38 EGAS- 38 EPC carb
trynne
trynne is offline
PostPosted: Wed Sep 26, 2012 8:29 am    Post subject: 38 EGAS- 38 EPC carb Reply with quote
Has anyone tried this set up?? If so on what type engine. It looks like it might be a good alternative to Weber single at this price.
http://www.thesamba.com/vw/classifieds/detail.php?id=1362385
jvulich
jvulich is offline
PostPosted: Mon Feb 04, 2013 11:05 am    Post subject: Reply with quote
I just installed one on a 1600 dual port with a mild cam. There's a bit of fitting involved which takes a while for a novice like myself, adjustments seem easy but I'm chasing an issue now that once it warms up it doesn't want to run off idle which may not be related to the carb.
JACKASS
JACKASS is offline
PostPosted: Thu May 26, 2016 6:40 am    Post subject: Re: 38 EGAS- 38 EPC carb Reply with quote
i just replaced mine with dual carbs. the egas38 never run right for very long. i have come to the conclusion that if it is EMPI it is a POS. i do not recommend
it. if you want a 2 barrel try weber or zenith.
