Howard 111 Samba Member
Posted: Sat Oct 13, 2012 11:58 am Post subject: My engine and tranny |
Hi all. I don't post much, but I read everything. I wanted to post my engine and tranny specs.
I'm right proud of it. I'm an OLD VW nut.
This is in my 73 Ghia.
New AS41 case / full flowed
1.5 quart Berg sump
30mm oil pump and Berg pressure relief cover
Mahle 90.5 P/C - Total Seal 2nd ring
Berg 78mm crank - 411 center main
Carrillo 5.40 rods
12.5 lb flywheel
Berg stock size Equalizer pulley
Engle FK-65 cam
Berg 1.40 rocker arms - CM pushrods
P&P Berg Semi-Hemi cut heads. Stock valve size, 3 angle valve cut, dual springs
KEP Stage 2 - 2100 lb clutch
Berg Super Street disc
CB Turbo kit w/ Schwitzer S2A
Dual 48mm TBs w/ 35lb injectors
MSD Billet Distributor
MSD 6BTM
MSD high vibration coil & MSD wires
Rancho built tranny
3.78
2.21
1.26
0.82
3.88 R&P
Bus CVs
Sway-Away axles |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76915 Location: Sneaking up behind you
Chris659 Samba Member
Joined: June 14, 2011 Posts: 654 Location: Central Florida
Posted: Sat Oct 13, 2012 5:21 pm Post subject: |
Sounds like a hellva nice setup you have there! _________________ 61 ragtop, 12 turbo beetle |
Posted: Sat Oct 13, 2012 5:39 pm Post subject: |
downsbs Samba Member
Joined: July 17, 2009 Posts: 540 Location: Avondale, AZ
Posted: Sat Oct 13, 2012 6:49 pm Post subject: |
Very nice. I don't think I'll be trying to race you!!!! _________________ 1956 Rag W/ Semaphores |
Little Harry Samba Member
Joined: November 15, 2011 Posts: 340 Location: Marquez, Texas
Posted: Sun Oct 14, 2012 3:22 am Post subject: |
Uuhhhh...Wow! That's all I can say. You have a lot to be proud of. _________________ 1973 VW Karmann Ghia - 1679cc, Kadrons, MoFoCo 041's, Tri-Mil Euro, Interstate Battery, and a little rust.
Zack1978 wrote: |
From my perspective vintage VW's are beyond being used for daily driver purposes. It would be best to have your car parked in a garage, and kept away from the elements on a daily basis. Zack |
Uhhh...yeah...I disagree |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Sun Oct 14, 2012 5:52 am Post subject: |
Good job. Ghia's were ment to have a turbo with the big engine compartment they have. Lots of space and plenty of room to close the deck lid making the whole car look like a sleeper. I'm waiting to see some 1/4 mile time slips _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2222 Location: HdG, MD & NJ
Posted: Sun Oct 14, 2012 9:07 am Post subject: |
Cool! What part of VA? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Sun Oct 14, 2012 9:29 am Post subject: |
NJ John, I'm in the Danville area. Nice and quiet until I start my Ghia. |
lrcdnc Samba Member
Posted: Tue Jan 19, 2016 2:44 pm Post subject: Re: My engine and tranny |
NICE AWESOME |
widefivebug Samba Member
Posted: Wed Jan 20, 2016 3:58 am Post subject: Re: My engine and tranny |
VERY NICE! I would be extremely proud of that. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sun Jan 24, 2016 12:02 pm Post subject: Re: My engine and tranny |
Did I miss it in first post, what fuel/spark management are you using? |
Posted: Mon Jan 25, 2016 3:24 pm Post subject: Re: My engine and tranny |
ps2375, you only missed it by a few years.
Fuel delivery is handled by the CB fuel injection system that relies mostly on the TPS for it's signal. Give it more gas, the injectors spray more fuel. The ignition is handled by the MSD pieces, and the signal it gets from one of the throttle bodies, controls the timing. As boost begins, the timing begins to retard to a max you can set.
It's a very reliable setup.
Come Spring, I'll get more pictures of my car. It has a narrowed front beam which allows me to put fat rubber on the front and back. The interior is 2 poly seats, lots of gauges, and a 1,000 watt Sony system with 2-12" Kickers, a 4pt roll bar, and 5 way seat harnesses.
Want to race? _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
ps2375 Samba Member
Posted: Mon Jan 25, 2016 3:40 pm Post subject: Re: My engine and tranny |
I'm familiar with efi systems, I've built a couple of MS units and installed it on one of my cars and helped tune a few others. I just didn't see it listed.
Well done, I hope it stays together for you and runs well for a long time. |
Posted: Tue Jan 26, 2016 1:25 am Post subject: Re: My engine and tranny |
Given you had the choice to do it over, would you stick with the CB fuel injection or go with something else. |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Mon May 23, 2016 4:44 pm Post subject: Re: My engine and tranny |
Howard 111 wrote: |
Want to race? |
I'll be your Huckleberry -- Now we just have to figure out how to get together!!!
LOL
http://www.thesamba.com/vw/forum/viewtopic.php?t=508387&highlight= _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
Posted: Mon May 23, 2016 7:44 pm Post subject: Re: My engine and tranny |
Here in Virginia, they require you to keep all four tires on the highway. That's going to be a problem for you, isn't it? _________________ 1973 Karmann Ghia
