Greg74 Samba Member
Joined: November 17, 2011 Posts: 15 Location: New Jersey
Posted: Wed Oct 17, 2012 6:21 pm Post subject: Horn BEEPS every time I turn Left! |
Hello:
Just got done installing a new steering coupler, steering gearbox, steering dampener, and gas tank. While installing a new rubber coupler, I replaced the broken wire that bridged across it to complete the horn ground.
The horn worked as soon as I started the car and pushed down on the wheel. When I backed out of the driveway and turned the steering wheel to the left, the horn went on. As soon as I straighten the wheel it goes off. The horn beeps every time I make a left- it's crazy. Is something touching the gas tank? I sure don't feel it when I turn left. Could it be a bolt on the flange that connects the steering box to the coupler? Or is part of the steering column touching the gas tank? I looked underneath for scratchmarks but couldn't spot any.
Any help is greatly appreciated. Thanks again- the advice here is invaluable. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Wed Oct 17, 2012 6:45 pm Post subject: |
Greg-
The problem is between the steering wheel and the horn contact which is part of the wiper/turn signal switch assembly.
Sometimes the contact on the wiper switch gets A.F.U., sometimes it's the contact ring on the steering wheel.
Once you've removed the steering wheel, you'll see the contact.
Here's a photo from the gallery which shows a similar one that's been repaired:
Avoid driving in any NASCAR races 'til you fix it.
Good luck, Mondshine
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Oct 18, 2012 5:27 am Post subject: |
STOP - take a look at your wires at the coupler. Had the wire that jumped across too close to the one bolt and as soon as there was a little stress by turing one direction on the coupler, the horn sounded..... _________________ D-Dubya Manx clone - 63 Short pan,1914.
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Thu Oct 18, 2012 11:48 am Post subject: |
Look for insulation that has worn away from the ground wire at the coupler. Turning left makes contact sounding the horn. _________________ Ghia Owner Emeritus |
Greg74 Samba Member
Posted: Thu Oct 18, 2012 4:54 pm Post subject: |
Thank you all for the advice!
The horn was not working; closer inspection showed the old brown/tan wire across the coupler had broken away from its connector. I also got to see what appeared to be the original steering coupler with 3 big cracks in it!
Made the repairs, but looks like I have to go back and take a look this weekend. I don't think the problem lies in the steering wheel turn switch/ horn contact ring because that worked fine before and currently works fine when I press down. It's just that the horn now announces all my left turns.
Can't thank you guys enough for giving me the confidence to go in there and take care of things myself. Wish I had done this more so on my old bug... but still so glad I now own a THING- nothing like it. |
sixty9fasty Samba Member
Joined: April 12, 2004 Posts: 1066 Location: crockett, ca
Posted: Thu Oct 18, 2012 5:56 pm Post subject: |
Well, then Stop turning Left |
Semper_Dad Samba Member
Posted: Fri Oct 19, 2012 9:45 am Post subject: |
The "jumper wire" at the steering coupler connects the upper part of the steering column to chassis ground. The horn button connects the brown wire from the horn to the upper part of the steering column (which is grounded through the "jumper wire").
The horn receives +12V whenever the ignition is switched on.
Despite what has been posted, intermittent contact between the "jumper wire" and the chassis could never cause the horn to sound (unless the brown wire from the horn is grounded someplace else); the "jumper wire" is meant to be permanently connected to ground.
If the brown wire from the horn is unintentionally grounded while steering, the fault has to be where the contact ring on the steering wheel rubs against the strip which is part of the wiper switch.
Take another look at this photo from the gallery.
The blob of solder at 10 o'clock is where the brown wire from the horn is connected. If you were to touch the copper contact to the steering column, the horn should sound. That is the connection made by the horn button.
Remove the steering wheel, and take a look at the contact ring on the steering wheel, and the contact strip on the wiper switch.
When you remove and install the steering wheel, make sure the turn signal is in its "neutral" position. Before you pull off the steering wheel, make a small "witness mark" so you can easily re-install the steering wheel in the same orientation as it was.
