zac_atac44 Samba Member
Joined: September 18, 2011 Posts: 269 Location: Tennessee
Posted: Sat May 24, 2014 12:07 pm Post subject: |
Hey Mark thanks for the heads up. I checked that clearance between the rockers and the head studs. They all are closer than normal but still have plenty of room.
Installed pressure plate and clutch today.
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sat May 24, 2014 1:06 pm Post subject: |
I'm guessing that you told CB your deck height, cam, and ccs and they recommended the chamber volume to you then. Correct? Otherwise, you should know your compression before the heads go on. |
Posted: Sat May 24, 2014 4:04 pm Post subject: |
That's correct buggyguy1967 I went with a 0.04" deck height and a camber volume of 59cc with a 0.06 copper head gasket. My compression ratio worked out to be around 8.6:1. I also have a set of 0.04 copper head gaskets if I want to raise the compression up just a bit to 9.0:1. At the last minute I decided to lower the compression ratio to keep the motor in the pump gas range. |
Posted: Sat May 24, 2014 4:23 pm Post subject: |
I don't see where you posted what kind of cam you went with.
I think many would agree that 8.6 is low for most anything besides a W100 cam.
8.6 isn't horribly low, but your engine could be a lot more efficient if the compression was matched to your cam specs, and still run on pump gas.
Since I don't know your cam, I'll list my preferred static settings for the Engle cams I use:
W100 - 8.3-8.6
W110 - 8.8-9.0
W120 - 9.2-9.5
FK8 - 9.4-9.8 |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Sat May 24, 2014 5:03 pm Post subject: |
zac_atac44 wrote: |
I went with a 0.04" deck height and a camber volume of 59cc with a 0.06 copper head gasket. |
So, to clarify: You have .04" deck, and a .06 shim, for a total of .1" deck and 8.6:1 compression. If so, you could do better, you not taking advantage of some potential performance. |
Posted: Sat May 24, 2014 5:16 pm Post subject: |
So a 9.0:1 compression would be better with the .04" head gasket.
What octane range does that put me in? I want to stay in the pump gas range. |
Posted: Sat May 24, 2014 5:20 pm Post subject: |
Looks like you're using a high lift 1:1 cam with 1.3 rockers. Will it work? Sure. How long? Idk.
How much lift at the valve with that combo? Have you figured it out yet? |
Posted: Sat May 24, 2014 5:32 pm Post subject: |
Yall sure dont instill alot of confidence in a rookie engine builder. I still have alot of learning to do and I realize this. Alot of the learning that I have done has been done on the fly because I have limited resources. |
Posted: Sat May 24, 2014 9:09 pm Post subject: |
Sorry. Didn't mean to. I just don't understand how you went about your parts selection. I usually notice that build threads have a lot of comments that steer the builder in the right direction. I can only guess since you haven't been including specs, the members haven't had much to comment on.
I believe you'll be lifting around .560" with that cam and 1.3s. The 2240 is like a 130 with less duration, so it lifts just as high, but up a steeper ramp. It probably makes power to about 6500 RPM. It's a cam that will be harder on the valvetrain for sure. I'd set aside the 1.3s for now and use some 1.1:1s OR swap the cam for a friendlier one that is designed for ratio rockers.
I remember building the same way you're doing. I was in the home stretch and just wanted to close it all up. It never was ideal for me in the end. The best way to build an engine is to have a well thought-out and compatible parts list compiled before any purchasing is done. Have your power goals, RPM goals, and longevity goals all sorted. If you're blending used with new, make sure the new will compliment the old so nothing is choking down anything else.
I can say that you made a great head choice for a 6500 RPM 2332. Not too big or small. Weber 44s or Dell 45s with 38 vents will be just about perfect for this build. If you need help with real German tins or thermostat parts for the engine, hit me up. |
Posted: Sat May 24, 2014 10:05 pm Post subject: |
What ratio rocker do you recomend me getting to get good performance? |
Posted: Sat May 24, 2014 10:38 pm Post subject: |
Rockers cost more than a cam. It might be wiser to just choose a 6500 RPM ratio rocker cam.
