RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Sat Nov 24, 2012 5:58 pm Post subject: |
Yes, so the illustration is probably correct for 53-55 (including Single Cabs)
With 50-52 maybe having no Holes or Dimples?
Or are there still the Holes over the B-post/semaphore jacking point? _________________ -StockRocks- |
EverettB Administrator
Joined: April 11, 2000 Posts: 69801 Location: Phoenix Metro
Posted: Sun Nov 25, 2012 10:20 am Post subject: |
RockStock wrote: |
EverettB wrote: |
Unless Barndoors are different than later Buses, I assume those should have the typical rubber plugs in them too.
They are missing from most Buses since they harden up and snap off. |
what do they look like? |
Example from Wolfsburg West:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=n200223
In the US, they sell these plugs at hardware stores too.
I don't see this part listed in my '55 Parts Book but I also don't see it in the later parts books. I know for a fact some or all post-Barndoors Buses had them in place. My '63 Bus had a few left in place when I bought it and I have seen them on numerous other 60s Buses. _________________ How to Post Photos
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sun Nov 25, 2012 5:09 pm Post subject: |
EverettB wrote: |
gatorwyatt wrote: |
Question?
Does a barndoor single cab have the same corresponding drain holes and drain dimples? The dimples being on the side with treasure chest rocker? |
My ex-'54 Single Cab has the dimples.
I don't see any drain holes but I don't have any nice direct photos of that area.
Pics if you want to look through them:
http://www.thesamba.com/vw/scrapbook/54truck/photos.php
http://www.thesamba.com/vw/scrapbook/54truck/photos2.php
gatorwyatt wrote: |
What is the size of hole in the pillar? You can use a drill bit to answer... |
I can measure if needed but the holes on my Deluxe are not super clean looking so I don't know if they are unmolested. |
Thanks!
It appears the long wall (non treasure chest) side has dimples? Am I seeing that correct? _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Posted: Sun Nov 25, 2012 9:59 pm Post subject: |
gatorwyatt wrote: |
EverettB wrote: |
gatorwyatt wrote: |
Question?
gatorwyatt wrote: |
Thanks!
It appears the long wall (non treasure chest) side has dimples? Am I seeing that correct? |
It does sort of look that way but I am not 100% sure that side is unmodified. _________________ How to Post Photos
Fonz Samba Member
Joined: January 17, 2003 Posts: 325 Location: UK / Australia
Posted: Mon Nov 26, 2012 9:03 am Post subject: |
Finally found one of the pics I was looking for. Everett's photo of Mark Merz' '55 standard. Has this been repaired? I can't see any dimples.
_________________ www.melburgluft.com |
Fonz Samba Member
Posted: Mon Nov 26, 2012 9:41 am Post subject: |
Aha!
Sneaky beige paint. _________________ www.melburgluft.com |
BeaterBarndoor Samba Member
Joined: December 15, 2000 Posts: 824 Location: North Carolina
barndoormambo Samba Member
Joined: April 25, 2005 Posts: 443 Location: East Coast, Homeland
Posted: Thu Nov 29, 2012 11:47 am Post subject: |
..sorry to say i believe that Beltek had the Sill replaced , while Paul( Bus Barn) had it..
here's a pic from Vincent's time ( pre-2005)
and one from my ownership in 2010
..you can see that it appears to be both holed & distorted in the top pic, but regenerated in the bottom one.. _________________ ....just cause you don't see it, doesn't mean it isn't there!.... |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Sun Mar 24, 2013 4:12 pm Post subject: |
Does anyone have a pic of the hornbecker 52 deluxe sills?
I believe it's a pristine untouched 52 right?
So should answer the question if 52s have cargo dimples or holes. |
Posted: Mon Mar 25, 2013 10:34 am Post subject: |
Don't really know how genuine this is with the artistic touch ups that often happened. But in the ambulance and the pickup brochures in the archives it seems 52 didn't have dimples on either side like 51s
but possibly B pillar holes?
CaLiBus Samba Member
Posted: Thu Jan 16, 2014 10:26 am Post subject: |
EverettB wrote: |
Unless Barndoors are different than later Buses, I assume those should have the typical rubber plugs in them too. |
I have these same drain holes on my post Barndoor july/55 .
Posted: Thu Jan 16, 2014 10:55 am Post subject: |
Dimples on the long panel started with the new body style march 55. |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1214 Location: Eerie PA
Posted: Tue Jan 21, 2014 8:55 am Post subject: |
Does anyone have an original factory barn door era service manual? Did they exist? They have very detailed pictures, at least my later one does, that shows the rockers in clear detail.
Maybe could clear this question up as best as it can be. It's almost like archeology at this point. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Sat May 02, 2015 4:28 pm Post subject: Barndoor Truck Rocker Dimples |
I'm trying to figure out rockers on a single cab... Does anyone know when drain dimples started on the treasure chest rocker and B-pillars for a truck? Specifically interested in '53 but any info would help. I know Everett posted a link to pics further up the page and I've searched a bit but can't find anything clear. Thanks. _________________ David S |
Wolfsburg Classics Banned
Joined: October 17, 2003 Posts: 326 Location: Christchurch,New Zealand.
Posted: Sat May 02, 2015 6:25 pm Post subject: |
David.
I have a NOS Barndoor Single Cab Left Hand B pillar here and that has the dimple but no drain hole.
Can send you a pic if need be.
Tony. |
Posted: Mon Oct 26, 2015 5:59 am Post subject: |
No drain dimples on the longside sill
Or on a 53, believed to be original