Good luck, Mondshine |
Greg74 Samba Member
Posted: Sat Jan 05, 2013 2:43 pm Post subject: Now the horn beeps when I turn left and right! |
Mondshine-
I finally got around (after the storm) to removing the steering wheel and checking out the contact ring and turn signal swith assembly. I cleaned contact points and bent the copper tab (my switch on the column only has a copper contact tab/arm on the top) out a little- towards the steering wheel. I must have done something wrong as now the horn beeps when I turn LEFT AND RIGHT! Can you tell me anything from the photos of my turn signal switch on the steering column and contact ring on the steering wheel? Thank you- Greg
[/img] |
Posted: Sat Jan 05, 2013 3:08 pm Post subject: |
I assume that if you were to temporarily connect the copper contact with the steering shaft, (with the ignition switched on) the horn will sound. That is what happens when you press the horn button.
So somehow, the brown wire is being grounded during movement of the steering wheel. It is possible that somewhere along the length of the brown wire, the insulation of the brown wire has been damaged so that the wire is making intermittent contact with ground.
With the ignition switched off, you should read infinite ohms with your VOM leads connected between the copper contact and a good known ground. Check it while turning the steering shaft. You might need to replace the brown wire.
Hope that helps, Mondshine |
Riffster Samba Member
Joined: September 04, 2006 Posts: 66 Location: Pittsburgh, PA
Posted: Sat Jan 05, 2013 4:42 pm Post subject: |
My first thought was that the copper contact strip on your cancelling ring was broken -- that it SHOULD have an upper and lower part, in which case turning the wheel might cause the remaining part to rotate about the rivet and make contact with something like the mounting screw inside the cut-out. On closer inspection, it looks like there's a plastic tab that's meant to keep that from happening. Still, is it possible that there's been enough wear that the copper contact strip IS swiveling around the rivet?
If you try to wiggle it and it doesn't move, then it's something else. Of course, if it DOES wiggle, there's no guarantee that's the problem either, just something else to fix and try.
Another thought - is it possible that the copper ring on the steering wheel (and the plastic piece inside it) have worn down enough that the contact strip can make contact with the mounting screws you can see inside the steering wheel hub? Or is the honking not that intermittent?
-Larry |
Greg74 Samba Member
Posted: Thu Apr 11, 2013 5:47 pm Post subject: Fixed the horn beeping every time I turned left! |
I finally got around to getting the horn to work as it should. With the steering wheel removed, I made sure all of the four screws that held the turn signal switch assembly down onto the column were fastened tightly- one was sticking up and needed tightened. Then- and I think this was my big mistake- I made sure there was a gap of about 3mm between the steering column and the wheel (fastened wheel down, then loosened 2 bolts under dash to adjust column away from wheel). Problem solved! |
Vw1600dellortoGR Samba Member
Posted: Sun Nov 10, 2013 11:36 am Post subject: |
Hi, i have kind of the same problem, it looks like i have a horn relay, and the car beeps when steering but not all the way it beeps and if you steer more it stops i replaced the bearing in the tube because it could go up and down but this didn't solve the problem if i disconnect the brown wire from the ring it still beeps, if i remove completely the brown wire still beeps what can it be? |
Posted: Sun Nov 10, 2013 11:37 am Post subject: |
Posted: Sun Nov 10, 2013 11:43 am Post subject: |
Did you read this entire thread? _________________ D-Dubya Manx clone - 63 Short pan,1914.
wewantphil Samba Member
Posted: Mon Feb 01, 2016 3:54 pm Post subject: Re: Horn BEEPS every time I turn Left! |
FWIW I was having a similar issue with my T25 and this post helped me. the threads on the aluminum mount assembly that the mounting screw nearest the turn signal assembly contact tab needs to screw into was mostly stripped so the turn signal assembly would not mount firmly. There was an extra pin on the wiring pins that also served as a washer at the screw hole, but that pin was not used anyway so removed it effectively removing the extra washer spacing, making enough room for the screw to reach past the stripped area and take hold into the aluminum threads and hold the turn signal assembly firmly in place. Now the vehicle only beeps when I tell it to |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Tue Feb 02, 2016 1:14 pm Post subject: Re: Horn BEEPS every time I turn Left! |
I have kind of the opposite issue...my horn only seems work when I turn the wheel to the right. Any advice for this particular horn symptom?
Thanks... |
