| Rear heater elimination options for coolant hoses |
| A) Remove heater and just block all the lines. |
17% |
[ 7 ] |
| B) Connect coolant hoses together under the bench seat with a straight barb fitting |
15% |
[ 6 ] |
| C) Remove T fittings under the Van and connect hoses together with straight barb fittings. |
66% |
[ 26 ] |
| Total Votes : 39 |
Windig89 Samba Member
Joined: September 22, 2011 Posts: 184 Location: Montreal
Posted: Thu Sep 13, 2012 1:49 pm Post subject: Rear heater elimination. Plug or Connect |
Planning on eliminating my rear heater core and seems like there’s some disagreement on whether to simply block the coolant lines, connect them together, or eliminate the T outside the Van. I know this has been discussed before, but I don’t come across a general consensus... I read about disrupting flow the front heater, circulation issues etc…
Option A seems simple and is least permanent
Option B seems simple but requires an adapter to connect hoses
Option C seems the best, but is most work and most permanent. If the heater should go back into the Van down the road, this will create additional work.
What should I do? _________________ 1989 Vanagon GL Westfalia - 2.1L waterboxer |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Thu Sep 13, 2012 2:01 pm Post subject: |
This has been discussed many many times. It comes down to
you need to block or remove the hoses. Connecting them
together will short loop the heater system preventing full
use of the front heater. It's been mentioned that its also
bad for the vans warm up cycle but have no direct experience
with that. Any rear heater I removed (for some one else I
prefer to have it) I do the job right and remove the hose
and t's. With my Bostig conversions coolant lay out it needs
a small amount of flow through the heater core loop at all
times. To keep things simple and not have heat on my feet
in the summer. I leave my rear heaters valve wide open. Unless
the fan is on no heat comes out. Any time I am under the
rear seat I cycle the shut off valve a couple times to keep
things moving. No problems and no leaks. _________________ Bill M
87 Westy |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10305 Location: Mt Lemmon, AZ
Posted: Thu Sep 13, 2012 2:27 pm Post subject: |
First rule of tinkering : 'Save all the parts'.
Global warming making things too hot up there in Montreal? |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Thu Sep 13, 2012 4:15 pm Post subject: rear heater |
All I can say, why! I love my rear heater, can run it and don't need the front heater. Saves the front blower, I would like to only change the rear blower motor, the front is a pain in the ass! Real cold use both, mine don't leak hot air so no heat in summer, it doesn't take up much room, so I say why! But I did add a front shut off valve just to help in the summer!  _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Thu Sep 13, 2012 4:21 pm Post subject: |
D: Don't remove heater - fix it properly. _________________ 89 Westy 2.1 Auto |
Posted: Thu Sep 13, 2012 7:11 pm Post subject: |
Well we only use the van in the warmer season. April - November. So I've never turned it on. Even the front heater gets minimal use, rarely ever on more then half. The rear is leaking slightly from the valve I suspect. I have a papertowel down under and it's bright pink even with the valve closed, yes it smells. I really want the space!! Got my jack, fiemma leveling ramps, 2 camping chairs and my extension cord. I can barely close the seat. No other real places to store these big items... See where I'm going... Of course I will keep the heater on my shelf incase our needs change, but the ba6 (future propex) is there for any unexpected chills during the early and late season.
Winter here is murder to a vanagon. Salt salt salt. We have 2 other daily drivers to punish. _________________ 1989 Vanagon GL Westfalia - 2.1L waterboxer |
goffoz Samba Member
Posted: Thu Sep 13, 2012 7:58 pm Post subject: |
What about removing it pushing the hoses back under the van, and putting in a barb with a flow restricter. (piece of1/2" pipe squished in the middle)
In my 89 7pass. 2wd. I moved the whole unit over to the drivers side, to gain more room under the seat...just had run longer hoses,and make a new kick board....needed one anyhow
...most people don't even notice the difference |
JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1531 Location: Wisconsin
Posted: Thu Sep 13, 2012 8:09 pm Post subject: |
If I were to remove(to cold here to do that) I would connect and put in a restricter.
Try to mimic want the engineers did. Little things like this could defiantly change your coolant systems efficiency.
Even the climate you live in has a big effect on it. Just cause something worked for someone else might not in your area.
