA. But then, after looking at Bert's car, you can see differences that the "home market" got, versus the export models. These kind of builds really cause 1 to pause and study. Great job. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Sat Aug 17, 2013 6:01 pm Post subject: |
he can tuck some radiators in there and convert to suby.
should work in theory as there is positive pressure inside wheel wells. |
vlad01 Samba Member
Posted: Sat Aug 17, 2013 6:02 pm Post subject: |
Bobnotch wrote: |
It's really interesting looking at how OZ did their cars, versus how Germany did theirs. On USA spec 69's, we would get IRS, but ya'll still got the swing axle, which was discontinued after 69 for the USA. But then, after looking at Bert's car, you can see differences that the "home market" got, versus the export models. These kind of builds really cause 1 to pause and study. Great job. |
in Oz 69 got IRS. NZ might be different. |
zimad Samba Member
Posted: Sat Aug 17, 2013 8:12 pm Post subject: |
vlad01 wrote: |
Bobnotch wrote: |
The notch is of Oz origin and was imported into nz in 1976, it is registered as a 69, but chassis number indicates 68.
It has the 4 stud wheels, 12volt and disc brakes up front, but yes it still has swing axle rear and the early bumper, older 'bullet' shaped front indicators and it had the fuel filler as the very early edition with no interior release, manually opened with a finger pull. But this has now been been converted back to early under the bonnet style.
All these odd items make it tricky when ordering parts, but one just has to take ones time. _________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
zimad Samba Member
Posted: Sat Aug 17, 2013 8:14 pm Post subject: |
Remainder of the bolt on panels now painted, brother got them outside in the daylight before it rained again.
Am pretty happy with how the colour is looking!!
57 RHD Type 21 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Aug 18, 2013 11:48 am Post subject: |
Acrylic Lacquer will spray smooth & shiny! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
zimad Samba Member
Posted: Sun Aug 18, 2013 1:27 pm Post subject: |
68notch wrote: |
That paint finish looks exceptional, really flat (no peel) off the gun.
Curious what tyre sizes you are running there?? |
I have 165 65 up front with 195 65 on the rear. _________________ 69 RHD Type 3 Notch Build Thread :http://www.thesamba.com/vw/forum/viewtopic.php?t=525890&highlight=
57 RHD Type 21 |
vlad01 Samba Member
Posted: Sun Aug 18, 2013 5:19 pm Post subject: |
Mike Fisher wrote: |
Acrylic Lacquer will spray smooth & shiny! |
not always,
depends on many factors.
what you are saying refers more to 2 pak. |
racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Sun Aug 18, 2013 6:42 pm Post subject: |
There's no way that is acrylic laquer, will be 2 pack.
Looks bloody good too. |
