88 Vanagon wont start
Forum Index -> Vanagon/Eurovan Share: Facebook Twitter
pimpn
pimpn is offline
PostPosted: Sat Nov 03, 2012 3:58 pm    Post subject: 88 Vanagon wont start Reply with quote
I checked out the bat and it's fine. When I put the key in the ignition to start nothing happens. no fuel pump hum no turn over no nothing. Does this sound like a relay issue?
MidwestDrifter
MidwestDrifter is offline
PostPosted: Sun Nov 04, 2012 6:56 am    Post subject: Reply with quote
do you have power at the dash with the ignition on? Such as gauges and warning lights?
My first guess would be an ignition switch, but that's just a guess. You will need to follow a troubleshooting process to diagnose it. Got a service manual?
1982 Diesel Westy W/ ABA I4 hybrid
Epic Road Tripping since 08/05/12
http://drivechuckdrive.blogspot.com/
pioneer1
pioneer1 is offline
PostPosted: Sun Nov 04, 2012 1:56 pm    Post subject: Reply with quote
When you turn the key power flows to the solenoid(attached to yer starter) Make sure the little wires are on the spade tip connections or no crank.
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'95 VW Rialta
'73 Campmobile
insyncro Premium Member
insyncro is offline
PostPosted: Sun Nov 04, 2012 2:51 pm    Post subject: Reply with quote
Relays in the box above the coil control the fuel injection.
Dont forget about how often ignition switches fail.
Grab a multimeter and start testing.
pimpn
pimpn is offline
PostPosted: Sun Nov 04, 2012 3:44 pm    Post subject: Reply with quote
no service manual but I'm sure i can find one floating around on the net some where easy enough. Yes i have power at the dash. if it was just the ignition switch would the fuel pump not fire up? Thank-you.
pimpn
pimpn is offline
PostPosted: Sun Nov 04, 2012 3:46 pm    Post subject: Reply with quote
k. I will check this out but again... no action from the fuel pump... would this not crank even if there were a missed connection in the solenoid?
pimpn
pimpn is offline
PostPosted: Sun Nov 04, 2012 3:48 pm    Post subject: Reply with quote
Thanx for the input. I will give this box a shot.
Reply to topic    Forum Index -> Vanagon/Eurovan All times are Mountain Standard Time/Pacific Daylight Savings Time
