FreakCitySF Samba Member
Joined: June 08, 2004 Posts: 642 Location: San Francisco
Posted: Mon Nov 05, 2012 1:01 pm Post subject: VW generator covers, just 1? 2? or none at all? |
So currently I have 1 generator cover on my generator. I ran the generator for a few years without a cover at all.
And then recently I realized the underside is open. I was thinking of covering up the bottom side opening on the generator.
I do mostly short driving in San Francisco bay area weather.
I read somewhere that the generator needs air cooling.
I have 1 or 2 generator bearings that are gummed up and failing so I'm thinking a cover would help down the road.
What do you think?
Thanks for any info!
Chris |
Semper_Dad Samba Member
Posted: Mon Nov 05, 2012 4:52 pm Post subject: |
I only have one cover. I assume that gravity has something to do with stuff not falling UP in the lower hole.
The cooling fan does provide some cooling for generator. _________________ Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492 |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Mon Nov 05, 2012 10:20 pm Post subject: |
If this is what you are talking about i have only seen one cover on the top , most of them has been lost.
Posted: Tue Nov 06, 2012 3:04 pm Post subject: |
Yup and directly on the other side is the same deal but with no cover. Debris, dust can always fly up in the generator from the fanbelt area. It's mostly just a port to get at the brushes but thats about it. Since most folks don't have either cover or just the top one It cannot be a issue but still. I like knowing its covered up from the engine enviroment/elements. |
Kibiyo Samba Member
Posted: Tue Jul 21, 2015 12:57 am Post subject: |
Keep it covered!
There is a Carburetor sitting right above. Imagine if fuel was to leak and get in the Generator while its sparking...
You know the rest... |
