Rich's 62 ghia build
c21darrel
c21darrel is offline
PostPosted: Mon Sep 29, 2014 1:15 pm    Post subject: Reply with quote
https://www.thesamba.com/vw/gallery/pix/1261462.jpg
Those clear caps are terrible, known to cause timing scatter. get a good one and avoid problems.
GhiaBuild
1967 DC build
Rich62ghia
Rich62ghia is offline
PostPosted: Wed Oct 01, 2014 3:21 pm    Post subject: Reply with quote
Clatter wrote:
Bah! Onward and upward! Very Happy
No sense in going backwards and putting the old stuff back on.
Drop spindles work much better than a beam that was just cut n' turned (adjuster-ed).
If you are going with the CB 2" beam (or one from the same place in Brazil that sells to everyone),
Watch out for the height range in which it was set up to adjust.
They always made their beams as a "lowered beam" where the adjustment range was from low to really low with standard spindles.
If you were like me, and got drop spindles to use with your adjustable beam, the highest setting will still be too low.
They now sell 2" beams with the adjusters set so they work well with drop spindles, too.
So get the beam for drop spindles, not the usual one, or you will end up like me, with chunks of your driveway missing....
Agree with the sentiment Clatter Im keeping the dropped spindles and going the narrowed beam with adjusters. Good tip on where the adjusters are set. My current stock beam has adjusters installed and the photos with the tyres rubbing is it set at the lowest position with no engine or fuel tank. So my current beam with adjusters is probably perfect just needs narrowing. Tossing up now whether to narrow myself or save myself the trouble and buy one. If I bought one, are the EMPI beams OK(not sure if this is the Brazillian one you refer to??) They just have the single plate on the sides for the shock tower, and are the cheapest.
sputnick60 wrote:
The beam I have now is set to take drop spindles from the normal height to lowered. I got the geometry to stay as close to stock with the intent of keeping the ride comfortable with full travel.
Nicholas
Is your custom Nicholas or off the shelf?? If off the shelf what make?
Thanks for the tip darrel, Ive got a growing number of parts on this build that after purchase, havent made the grade and gone to the circular filing cabinet. I'll take you advice and get a good one.
c21darrel
PostPosted: Wed Oct 01, 2014 4:33 pm    Post subject: Reply with quote
concur with Clatter. I had an aquaintance narrow my beam. I asked for it to be indexed so that i could lower slightly but i didnt want to scrape asphalt. I also have 2.5 drop spindles. It ended up too low and no upward adjustment. It was a lot of work (had to remove beam) to lengthen the holes to get upward adjustability. I was able to add about 1.5- 2 inches. So, order your beam based on your need.
GhiaBuild
1967 DC build
djway3474
djway3474 is offline
PostPosted: Wed Oct 01, 2014 5:14 pm    Post subject: Reply with quote
I narrowed one and it was not that difficult.
A large 3/4 blade pipe cutter is the best way to get straight cuts.
Clatter
Clatter is offline
PostPosted: Wed Oct 01, 2014 6:54 pm    Post subject: Reply with quote
The OG German beams are better than aftermarket for many reasons.
If you have the facilities to do it yourself - Go For It!
Bus Motor Build
What’s That Noise?!?
Rich62ghia
PostPosted: Fri Dec 05, 2014 5:45 am    Post subject: Reply with quote
Thanks for the encouragement guys, Ive decided that I will have a crack at narrowing the beam myself. Before then though I wanted to get the rest of the wiring in the rear finished.
Time to sort out the birds nest
Felt padding over the tar panels to hopefully cut down the noise
Side cover on
Ready for the engine. Still need to make a wooden packer to fit under the battery strap to suit shorter modern battery.
I also finally got my heads back from the reconditioners. There were a few cracks which took them a little longer than they expected. Allowed me to port the manifolds ready for the dual 44s
Next was cutting the heads to accept dual valve springs
Then assembly of the long block
got to remember those deflectors
Heads on and torqued up
Long block nearly finished. Next is to take the engine off the stand and fit the flywheel. Have to colour spray all the tinware before finishing to the engine, so time to get back to that front beam.
Found this awesome video on Youtube, which I will go by
kiwighia68
kiwighia68 is offline
PostPosted: Fri Dec 05, 2014 11:33 am    Post subject: Reply with quote
I've been following your thread for some time now for leads and for inspiration. I'm some steps behind you still. Could you please tell me what you used to insulate the firewall between the engine and the internal luggage compartment and where I may buy some? I have the original tar-board for my '68 Ghia but it is very untidy and cracked and I would like to replace it with something that looks original.
I saw your post on the upholstery thread and would like to know more about Kevin (AussieTrimmer?) I may come across to Oz later when my car is up and running for a custom but original look interior. Where does one source those chrome trim pieces on the doors?
I apologise for making my problems yours but hope you won't mind.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
Rich62ghia
PostPosted: Fri Dec 05, 2014 3:33 pm    Post subject: Reply with quote
No Problems Chris, to tell you the truth I didnt put that much thought into the insulation between the engine and fire wall because I still had the OG double layer on the other side of the firewall inside the cabin. In the engine bay I mainly wanted it to be neat. I used a bit of left over dynamat just to take any ring out of the firewall, and then used the cheaper fire wall kit that KGPR sells. They sell a more expensive german one, but I bought one years ago for my bettle and wasn't that happy with it, not sure if its the same type. But for now Im happy with this one. The test will be what happens when there is heat in the engine bay and what happens to it.
I think kev makes the best panels for the early ghias with the different panel sections. For later ghias TMI makes what looks to be the welded panels in single colours. Im pretty sure you can get the lower aluminium moldings from KGPR, kev makes the chrome strip just under the door handels, but Im not sure if they are on the 68 panels. May be have a chat with him to see what is meant to be on the 68 panel
djway3474
PostPosted: Thu Dec 11, 2014 1:10 am    Post subject: Reply with quote
I narrowed my beam 2 inches. It was not that hard and I am not much of a metal man.
