56-57 heater vents
747frieghtdog
747frieghtdog is offline
PostPosted: Tue Sep 25, 2012 3:58 pm    Post subject: 56-57 heater vents Reply with quote
I have owned 4 Ovals throught he years, and recently acquired a 56. My question to someone who may know is, was there a change in heater outlets in the lower foot wells? I had a 55 and know they are placed forward rather than aft, but have seen 56, 57's with both positions being represented.
I have looked at several here on the site in the gallery, and it seems there may have been a change during 56 production. I guess there could be the occasional channel replacement with later channels, being positioned closer to the door jamb.
Thanks.
55 Oval
vwsonmybrain
vwsonmybrain is offline
PostPosted: Tue Sep 25, 2012 4:44 pm    Post subject: Reply with quote
IIRC, they did move back mid year 56... just can't remember what the specific date would have been. I had a later 56 with the heater vents towards the back.
747frieghtdog
PostPosted: Tue Sep 25, 2012 5:07 pm    Post subject: Reply with quote
Best I could come up with is December 56, does anybody know if that is correct? Thanks for your thoughts.
55 Oval
type4split
type4split is offline
PostPosted: Tue Sep 25, 2012 6:06 pm    Post subject: Reply with quote
My book shows the moved back 4" in January of 57
'67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts
janerick3
janerick3 is offline
PostPosted: Wed Sep 26, 2012 5:23 am    Post subject: Reply with quote
Ovals had 4 types of front heater channel vents:
- '53s had the round hole carried over from the splits
- '54s and '55s had a larger, oval hole in the same location with a mesh screen tack-welded to the inside of the channel
- '56s and early '57s had stamped louvers in the same location
- A new heater channel, with an internal pipe, was introduced on 19 December 1956 (9 January 1957 on cabriolets), per Progressive Refinements. The footwell vent was moved closer to the door, where it remained through the 1968 model year.
Thanks,
Jan K.
0nebadbug
0nebadbug is offline
PostPosted: Thu Sep 27, 2012 12:12 pm    Post subject: Reply with quote
Ya' learn something new everyday here... Cool
I always thought they didn't start adding the second tube until '65 year model.
Nice to know something new about my '57 Wink
::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 :::
oneeyedducky
oneeyedducky is offline
PostPosted: Sat Sep 29, 2012 10:11 pm    Post subject: Reply with quote
heater vents moved from the very front of the foot well to just in front of the door during the middle of the 58 model year,not 57
0nebadbug
PostPosted: Sat Sep 29, 2012 10:27 pm    Post subject: Reply with quote
So when was the inner heat tube added then?
cj1971
cj1971 is offline
PostPosted: Sun Sep 30, 2012 1:29 am    Post subject: Heater Vents Reply with quote
My car has the heater vents further back,it left the factory 9th January 1957.............
Snort
Snort is offline
PostPosted: Sun Sep 30, 2012 8:11 am    Post subject: Reply with quote
Progressive Refinements (as above) lists the change in heat vent location moving closer to the door starting with chassis number 1 385 974.
My car was produced about 10,000 units previous to this number and indeed, the vents are in the forward position.
Schwing
Schwing is offline
PostPosted: Mon Oct 01, 2012 6:26 am    Post subject: Reply with quote
Thats not right they moved in '57. I have an April '57 and my heater vents on the original channels were close to the door pillar (less forward). My vin is 1503962 so this lines up with Snort's comment.
I always heard it was Jan 57 or later when they shifted, not 58.
Shadetree Westy
http://www.thesamba.com/vw/forum/viewtopic.php?t=657279&highlight=
Single Cab - BBXXVII Long Distance Winner