That cam is meant only for 1.1 rockers. You could use what you have, but may only get 25,000 out of it before headwork is needed. |
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
mark tucker Samba Member
Posted: Sun May 25, 2014 10:35 am Post subject: |
I would choose another cam. and keep the 1.3 rockers, and change to a .040 head gadget,remove .040 worth of cylinder shims. I run the cb 2250 cam with 1.33 rocker,10.4cr on pump gass, every day well almost, but it's my only car other than race car& unfinished 356. I would shoot for 9.5~10 cr. with less lift on cam. that cam is for 1.1 rockers. |
Posted: Sun May 25, 2014 10:41 am Post subject: |
my 2332 had the 2250 cam& 1.33 rockers,pulled oh so sweet everywhere [email protected] cr, that cam is now in my 2028(about 3-4 years)not quite the same pull but still hard running. if I was building a 2332 again to be like that one I would use fk8 with 1.4 rocker.a lot less lobe lift+a few degrees more2 or 4 degrees. |
Posted: Sun May 25, 2014 3:56 pm Post subject: |
Ok lets talk about the performance and reliability trade offs that come with keeping the 1.3:1 rockers or changing my set up to 1:1 rockers. I now understand that my cam is designed for 1:1 rockers. What kind of strain would my valve train undergo if I stayed with my 1.3:1 rockers (Specificly)? I want a good reliable engine that puts out some hefty power without having to rebuild my engnie every weekend. I understand that the rockers are a more expensive buy but I would MUCH rather buy some 1:1 rockers and install them at this point than tear my engine down, unless the 1:1 rockers are going to totally make my engine a pussy.
What about insted of installing 1.3:1 rockers I downsized my rockers to 1.1:1? Same problem? I dont know.
With all that said, I really appreciate all of your input. |
Posted: Sun May 25, 2014 8:29 pm Post subject: |
your throwing away a lot of spring pressure witch is rpm& valve job if they start fluttering/bouncing due to loosing about 100lbs of open pressure and still throwing the lifter& pushrod the same distance.split it & put in another cam with less lobe lift.& I would up the duration to around 256~262 [email protected] use either 1.3 or 1.4 witch ever works with what you want or get. my 2250 cb cam has over 70000 miles with 1.33 ratio rockers. ( around .555 lift) idles smooth& runs great. it runs about the same as the old fk8 I had with this crank/head combo 10 years ago.but thats just butt dyno figures |
Posted: Sun May 25, 2014 8:42 pm Post subject: |
Quote: |
your throwing away a lot of spring pressure witch is rpm& valve job if they start fluttering/bouncing due to loosing about 100lbs of open pressure |
Does it make any difference that I have a high rpm valve spring upgrade?
650 spring upgrade is what its called, also titanium valve spring retainers |
Posted: Mon May 26, 2014 10:01 am Post subject: |
yup it does, your wasting a great upgrade that that cam will never be able to take addvantage of.... a little lower lobe& a little more duration and you will heve a fun ride.and it should be very reliable. |
Posted: Thu Aug 07, 2014 12:41 pm Post subject: |
Well, it has been a while since I have posted any progress on my build. Truth is, I have had some set backs (Learning opportunities). First, in a discussion with Mark Tucker I learned that the cam that I had installed was not ideal for my particular build. So, I swapped out my 2240 cam for a 2250. This means that I had to undo all of my hard work and break open my case. It took me a while to do this, I was pretty bummed out about it.
Finally got my case opend back up and started the clean up process. If I can give anyone advice on a sealant not to use it would be HondaBond!!!! Its not that it is a bad sealant its that it is SUPER hard to clean off. It took me forever to get my case cleaned up and back to assembly quality. I am sure that it is a good sealant but it is not worth the trouble to clean up when you break open your case and do some maintenance.
So,I finally got to reassembling my shortblock and began the process of bolting my case back together. Got to torquing the case down and the case halves would not fully go back together.
Later on I learned about shuffle pins. Turns out you dont have to put o-rings on your main studs if you have shuffle pins.
So I had to break open my case again!! This is when I found the o-rings shoved down into the slot where the shuffle pins were supposed to go. No damage done to the case though (Thank goodness).
So, I began the cleanup process again, which was much easier because I used Loctite 518.
So far I am very pleased with the Loctite 518.
Once I got everything cleaned back up I reassembled my short block.
Then sealed everything up.
Then torqued up. Its amazing how easy things went without those o-rings in the way.
Here is where I made some changes to my build for the better.
1. I replaced my oil pump with a full flow oil pump
2. purchased a front main seal installer (worth every penny)
3. set my endplay at 0.006
Much happier with this setup.
Yesterday, I mounted my engine on the transaxle.
