dangerbus Samba Member
Joined: February 15, 2010 Posts: 239 Location: portland, OR/vancouver, BC
Posted: Mon Apr 08, 2013 8:52 am Post subject: |
drum definitely seemed loose to me...i got it off with only a wrench (granted an 18" wrench but it didnt take so much as a grunt)...
but that's not all that's going on as the brakes were covered in oil...
im opening things back up and hoping the guys show up soon for another set of eyes.
_________________ driving our bus through mexico/central america-
the blog: www.thedangerz.com
trip forum: www.thesamba.com/vw/forum/viewtopic.php?t=530204 |
Clara Samba Member
Posted: Mon Apr 08, 2013 9:01 am Post subject: |
could you tell where the oil was seeping out of?
plug behind RGB?
RGB case half?
under the seal holder?
over the face of the seal?
FWIW, you do need to torque the axle nut down properly to get the center seal to seal. If you did not need to stand on that 18" wrench to take it off it was probably not snug enough. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Mon Apr 08, 2013 9:06 am Post subject: |
Clara wrote: |
plug behind RGB?
RGB case half?
That was my first thought. It never got torqued down all the way, and that caused the leak. _________________ nothing |
Posted: Mon Apr 08, 2013 9:07 am Post subject: |
Clara wrote: |
plug behind RGB?
RGB case half?
right out from under the stub axle
does that mean we shouldnt be pounding the stub axle out again, we should just be tightening the drum down?? _________________ driving our bus through mexico/central america-
Birdmanhere Samba Member
Joined: June 03, 2006 Posts: 1054 Location: CANADA EH
Posted: Mon Apr 08, 2013 9:13 am Post subject: |
dangerbus wrote: |
Clara wrote: |
does that mean we shouldnt be pounding the stub axle out again, we should just be tightening the drum down?? |
I would try this first and see if that fixes it before stripping it down again.
I had this exact same issue when i first had my bus, drove me nuts when i realized all i needed to do was tighten up the drum
oh and make sure the drain hole on the bottom of the bearing cover is clear so if it does leak it will go out the back of the backing plate and not all over on the inside. _________________ 66 Bus
71 Bug |
Posted: Mon Apr 08, 2013 9:22 am Post subject: |
dangerbus wrote: |
does that mean we shouldn't be pounding the stub axle out again, we should just be tightening the drum down?? |
Yes. At the very least, try that first. _________________ nothing |
Posted: Mon Apr 08, 2013 9:26 am Post subject: |
holy #$&%!!
only here...
We're lying under the bus trying to work the stub axle (dont worry, now aborting mission because your idea sounds WAY easier)...
and we have the back hatch open for access to tools-
another vehicle backs up directly into the hatch (rather than the other 30' available behind the bus) and almost pushes the bus off the blocks.
Seriously??
luckily, it was blocked well rather than just the jack (thanks to last weeks lesson) and nobody was hurt-
other than the hinges to the rear hatch which obviously no longer close.
i guess thats our next project. argh. _________________ driving our bus through mexico/central america-
Posted: Mon Apr 08, 2013 9:30 am Post subject: |
Wow! That sounds a little too close for comfort. Hope you can tweak that hatch back into shape. It needs to seal properly to keep exhaust fumes out of the cabin. _________________ nothing |
Ian Samba Moderator
Posted: Mon Apr 08, 2013 9:45 am Post subject: |
Shit!!!
I would recommend finding a "cheater pipe" it's a piece of tubing that you can slip over your current mechanical device which will give you more leverage. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
Posted: Mon Apr 08, 2013 9:48 am Post subject: |
Ian wrote: |
Shit!!!
I would recommend finding a "cheater pipe" it's a piece of tubing that you can slip over your current mechanical device which will give you more leverage. |
Already laying beside the bus. Of course, the only one they had at the hostel we're working at is about 7' long...so it might be a tad over the top... _________________ driving our bus through mexico/central america-
big bus mike Samba Member
Posted: Mon Apr 08, 2013 9:57 am Post subject: |
Make sure the axle seal is installed correctly:
Posted: Mon Apr 08, 2013 10:11 am Post subject: |
big bus mike wrote: |
The outer spacer 8 can actually slide on either before or after the bearing cover (right past 9, 10, 11 on the stub axle/shaft)...
is that normal/okay? seems different than what the diagram shows. _________________ driving our bus through mexico/central america-
Ian Samba Moderator
Posted: Mon Apr 08, 2013 10:19 am Post subject: |
Yeah, that's fine. I think that diagram is for small nut 36mm RGB because of the angled brake adjuster holder and oil slinger washer.
Your version shouldn't use a metal washer at all on the axle. _________________ All your Buses are belong to us.
dangerbus wrote: |
is that normal/okay? seems different than what the diagram shows. |
It will fit that way on a big-nut rear end. That diagram is for "small nut" setup, but it was the only one I could find off hand. |
Posted: Mon Apr 08, 2013 10:23 am Post subject: |
dangerbus wrote: |
just checking... all new to me!
thanks _________________ driving our bus through mexico/central america-
Posted: Mon Apr 08, 2013 12:59 pm Post subject: |
Okay.
So we're back together and the tapping noise is gone.
there is a bit of a low humming noise however that maybe could be tire noise but certainly doesnt sound familiar to us (but were also on high alert for noise from that wheel).
Any chance the small corners broken off the teeth could would cause this noise??
It certainly feels good/right- but i dont want to take any chances before crossing the border. _________________ driving our bus through mexico/central america-
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Posted: Mon Apr 08, 2013 2:06 pm Post subject: |
Dude, your journey is epic, loving the video on page 1. Itīs given me so much inspiration for my journey into North America. Canīt wait for that.
I canīt believe we are both in Nicaragua and we have missed each other, if only I knew before I would have come and met you for sure, I was in your currently location San Juan Del Sur a week ago
If for any reason I come down there again chasing waves I will let you know for sure. If you start heading north you have to let me know so we can meet up for a beer, I am travelling quite slowly!
But if I was you I would cross into South America, it is amazing! If you need any advice on getting across to Colombia let me know, if you need any inspiration to go there, check out my videos on YT http://www.youtube.com/user/kombilife
Happy travels and keep living the dream!
Ben _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Apr 08, 2013 2:34 pm Post subject: |
dangerbus wrote: |
When the bearing on the rear of the stub axle began to fail it allowed the gears to be positioned in an orientation other than that which they were machined for. As the failure progressed, the misalignment was worse. The tolerances for those gears is pretty tight and by them operating in a way that the machined teeth were not in perfect aligment, the teeth were in essence, "remachined". Now that everything is back to normal, the gears, which, most likely, were subtley "remachined" are now clashing. Straight cut gears are noisy when everything is perfect. I think you are hearing the result of the abuse they were subjected too. Well, that and your newly attuned ears are more sensitive to the noise.
I would wager that some of the noise will disappear shortly as the gears get reacquainted. But keep checking things, especially the temp of the axle nut. That has always been the way I assess the health of the RGBs. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Mon Apr 08, 2013 2:40 pm Post subject: |
HastaAlaska wrote: |
Ben |
sadly ben, were heading south instead of north but if things change ill let you know (and please do the same)! _________________ driving our bus through mexico/central america-
Posted: Mon Apr 08, 2013 2:41 pm Post subject: |
cru62 wrote: |
I would wager that some of the noise will disappear shortly as the gears get reacquainted. But keep checking things, especially the temp of the axle nut. That has always been the way I assess the health of the RGBs. |
Sounds like good news, but we'll take it easy for a while and check often.
lets hope our second departure turns out a bit better than the first =) _________________ driving our bus through mexico/central america-
