citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Sat Nov 24, 2012 7:58 am Post subject: |
GodJockey wrote: |
Are you going to do anything to the trans like flush or regasket or anything? Reason I ask is because, I have mine out and other than a fluid change what should I do? |
i drove the thing before i tore it down so i know that it is ok but i will tear it down and check every thing out replace the seals fluid clean the case add new fluid because i am restoring everything on the car. On yours if you know it is ok replace the main and side seals clean and replace fluid it is a lot easier now than after it is all together. |
Posted: Tue Nov 27, 2012 7:02 am Post subject: |
benn working on the exhaust to see if i can save it since it is the original one . I sandblasted it to find the holes the main holes were in the end I had a new 40 hp bug muffler so i cut the end off and welded it to the end of the thing exhaust a couple of small holes i welded up a little more work and i think it will be saved.
Posted: Tue Nov 27, 2012 7:10 am Post subject: |
Also working on the windshield frame brother Ron had some metal piecies made up to repair the frame i am trying to repair the frame since most thing frames are rusted and 400.00 is a lot for a new frame i will send more pictures when done.
Yarkle Samba Member
Joined: August 03, 2009 Posts: 1218 Location: the Hills of Western Maine
Posted: Tue Nov 27, 2012 7:04 pm Post subject: |
thanks he did a lot of work but a nice job i have mine almost finished will put the pictures on tomorrow or the next day and you can see how it came out i have about 8 hours in one side it is a lot of work |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Wed Nov 28, 2012 4:17 pm Post subject: |
finished the windshield frame ready for sealer primer and paint
Posted: Fri Jan 25, 2013 10:31 am Post subject: |
A little update been working on other peoples things so I have not had as much time to work on mine here are a few pictures
body ready to go to the sandblaster
body back from the sandblaster
body back from brother Ron after puting the sealer on got a little ice on it last night |
Posted: Fri Jan 25, 2013 10:39 am Post subject: |
Got to do work on the engine ready to assemble
I had to machine the case were the cylinders set
smooth surface ready for the cylinder
I had to align the case
all the parts laid out it takes a lot or parts for a vw engine
I had to machine the heads and put a hemi cut on the head
rebuilt the dist.
rebuild pedal assembly
swhitcomb Samba Member
Joined: November 05, 2003 Posts: 5673 Location: Inwood WV
Posted: Sun Jan 27, 2013 8:10 am Post subject: |
swhitcomb wrote: |
No thrust cut? |
did not need it std crank very little wear on the case |
Posted: Mon Jan 28, 2013 4:56 am Post subject: |
Nice. You do your own machine work? _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Mon Jan 28, 2013 6:45 am Post subject: |
swhitcomb wrote: |
Nice. You do your own machine work? |
Yes The Domeck Brothers Ron and me are lucky He does all the body and paint work i do all the machine work and building of the frame engine and transmission and we both put them together. He does'nt like to get greasey and I don't like to get dusty so it works out good. |
Posted: Mon Jan 28, 2013 7:50 pm Post subject: |
Wish I had a brother. I do all of the paint and body, plus mechanical work myself. Not equipped to do my own machine work yet. I'd love to have the money to invest in the equipment. There isn't a shop within 200 miles of me that does VW machine work. A couple of guys with line bore bars, but I want a true machine shop. _________________ My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster |
Posted: Tue Oct 22, 2013 7:13 am Post subject: |
time for a little update had a little time between restoring other peoples things to work on mine no time when you are retired the engine is finished except for a few little items I just need to put the transmission back together started to cut the old panels out of the body and replace them . Brother Ron found me another rear body with little rust I got new inner and outer side panels from the thing shop
Joined: July 02, 2003 Posts: 591 Location: Florida Space Coast
Posted: Wed Oct 23, 2013 11:14 am Post subject: |
Who do you get your repair panels from?
I have this one and I was thinking it was beyond saving.
_________________ 1974 Standard Beetle to Baja Bug
http://picasaweb.google.com/fvee1234/BajaBug02# |
Posted: Wed Oct 23, 2013 2:22 pm Post subject: |
[email protected] wrote: |
the Domeck Brothers use the Thing shop. There is no thing that can not be saved some just take a little more LOVE |
Yarkle Samba Member
Posted: Wed Oct 23, 2013 3:34 pm Post subject: |
yp here in the rusty new england, that'd be called "minor rust".
I once travelled 100 mile one way to look at a subaru brat that had "no rust" . Well, what they meant was the rust had been oshpo'd and painted, but the holes were big enough to throw a dog through. You could see the shocks from inside the bed. _________________ Tilda the Mustard Tigress 1973 Squareback (o'''^'''o)
https://www.thesamba.com/vw/forum/viewtopic.php?t=771024&highlight= |
Posted: Sun Nov 03, 2013 8:22 pm Post subject: |
update cut out the rust on the side on the front so I can replace both side panels. today I went out behind brothers garage and cut out a lower front where it mounts on the frame because mine is completely gone where the big 4 bolts hold on the frame also brother found me a almost rust free rear half maybe this week I can get them cut up to get the sheet metal I need for the front
Posted: Wed Mar 05, 2014 4:44 pm Post subject: |
just a little update I get a little time in between building other peoples things Ron and I just took a couple weeks and put the body back together we replaced both the side panels inner and outer replaced all the rust panels with new or reclaimed sheet metal from other things it took a lot of things to restore this thing but I just could not let it go the body was sandblasted first all dimensions were put back to factory specs, I took the frame to be sandblasted today at least it looks like a thing now. the primer is in red but the paint will be in stock orange a lot to go to get it ready for paint.