Jeff _________________ For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com
hdenter Samba Member
Joined: October 14, 2008 Posts: 2961 Location: San Luis Obispo, CA
Posted: Thu Sep 13, 2012 8:35 pm Post subject: |
I am doing away with the rear underseat heater because it wastes vital space under the seat. I am replacing it with the DOKA/Diesel floor duct that draws heat from the front heater core. Since I will be going turbo WBX and expect to do some touring in the mountains in summer, I am considering a supplimental radiator to help keep things cool if it needs it. I just might utilize the rear heater's hoses or T fittings to do it. We'll see.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
rubbachicken Samba Member
Posted: Thu Sep 13, 2012 9:03 pm Post subject: |
i removed ours to gain much needed space, since we are never in the back with lucy running it seemed a waste of space.
for now i connected the pipes together under the back seat, not the best, i will fix that soon when i get the system drained while working on the motor _________________ lucy our westy
lucy's BIG adventure
meet 'burni' |
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Thu Sep 13, 2012 9:24 pm Post subject: |
Why put in a flow restrictor? If the rear heater valve is closed in the stock configuration, it's the same as having two capped hoses or no rear heater hoses altogether.
If you're lazy or want to put the heater back someday, just cap the two hoses. Otherwise pull the tees from under the van and put an inline barb fitting in both hoses. _________________ 1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti |
Posted: Thu Sep 13, 2012 9:52 pm Post subject: |
| I used to carry a U shape bit of soft tubing, either 1/2" or 5/8" OD ??? with a ferrules soldered on each end. The tubing was pinched in the middle. When the heater would spring a leak, which happened all to often, I would just slip the hoses into each end of the "U", apply the clamps, and be on my way. |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 735 Location: Bellevue
Posted: Thu Sep 13, 2012 10:00 pm Post subject: |
| option C reduces the number of failure points. That's my vote and what I did. |
kbeefy Samba Member
Joined: March 10, 2006 Posts: 600 Location: Central Oregon
Posted: Thu Sep 13, 2012 10:41 pm Post subject: |
I did 'B' as an emergency repair on the side of the road, but if your ditching the heater I say cap or plug the lines at the motor and ditch everything. As presslab mentioned, whats the difference between a closed heater and a blocked off heater? Maybe theres a reducer in there that allows flow while closed, but I doubt it. Compared to the radiator the heater core is small potatoes.
I prefer the space, now that I'm not in a cold climate. If I was still in Alaska theres no way I would give up the rear heater!! |
goffoz Samba Member
Posted: Thu Sep 13, 2012 11:30 pm Post subject: |
| presslab wrote: |
| Why put in a flow restrictor? If the rear heater valve is closed in the stock configuration, it's the same as having two capped hoses or no rear heater hoses altogether. |
Crack one of those valves open, and take a look inside
...you'll see they flow ,even when "closed"
Approx a 3mm. hole...I just figger thar may be a reason for that  |
Posted: Fri Sep 14, 2012 12:58 am Post subject: |
Yep, take a good look at a system before you assume anything on it.
Little things add up and can make a difference. _________________ For OEM Subaru and SixStar parts and harness modications
AVsubaruconversions.com |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Fri Sep 14, 2012 4:25 am Post subject: |
| SSWesty wrote: |
Yes, and with new lines front to back and no clamps there is even fewer failure points. The added space under the seat is much appreciated. Here in the rust belt, if it is cold enough to need the rear heater, the Westy should be in the garage stored for the winter at that point! _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
insyncro Banned
Posted: Fri Sep 14, 2012 4:32 am Post subject: |
| SSWesty wrote: |
X2  |
insyncro Banned
Posted: Fri Sep 14, 2012 4:33 am Post subject: |
| goffoz wrote: |
| presslab wrote: |
X2 |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3673 Location: Dartmouth, Mass.
Posted: Fri Sep 14, 2012 6:14 am Post subject: |
| rubbachicken wrote: |
| i removed ours to gain much needed space, since we are never in the back with lucy running it seemed a waste of space. |
Same here. Had an air-cooled Vanagon before, so the heat from the front is great. I did option "C", although I originally blocked off the line with stainless steel bolts, cutting the threads off and clamping onto the unthreaded zone under the head.
Next plan is replacing the Weekender sloping plastic bulkhead under the rear seat with a vertical wood one. Every increase in space means less stuff in back that has to be moved around, although I may add 6x9 speakers in removable boxes in the new bulkhead since I already own them. _________________ John - 86 Wolfsburg Westfalia "Weekender"
Complete SA Grill Set-up for sale!
https://www.thesamba.com/vw/classifieds/detail.php?id=2748907
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
