Jody's 55 semaphore three fold restoration!
Page: Previous  1, 2, 3 ... 15, 16, 17, 18, 19  Next
tlambert
tlambert is offline
PostPosted: Wed May 04, 2016 12:18 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
I might be down that way in a couple of weeks. I'll get with you. I'd love to see it.
Tim
jody714
jody714 is offline
PostPosted: Fri May 13, 2016 6:46 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Well, she's Home getting used to the South Carolina grass and my other cars. Into the shop later to get an engine and a few other "dress up" goodies !!!
Jody
'55 Bug 3-fold Sunroof Deluxe
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
NIASE/ASE Master Mechanic
Low Country VW Club
Southern Integrity Aircoolers
drscope wrote:
If the guys on TV can do it in an hour, you should be able to get it done in 60 days!
tmb077
tmb077 is offline
PostPosted: Fri May 13, 2016 7:34 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Sweet Pea looks great Jody! Glad you have her home and ready for the final steps to getting her on the road.
Brother's 56 Thread http://www.thesamba.com/vw/forum/viewtopic.php?t=652839
tlambert
tlambert is offline
PostPosted: Fri May 13, 2016 7:51 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Looks really nice Jody!
Tim
jody714
jody714 is offline
PostPosted: Fri May 13, 2016 1:47 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Thanks Guys, that's a BIG load off my mind !!! Now I can relax while I'm finishing her !!!
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Sun May 15, 2016 7:08 pm    Post subject: Reply with quote
splitjunkie wrote:
jody714 wrote:
Yep, someone cut it off or it might have broken off....now I'll do what I can to save it. Good luck Don and enjoy !!! Thanks Russ !!!
Jody
My '54 had the same thing. I welded on a new section of rod to the top and ground it smooth and it looked perfect. Just tap threads on the top and you are good to go. I think 3/8" rod was almost exactly the same size and was not noticeable.
I ground each end to a point so it looked like two pencils pointing at each other. This gives you plenty of surface area and penetration for a good strong weld. I then cut a groove in a piece of 2" x 4" to use as a V block and cut out a section around where the two sections would come together so I could weld them together without setting the 2 x 4 on fire. I then clamped both pieces in the 2 x 4 and welded the two pieces together.
I put together this quick and dirty drawing. If you need more info let me know.
... yup my '54 had the same short shifter... I was told that was made shorter, back in the 70s to emulate the sports car feel... installed a correct length strait one and kept the shortie in my stash...
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
jody714
jody714 is offline
PostPosted: Sun May 15, 2016 7:57 pm    Post subject: Reply with quote
ZENVWDRIVER wrote:
splitjunkie wrote:
Jody
That's what I'm going to do...already have the correct stick and should be putting it in tomorrow !!!
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
tlambert
tlambert is offline
PostPosted: Fri May 27, 2016 6:22 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Jody are you bringing the oval to dragnight?
Tim
jody714
jody714 is offline
PostPosted: Fri May 27, 2016 7:38 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Yes I am, Tim, at least that's the plan right now !!! Working on it as we speak...putting engine in, adding "correct" things back on...!!!
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
tlambert
tlambert is offline
PostPosted: Fri May 27, 2016 9:32 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Cool hope to see you then.
Tim
jody714
jody714 is offline
PostPosted: Fri Jul 01, 2016 12:31 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Doing some interior work. New shifter going in..
New Coco Mats and shelf..
Step covers..
Open sunroof..
Swamp air cooler being fitted...
Re-installing engine firewall pad, wasn't installed properly....
Engine going in soon !!!!
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
txoval
txoval is offline
PostPosted: Fri Jul 01, 2016 6:34 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Beautiful car Jody. Check your front hood rubber seal...may be falling off on passenger side
jody714
jody714 is offline
PostPosted: Fri Jul 01, 2016 6:45 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Yeah, I have to keep reminding myself about that one !!! Thanks !!!
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
jody714
jody714 is offline
PostPosted: Fri Jul 01, 2016 7:41 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Here's the correct shifter installed along with correct Emergency Brake boot thanks to Frank Espinoza (RVA) !!! Also got the tray and coco mats in...
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
jody714
jody714 is offline
PostPosted: Fri Jul 01, 2016 8:05 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
I had to take the rear seat upholstery off of the WRONG seats and install them on the CORRECT '55 rear seat frames courtesy of Chris Vallone !!! Thanks Chris !!!
That looks and fits so much better and lays back where it's supposed to. Front seats look better when everything fits like it should.
I've had to re-do a lot of things to make them work right and I shouldn't have had to. If you're following/reading this STAY AWAY FROM VINTAGE METAL WERKS in Ohio.
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
nlorntson
Crazy VW Lady
nlorntson is online now
PostPosted: Fri Jul 01, 2016 8:41 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Coming together!
Another thing a judge will notice is the e-brake should be the same color as seats, shifter, steering column.
jody714
jody714 is offline
PostPosted: Fri Jul 01, 2016 8:53 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Thanks for the Tip but that's gonna stay the way it is...for now anyway !!!
Jody
'65 Double Cab
2-'66 Bug Deluxes
'67 Bug Deluxe
'69 Fatchick
'69 Baja
'73 Squareback
3-Dune Buggy's
3- Trikes
Low Country VW Club
FRK
FRK is offline
PostPosted: Tue Jul 05, 2016 7:26 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
It's coming along great Jody! Cool
64 Ghia
55 Kab
50 11G
50 11A
49 11
48 11
RVA Car Club
Tuned Perfection
Tuned Perfection is offline
PostPosted: Sun Jul 17, 2016 9:20 pm    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
Jody
Car is looking good Jody. Hopefully I'll see it completed one day.
As for VMW..... don't say you weren't warned LONG ago....
www.tunedperfection.com
txoval
txoval is offline
PostPosted: Mon Jul 18, 2016 4:16 am    Post subject: Re: Jody's 55 semaphore three fold restoration! Reply with quote
For VMW's, was it the assembly portion?
Their metal work/paint seems top notch.
Page 16 of 19
