74Pepper Samba Member
Joined: March 26, 2007 Posts: 719 Location: Dallas, TX
Posted: Mon Jun 24, 2013 1:35 pm Post subject: Install Fuel Sender 77 |
I yesterday spent three hours trying to reposition my fuel sender. The reason I had to re-install it was because The PO had installed it in such a position that the float was the float would stick on the front side of the tank and the sender was not able to signal the correct amount of fuel in the tank.
Removal of the sender wasn't too bad, but install was a big pain. The O-ring was very new, so it was difficult to get the thing to squish down far enough to screw the sender on. Lubing it up helped, as did having a helper push down on the top of the sender while I tapped it into place using a screwdriver in one of the slots.
Having struggled with this stupid thing for too long, I have some observations from my struggle (but sadly, no pics) to help others get this done effectively:
* The tabs on the sender line up with the slots on the fuel tank opening. One tab is smaller than the others. I scratched an X in that tab to keep track of it as I was installing the sender.
* Facing the tank from the back of the bus, the smallest slot is positioned at 11 o'clock (as if looking at the opening from the top of the tank). You have to fish the float into the hole, then turn the sender until you can drop the tabs down into the slots.
* When you align the tabs in the slots, prior to tightening the sending unit down the float will be laying 3 o'clock to 9 o'clock (the float end of the rod is at 9 o'clock).
* Note, that stupid O-ring doesn't really want to stay in the groove on the tank as you are installing the sending unit - be careful it doesn't drop down into the tank.
* If you tighten the sending unit clockwise, the float rod will end up angled 4 o'clock to 10 o'clock, or 5 o'clock to 11 o'clock if you turn it too far. This makes it so the float can only open so far, because it hits the lower part of the tank at the front, or it makes it so the float can't move if you turn it too far.
* I tightened my sending unit counter-clockwise, and the float ended up at 7 o'clock, which meant the float rod had full range of travel.
* A helper pushing down on the center of the sending unit to crush the o-ring while using a screwdriver in the slots around the outside of the sender to turn it was pretty easy, once I figured out all of the above. I guess I should mention, the previous owner had hacked a hole into the deck to access the sender when he replaced it, which is why I could get a person to help press down on the sender from above. If you doing this from inside the engine compartment through the firewall, I guess you're going to have to have gorilla strength to get the job done.
* Be sure to fill the tank completely and check for leaks around the sender before you close up the hole (or re-install the firewall).
Hope this keeps somebody else from cussing at their bus for three hours. _________________ '66 Beetle, in restoration
'74 Ghia, in restoration
'77 Westfalia Campmobile - Dangit - rear-ended! Now has primer-butt!
Per Gary, A.K.A. "Purple dress girl") |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Tue Jun 25, 2013 12:55 pm Post subject: |
I guess you have an access hole cut for the sender? If so, it's hard for me to understand why it was so hard for you. I guess if the o-ring was too fat you could have tried longer screws at least to get it started. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Jun 25, 2013 1:52 pm Post subject: |
Yes, there was an access hole cut into the deck. The fuel sender for a 77 doesn't screw down with screws - it is "screwed" onto the tank like you would screw the lid on a jar. It was very difficult to get enough downward pressure on the sender while screwing it onto the tank without assistance. _________________ '66 Beetle, in restoration
Posted: Tue Jun 25, 2013 1:54 pm Post subject: |
Ahh, I see. Persistance pays off. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
