Frankenbeetle Samba Member
Joined: August 08, 2003 Posts: 825 Location: The Great NW, Home of PBR and roses
Posted: Sun Oct 05, 2003 1:43 pm Post subject: Subaru flat 4? |
I heard a number of weeks ago that Subaru still uses flat 4's in their cars. I thought it was crap untill last night in a fit of insomnia I found a site where a guy put a 2.2 water cooled subaru engine in his vanagon.
After a ton of reading and many cups of java I found the place to get the adaptor plates for a subaru-->Beetle engine install.
My questions are;
1) Yes it's a 2.2L engine, and water cooled, does the tranny have to be toughened up?
2) Suspension changes needed?
3) where the HELL do you put the radiator??
4) yeah, I know it's an air cooled board, but a beetle is a beetle is a beetle. _________________ Samba Whipping Boy of '07
Tram wrote: |
That explains it. Jihad supplies ain't cheap!
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Sun Oct 05, 2003 1:49 pm Post subject: |
for a seriously balls-out, kickass subaru conversion in a beetle go to www.volksrods.com and check out reub revhead's work. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
C. Kometz Samba Member
Joined: September 27, 2003 Posts: 30 Location: Calgary, Alberta, Canada
Posted: Sun Oct 05, 2003 2:42 pm Post subject: |
Frankenbeetle,
What were the sites you looked at? Sounds like a cool idea I would like to check out.
-Chris |
Posted: Sun Oct 05, 2003 9:31 pm Post subject: |
C. Kometz wrote: |
Frankenbeetle,
-Chris |
http://www.mcn.org/b/roadcow/convert.html
There ya go. The convo kit is ~500 including all parts needed. Personally I think this is more bloody inexpensive than building an air cooled 2 litre engine.
But that's not what bugs are about is it? _________________ Samba Whipping Boy of '07
Tram wrote: |
Chris181Westy Samba Member
Joined: August 05, 2003 Posts: 148 Location: Michigan, The Third Coast!
Posted: Mon Oct 06, 2003 7:52 pm Post subject: |
I have seen a few Subaru powered sandrails on the dunes and at the sand dragway. They did not look cheap but they were still getting spanked by type1 and type4 powered rails. I have not seen one in a full bodied VW. But I think Aircooled VW engines are still hard to beat for light weight power. |
P-Dub Samba Member
Joined: October 17, 2002 Posts: 1064 Location: Oh, hi!
Mick Mick-n-chips
Joined: April 12, 2003 Posts: 415 Location: RADelaide
Posted: Thu Oct 09, 2003 8:40 pm Post subject: |
You might want to try taking a look at this guys site http://www.ricola.co.uk/ He did a suberu conversion on a speedster kit, ok - not exactly the same as a bug, but he's got a lot of good info on there and its pretty applicable to a bug as its a shared pan / box etc. _________________ https://joeblow.me
Joe Blow Superchargers |
erockinit Samba Member
Joined: December 01, 2007 Posts: 2 Location: HARTSELLE
Posted: Wed Dec 12, 2007 7:55 pm Post subject: |
hey man i have a couple of those subaru motors if you're interested. The easiest rout is o go carburated go to http://www.redlineweber.com/ also try http://www.ramengines.com/ they have some mean mods for the motors i got... |
POWER ON Samba Member
Posted: Wed Dec 12, 2007 11:55 pm Post subject: |
Chris181Westy wrote: |
You need to pay to play but in the long run it will pay off. No more valve and carb adjustments plus 30+ mpg. Not to mention smoking anything on the streets. Check this 65 out.
http://forums.aussieveedubbers.com/viewtopic.php?tid=66118 |
Hotrodvw Samba Member
Posted: Thu Dec 13, 2007 12:05 am Post subject: |
If you do it, you can't hang out here anymore. _________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Dec 13, 2007 1:12 am Post subject: |
Hooray for newbies bumping 4-year old threads without realizing it. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Thingggg Samba Member
Posted: Thu Dec 13, 2007 3:30 pm Post subject: |
Kits / wiring harness plans for stock 2.2 suby.
I have a Legacy motor fogged and setting in the garage and striped out wiring and ecu for a Vanagon someday. The motor is bigger and heavier than T4 maybe not the best for a bug.
http://www.kennedyeng.com/ |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Thu Dec 13, 2007 11:12 pm Post subject: |
Max Welton wrote: |
Towel Rail wrote: |
Hooray for newbies bumping 4-year old threads without realizing it. |
At least they used the search!
Max |
Touchee, salesman. _________________ 1974 Thing -- under the knife
50&60 Samba Member
Joined: February 13, 2007 Posts: 107 Location: ireland
Posted: Fri Dec 14, 2007 9:46 pm Post subject: |
check out what trevor is building here in ireland......impressive
www.veewrx.com |
maxco Samba Member
Joined: April 08, 2012 Posts: 3 Location: Lakeland Fl
Posted: Thu Apr 11, 2013 4:56 pm Post subject: |
Hi there ray here of rays vintage Volkswagen just finishing a 1970 bug with a Subaru 2.2 conversion as soon as I get some pix I will show you how its done and as far as the trans it will hold up if you don't get to rough with it thanks take care Ray |
75smith Samba Member
Posted: Thu Apr 11, 2013 5:00 pm Post subject: |
Towel Rail wrote: |
Max Welton wrote: |
Towel Rail wrote: |
Hooray for newbies bumping 5-year old threads without realizing it. |
Max |
Touchee, salesman. |
and again.... _________________ My 1975 Beetle Build Updated 8-21-12
My engine build |
slalombuggy Samba Member
Posted: Thu Apr 11, 2013 5:02 pm Post subject: |
brad |
MidWesty79 Samba Member
Joined: October 19, 2011 Posts: 485 Location: Milwaukee Wisconsin, US
Posted: Thu Apr 11, 2013 5:12 pm Post subject: |
This is like reading a time warp... I was incredibly surprised that someone with as many posts as Frankenbeetle had never heard of a sube conversion... I then saw the date... yup... welcome newb!! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Crankey Samba Member
Posted: Thu Apr 11, 2013 8:31 pm Post subject: |
they make 6's too....
