KAMAX Samba Member
Joined: October 19, 2003 Posts: 232 Location: Chartres - FRANCE
Posted: Sun Nov 04, 2012 3:06 pm Post subject: Door window channel resto question.What felt material u use? |
I have sandblasted and painted my metalic channels. I was lucky to find almost NOS ones, but rubber and felt material were damaged by time and bad storage.
So i have changed the rubbers (from ricardo. very pleased with them) but can't find correct material for the felt material that is glued on.
I have seen several repro offered by different saler on thesamba but it's either too thin or too thick...
I know it need to be UV and water protected...
Any clues or help will be highly appreciated. |
KAMAX Samba Member
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
mdvanderploeg Samba Member
Joined: November 06, 2011 Posts: 126 Location: Raleigh, NC
Posted: Sun Apr 26, 2015 1:29 pm Post subject: |
I read this string, and the links, and looked in the Gallery....I think I know the answer, but want to verify. Is it correct that the felt material covers everything, including the rubber and the metal channel? Just want to make sure, since installing the felt and assembling the window assembly more than once sounds like something to be avoided. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sun Apr 26, 2015 7:25 pm Post subject: |
Yes, the felt needs to cover the rounded edge so it has a finished look to it.
I just did my drivers side door last weekend.
I think the proper order for door assembly is:
1. Inner and outer glass seals (with the spring wire)
2. Curved glass channel
3. Inner latch mechanism
4. Straight glass channel
5. Door glass
6. Window regulator
----- Install door
7. Check strap/rod
8. Outer handle
I guess you could put the curved channel in after the inner latch as well.
I found it easiest to do this assembly with the door off.
Good luck! |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Apr 28, 2015 12:47 pm Post subject: |
Restoration specialties sells the mohair black cloth. The one thing you have to be careful of is that the cloth is glued, tucked all the way down to the very bottom of the rubber channel. I cut some 1/4 masonite sections that put together followed the curve of the upper window and used them to push, hold the felt all the way into the channel while the glue set. I used wood workers spring clamps. I think I have pics somewhere, will try to post later... _________________ John Henry
'57 Deluxe
'56 Single Cab |
BjornTore Samba Member
Posted: Tue Jan 03, 2017 3:19 pm Post subject: Re: Door window channel resto question.What felt material u use? |
Hello. Anybody who know someone who sell felt material for these window channels? In correct color, UV safe and for 1949 split? |
Porsche904 Samba Member
Posted: Wed Jan 04, 2017 2:47 pm Post subject: Re: Door window channel resto question.What felt material u use? |
BjornTore wrote: |
got mine from Jacek, very good stuff
[email protected] |
Posted: Thu Jan 12, 2017 3:07 pm Post subject: Re: Door window channel resto question.What felt material u use? |
BjornTore wrote: |
I got both the fabric and rubber from Ricardo (split parts unlimited) and it was very nice.
http://www.thesamba.com/vw/classifieds/detail.php?id=319690 |
