zac_atac44 Samba Member
Joined: September 18, 2011 Posts: 269 Location: Tennessee
Posted: Thu Nov 01, 2012 12:24 pm Post subject: Zac's 2332cc engine build. |
I am really looking forward to getting this build started. Thanks to all who have given me advice thus far. Look for more posts as new parts show up.
CB performace aluminum engine case showed up today:
94mm bore
clearanced for 86mm stroker crank, but I will be using a 84mm
I finally got the case apart:
Any words of wisdom going into this build is always appreciated!!
Thanks. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Thu Nov 01, 2012 12:59 pm Post subject: |
I would look into replacing the oil pick up with a German one. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
mark tucker Samba Member
Posted: Thu Nov 01, 2012 1:00 pm Post subject: |
besure to clean all the gallys real good. and if you do the cambearing oiling mod be carful on the center one that is very close to the cutout for the stroker clearancing, you can widen it to the rear of the case(pully end)where there is plenty of room to work.I dont know why these new cases dont come with that done and moved about 2mm., be sure to check everything 4 times before final check&assy. |
Jon65 Samba Member
Posted: Thu Nov 01, 2012 2:15 pm Post subject: |
vwracerdave wrote: |
I would look into replacing the oil pick up with a German one. |
x2. |
slalombuggy Samba Member
Posted: Thu Nov 01, 2012 2:35 pm Post subject: |
There's lots of sharp edges and protrusions on the insides of these cases as well as some casting slag. I spend about an hour a side on both mine to smooth everyhting out. I open up the small holes on the center main webs a bit to let air out the back of the pistons. I open up the space at the top of the case over the webs for a bit more venting. I open the oil return hole from the cam gear well a bit. I open up the hole under the generator stand a bit and smooth it out. Check the oil holes on the main baring saddles, both my cases needed a bit of adjustment.. Check the oil pump hole alignment. Find a German pickup for it. My first engine had an oil leak on the 3/4 side at cam gallery plug under the cylinders on the side of the case. I'm going to tap and plug mine.
Did you get the 3.5mm raised deck case? I only needed to put a .010 shim under my barrels to get .048 deck and should be clos to the smae on my next one.
brad |
Bad bug Samba Member
Posted: Thu Nov 01, 2012 3:16 pm Post subject: |
Document everything i want to see if these cases have improved in manufacturing. |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Thu Nov 01, 2012 10:24 pm Post subject: oil pickup |
Just curious...what's the issue with the oil pick-up?
I've been using the Brazillian oil pick-up for seven years in my current motor, with a brazed on extension for the deep sump. Everything is sealed tight and works very well. No issues. _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
Posted: Fri Nov 02, 2012 6:39 am Post subject: |
Could yall go into depth about why I need to get a German oil pickup tube? What are the advantages of the German one? I also have another rookie question. What kind of oil pickup tube is installed on mine? |
Posted: Fri Nov 02, 2012 7:03 am Post subject: |
I choose the standard deck height for my engine case. |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Fri Nov 02, 2012 7:09 am Post subject: |
Just a suggestion. If you upload your pictures to your gallery on thesamba instead of hosting them on other websites you can refer to them faster in the future, prevent broken links and people who can't view websites like Photobucket from work can still view your pictures. All this will help you get answers to any questions you may have since pictures are so helpful to see. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Jon65 Samba Member
Posted: Fri Nov 02, 2012 2:32 pm Post subject: |
zac_atac44 wrote: |
Could yall go into depth about why I need to get a German oil pickup tube? What are the advantages of the German one?? |
I believe that one of the advantages of the german pickup tube is that it has a larger diameter tube than the Brazilian one, which means more oil flow.
Which is good for a VW engine. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Nov 02, 2012 9:21 pm Post subject: |
Actually, it's the angle of the tube in the pickup that sux. Try installing a deep sump with that POS you got right now, it's downright impossible. Get a German one, you'll thank us later. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Fri Nov 02, 2012 10:04 pm Post subject: |
Thanks guys I will look into installing a German oil pick up soon and I will post pics during the process. Thanks again. |
Posted: Fri Nov 02, 2012 10:06 pm Post subject: |
Where is the best place to purchase this German oil pickup? |
AlteWagen Troll
Posted: Sat Nov 03, 2012 1:54 am Post subject: |
zac_atac44 wrote: |
Zac i think when ordering your case from CB you should have ordered it with the german pickup tube. This option is available. |
Posted: Sat Nov 03, 2012 1:55 am Post subject: |
Ah! excellent blueprint sheet, everything is there, Zac please use this sheet to check your case and report findings here. |
Posted: Sat Nov 03, 2012 2:54 am Post subject: |
Is everyone expecting me to find something wrong with my new case? Everyone seems so intrested in this. |
Posted: Sat Nov 03, 2012 2:57 am Post subject: |
Sweet spread sheet. Thanks I will put that to use. |
Posted: Sat Nov 03, 2012 3:06 am Post subject: |
Quote: |
Zac i think when ordering your case from CB you should have ordered it with the german pickup tube. This option is available |
I just checked the cb performance website and didn't see that option avalible. They have an option for case saver sizes but I didn't see one for oil pickup type. |