I think I saw that same video myself.
Go for it. Cool
Rich62ghia
PostPosted: Thu Dec 11, 2014 3:08 pm    Post subject: Reply with quote
Go for it. Cool
Did you have to do any mods to the body to fit it in? I pulled the beam out the other night and measured the the distance between the shock tower seam and the body and the most I reckon I can narrow by plating one side of the shock tower as shown in the video is 20mm (3/4") either side. I am going to pull apart the rest of the beam tonight and see if I can narrow a bit more by taking some material off the ends of the tubes. Unfortunately this video is the only thing I can find on narrowing a OG king and link pin beam, havent found anything on the Samba. Plenty of topics but no instructions Confused
motorhead364
motorhead364 is offline
PostPosted: Thu Dec 11, 2014 4:09 pm    Post subject: Reply with quote
Looking awesome! What color silver did you use? That's the color I'm going with.
63 ghia coupe
c21darrel
PostPosted: Thu Dec 11, 2014 5:44 pm    Post subject: Reply with quote
2 inches narrowed should be a bolt on, shouldnt hit anything
GhiaBuild
1967 DC build
djway3474
PostPosted: Thu Dec 11, 2014 6:05 pm    Post subject: Reply with quote
https://www.youtube.com/watch?v=EXSv0FdVPJg
I took many tips from this video
Rich62ghia
PostPosted: Fri Dec 12, 2014 1:41 pm    Post subject: Reply with quote
Thanks Motorhead, the colour is called Asteroid silver and was found by accident. My ghias original colour was Lavender going off what I could see in the hard to reach places and the factory colours for 1962. Lavender isnt the most flattering colour for ghias so I was originally going to repaint in the colour the PO painted it which was Alpha Romeo red. My wife convinced me to paint it silver, so I went to the local auto shop and went with a premixed colour they had on the shelf. I started doing all the painting myself, separating the body then painting the undercarriage. Not sure what they are called in other countries, but this paint was an acryllic and I used a isocyanate free 2 pack clear top coat, both of which can be spayed by the diy without a booth. When it was time for the top side to be painted I handed it over to a professional who painted it in 2 pack (basecoat then clear coat) which by law can only be painted in a booth. I told him the colour not realising there would be different versions and he painted it in Asteroid Silver GMH (General Motors Holden local car manufacturer) which had a slightly bluer tinge which I prefer anyway. Being a General Motors colour theres probably a local equivalent.
Rich62ghia
PostPosted: Fri Dec 12, 2014 2:28 pm    Post subject: Reply with quote
I think thats true for a ball joint front end, your 68 looks great BTW.
I re-measured last night(pics to follow) and I only have 3/4" either side if I cut half the shock tower and plate Sad, hopefully this will be enough. Seeing if there are other ways of bringing in the trailing arms another 1/4" each side.
Yeah I watched all 4 parts. Good tips if you are installing adjusters, mine already had the adjusters.
c21darrel
PostPosted: Fri Dec 12, 2014 3:52 pm    Post subject: Reply with quote
^^^ Embarassed
GhiaBuild
1967 DC build
jpjohns
jpjohns is offline
PostPosted: Fri Dec 12, 2014 5:39 pm    Post subject: Reply with quote
Rich62ghia wrote:
The PO installed adjusters on the front beam, but I wasnt sure if the car would end up low enough, so after much deliberating decided to go with dropped spindles as well.
How far did you want to drop it? That looks a little more than 2 1/2 inches.
-Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member)
DONGKG
The Araneta Boys
Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
DONGKG is offline
PostPosted: Sat Dec 13, 2014 8:19 am    Post subject: Reply with quote
Your kg looks awesome! Gosh i need to go back to my kg that has been hibernating! Cool ride!
'67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20
Rich62ghia
PostPosted: Tue Dec 16, 2014 3:54 am    Post subject: Reply with quote
Im not sure how far from stock I want to drop it. I wanted the pan clearance to be roughly 6 inches with 175/65/R15 tyres. With the adjusters at their lowest setting it didnt look like it would be enough. I was buying a porsche stud pattern disk brake kit, which included the dropped spindles, so decided to install as I can always adjust up if too low.
Thanks DONGKG
Rich62ghia
PostPosted: Tue Dec 16, 2014 5:04 am    Post subject: Reply with quote
I started dissecting the beam on the weekend. First was to measure how much I could narrow it by, by plating the inner side of the shock tower.After checking then re-checking looks like I can narrow by 20mm(3/4 inch) at most either side without modifying the body.
Then pull the beam out after removing spindles, steering box, damper, tie rods etc
Remove the swaybar
Loosen grubscrews, slide out trailing arms and remove lower torsion springs
Then upper torsion springs
Beam dissasembled
Need to measure how far the trailing arms sit in the tubes to find a safe area to narrow, taking into account I didnt want to lose the steering damper mount, ended up being about 145mm in from the shock towers
After trying to cut with an angle grinder and going through 2 chinese blades hardly making any progress, I used a trusty old hacksaw to finish the job.
Trying to get a couple more mm by pushing in the needle bearings and grinding off the ends. It seems that you can only gain 2mm without fxxking the bearing, I pushed the first one in 3mm before realising I was crushing the ends, it now needs replacing Mad.
I can see why most people opt for purchasing a narrowed king and link pin beam, but at least I know this will work and where the adjusters will be. Looks like I will be able to narrow 22mm either side, 44mm or 1 & 3/4 inches, not quite 2 inches but hopefully enough for what I need. Looking to get this finished in the next couple of weeks.
Page 5 of 10
