coolairX2 Samba Member
Posted: Sun Sep 16, 2012 10:24 am Post subject: Okrasa vented valve cover question |
I purchased a pair of repro okrasa vented valve covers. I was expecting that I would have to tie these to a breather box. But now that I have the covers it looks like they were meant to just exhaust right out of the valve cover tube. I say this because there is not enough tube to attach a hose to. Is this the case? It seems like a bad place to exhaust oil vapor, above the heater tube.
Craig |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Sun Sep 16, 2012 1:19 pm Post subject: |
You really won't get any significant amount of oil out of them at all. Since the vent tube starts at the top of the cover it vents just air. On the last engine I ran them on after 28k miles the valve covers looked about what you would expect a non vented cover to look like. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sun Sep 16, 2012 3:31 pm Post subject: |
Yea hardly have anything coming from mine...little tiny wetness around the opening of the tip. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sun Sep 16, 2012 6:00 pm Post subject: |
Thanks for the info,
I installed them and they look nice and function fine as you described.
Craig |
Posted: Sun Sep 16, 2012 7:09 pm Post subject: |
EverettB wrote: |
Are the repros like these regular 36hp ones I have or are the "Okrasa" ones something different?
If they are the same, my friend has these on a normal 36hp engine and I can't remember seeing any leakage from the tubes. |
They are all pretty much the same, 8mm tube brass welded in place. I like to make the tubes shorter on the ones I make. The powder coat is the most expensive part of making them.
Some Chinese guy |
RichardinNZ Samba Member
Joined: September 16, 2011 Posts: 280 Location: Auckland, New Zealand
Posted: Fri Sep 21, 2012 10:18 am Post subject: |
^^^ this...
And they are not anything to do with Okrasa...just vented valve covers designed by the factory. _________________ www.blastserv.com
wanted:
pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Sun Jan 18, 2015 8:11 am Post subject: |
on the subject of breathing etc...
I am going to run an electric fuel pump, so will be blanking off the mechanical one, if I get a vented plate for a later engine does this need to go to a box? will it fit the 36hp case? if running it to a box along with valve covers can I just forget about breathing at the filler? It would be much neater and less plumbing.
finally, can I just vent the valve covers as per these ones (but I am using speedwell ones) straight out onto the floor, and run the fuel block off vent for case breathing into the intake or something?
must add never put breather onto a motor before etc. sorry if these are all daft questions!
Posted: Sun Jan 18, 2015 8:23 am Post subject: |
also... another thought, but please be gentle...
could I use this plate as an oil return line for full flow? rather than tapping the case?
and then vent out of the oil filler as normal? |
slalombuggy Samba Member
Posted: Sun Jan 18, 2015 10:15 am Post subject: |
I haven't done a lot of engine venting on 36hp stuff but this is what I can tell you about what I've found on my bigblock race engines at Bonneville. Internal engine pressure starts in the case, not the heads. Anything you can do to relieve pressure at the case will be better than trying to vent it at the heads. I run a #8 line out of my fuel pump block off to a breather box and vent out of the filler to the same breather box. I do not vent the valve covers, nor do I run lines to the airfilters from the breather. Even at sustained high rpm I have no problem with oil leakage.
No, you can't run the return line from the filter to the block off plate. It has to go back into an oil gallery.
brad |
Posted: Sun Jan 18, 2015 10:25 am Post subject: |
perfect. thank you for your detailed and precise answer. exactly what I need. much appreciated. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Mon Jan 19, 2015 8:20 pm Post subject: |
On the valve covers posted, does anything cover the end of the tube? Seems like trash could make its way up...maybe I'm overthinking it |
Posted: Tue Jan 20, 2015 1:26 am Post subject: |
or spiders |
Posted: Tue Jan 20, 2015 5:20 pm Post subject: |
Zip tie some foam around it if you want. As the engine cools off after running the air inside contracts and will pull air from outside into the covers. |
