what is the difference?
Forum Index -> Performance - Engines/Transmissions Share: Facebook Twitter
schultzy77
schultzy77 is offline
PostPosted: Sun Nov 18, 2012 10:43 am    Post subject: what is the difference? Reply with quote
i am looking to rebuild my 1600dp. i really want to split the cases and install a new performance crankshaft and a cam new lifters the whole thing but i just can not find what would work with the 88mm x 69-76mm Hypereutectic Slip-In Piston & Cylinder Set, AA Brand, Type 1. any info will help.. thanks
BTW whats is the difference between these: 88mm x 69-76mm Hypereutectic Slip-In Piston & Cylinder Set, AA Brand, Type 1 and 1003 Big Bore Kits - 87mm High Performance from CB performance? any info will help
thanks first time builder.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Nov 18, 2012 10:45 am    Post subject: Re: what is the difference? Reply with quote
88mm is 1mm larger than 87mm.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $25,000 raised in 2016, hoping for the same in 2017
schultzy77
PostPosted: Sun Nov 18, 2012 11:06 am    Post subject: Reply with quote
witch is better to buy?
Mr. 010
Glenn is offline
PostPosted: Sun Nov 18, 2012 11:07 am    Post subject: Reply with quote
I'm not a fan of slip in 88s due to the thin walls.
Glenn
DarthWeber
DarthWeber is offline
PostPosted: Sun Nov 18, 2012 11:43 am    Post subject: Re: what is the difference? Reply with quote
You need to do some serious reading Shultzy. You can't, or shouldn't, just dive into an engine build. I suggest you take full advantage of the tech articles John has written on his web site AirCooled.Net. There are also tech articles available on CalLook.Com. You should also read Tom Wilson's Rebuilding Your VW Engine book and, of course, you should have the appropriate VW Bentley Manual for your year VW.
If you ask here, without having some background knowledge on VW engine combos, all you'll get are 1,000 different opinions (many good suggestions) but you won't know which way to go. The more you read and learn, the more apparent it will become that there are certain combos which are more common than others. You'll know which ones to avoid and which ones "work".
Mitey62 wrote:
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on.
RockCrusher wrote:
JB weld the case halves....that'll keep the fretting to a minimum. Laughing
schultzy77
PostPosted: Sun Nov 18, 2012 2:18 pm    Post subject: Reply with quote
i have all those books and have been doing alot of reading thanks just wondering if anyone has anymore info on what a good bottom end (cam/crankshaft size rod size) would be for this type of build (if any at all) and also why is there a big price difference in- CB's 87mm"High Performance" Big Bore Kit and aircooled.net 88 kit?
DarthWeber
PostPosted: Sun Nov 18, 2012 2:44 pm    Post subject: Reply with quote
OK, if you are building, say, an 1849 - you didn't say what you are considering - then I'd choose a DPR 76mm crank and flywheel, 5.325" H beam rods, a set of machine in 88's or a set of the AC.N turned down 88's. They are machine in 88's with the cylinder bases turned down to fit the 85.5 holes. I'd run an Engle W110 or Web 163 cam.
I wouldn't even consider 87's with the availability of the turned down 88's.
Mr. 010
Glenn is offline
PostPosted: Sun Nov 18, 2012 2:48 pm    Post subject: Reply with quote
Darth,
sounds like he wants a "no machine" build so the 88s are no good since you have to machine the heads.
Glenn
schultzy77
PostPosted: Sun Nov 18, 2012 2:53 pm    Post subject: Reply with quote
trying to build a no machine build
DarthWeber
PostPosted: Sun Nov 18, 2012 2:55 pm    Post subject: Reply with quote
Dang, and I had my sledge hammer out getting ready to beat some sense into him. Crying or Very sad
OK, at a list price of $340, the CB 87's sound like they are forged pistons although it doesn't actually say that in the ad. That's about the difference between forged vs. cast or hypereutectic pistons.
schultzy77
PostPosted: Sun Nov 18, 2012 2:57 pm    Post subject: Reply with quote
would like to build as much power/torque with out machining anything any ideas
NJ John
NJ John is offline
PostPosted: Sun Nov 18, 2012 3:02 pm    Post subject: Reply with quote
85.5 p/c
www.thesamba.com/vw/forum/viewtopic.php?t=615587
My chop project thread
http://www.cafepress.com/bugracing "MY OTHER CAR IS A DUNE BUGGY" stickers & more..
vwracerdave
vwracerdave is offline
PostPosted: Sun Nov 18, 2012 3:11 pm    Post subject: Reply with quote
Why are you against machining?
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
modok
modok is offline
PostPosted: Sun Nov 18, 2012 3:16 pm    Post subject: Reply with quote
Turbo
Get a job hippie Laughing
ok, first off you can't re-build an engine without machine work, unless there is nothing major wrong with it to begin with.
When you re-build one of these things USUALLY you re-surface the heads and case anyway, because the cylinders SINK into them. If you get a new case it's a shame to bore it out right off the bat but you know what? the decks aren't even on a lot of them!
SLIP IN CYLINDERS are a waste of time. I'd rather throw a 74 stroke crank in there, you'll FEEL that!
schultzy77
PostPosted: Sun Nov 18, 2012 3:35 pm    Post subject: Reply with quote
its not me the guy that owns the machine shop around here hates vw's so he charges a lot of money he wants $850 to machine my cases i told him i could buy new ones for that price he said i know
schultzy77
PostPosted: Sun Nov 18, 2012 3:52 pm    Post subject: Reply with quote
only rebuilding because i want more power. by the sounds of things i should just buy new cases and build a bigger engine thanks for all the info guys
modok
modok is offline
PostPosted: Sun Nov 18, 2012 4:06 pm    Post subject: Reply with quote
Whoa, that is crazy. Check the classifieds, I bet you can buy a decent engine case ready to go for half that.
ONEBADBUG
ONEBADBUG is offline
PostPosted: Sun Nov 18, 2012 4:07 pm    Post subject: Reply with quote
You could ship your parts to a good machine shop. The odds of your old case needing no work is slim.
[email protected]
john@aircooled.net is offline
PostPosted: Sun Nov 18, 2012 5:24 pm    Post subject: Reply with quote
IF you are buying new heads, you can order them bored to 92mm, allowing you to use the thick wall 88s usable without machining the case. It all depends on what parts you are going to re-use.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
schultzy77
PostPosted: Sun Nov 18, 2012 5:56 pm    Post subject: Reply with quote
thanks John, looking forward to talking to someone a aircooled.net i will be ordering new heads
Reply to topic    Forum Index -> Performance - Engines/Transmissions All times are Mountain Standard Time/Pacific Daylight Savings Time
