kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Fri Nov 23, 2012 10:16 pm Post subject: Hub Cap Clips... Pound Them Rivets! |
For those who have not done the procedure, this thread is to give the basic concept of various methods used.
Tools/Parts needed:
Rivet bucking bar: Mounts into vise. One can be home-made from a large bolt with the appropriate clip reliefs cut into it with an angle grinder.
Hubcap clips: My buses and I prefer genuine, experienced clips and will drill or cold-chisel them from donor wheels. Common vendors have rookie/fake/New Kids On The Block clips available. Discuss this with your bus to ensure your maintenance practices are in sync and bring harmony instead of mechanical resentment.
Rivets: Find NOS rivets or reproduction. In a pinch, you can buck a round head screw of the right diameter.
Big F'n Hammer!
Post your results!
In this image, the special and commonly available hubcap clip bucking bar has one rivet holding one fake hubcap clip. Below it, many fake hubcap clips abound. Notice the correct size reproduction rivets:
Here I'm smashing/bucking the back side of the special rivet against the special hubcap clip bucking bar mounted in the shop vise -precarious wheel holding required:
Here is a Beetle wheel with an early "Crow's Foot" bus clip bucked onto it (notice the little tab on the hub-side). -finished product:
Video from later in this thread
D-train Samba Member
Posted: Sat Nov 24, 2012 1:26 am Post subject: |
home made rivet holder
bang bang bang with a ball pein hammer an voila!
_________________ shiny paint doesnt make it worth any more |
DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Sat Nov 24, 2012 1:40 am Post subject: |
I wish i had gotten some pics of me when I did this procedure lol. I was squatting on the tire with the rim balanced on the head of a sledge hammer, and a piece of rebar for a rivet holder. |
Posted: Sat Nov 24, 2012 10:01 am Post subject: |
D-train wrote: |
Bang bang bang with a ball pein hammer an voila!
Brilliant! Gotta' love handy solutions.
DannoT wrote: |
Someone posted a complete 5-rivet wheel clip bucker they made and I can't seem to find it. THAT was ingenious! Would hope someone could post that here... |
Thomas Pedigo Samba Member
Joined: July 03, 2010 Posts: 1052 Location: Nine Mile Falls/Sunset Bay,WA
Posted: Sat Nov 24, 2012 12:30 pm Post subject: |
What an absolutely riveting topic... _________________ Defying conventional wisdom since 1970 |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Sat Nov 24, 2012 12:39 pm Post subject: |
Tip: If you use a ballpeen hammer the ball side you can control where direction you move the material. A large hammer is nice to start it, but the ballpeen helps fine tune where the material is actually going. Learn that from an old sheet metal guy. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
dreadnotmusic Samba Member
Joined: March 04, 2003 Posts: 880 Location: Guam, USA
Posted: Sat Nov 24, 2012 6:33 pm Post subject: |
I did mine on the floor to avoid the whole wheel balancing on the vise shuffle. A 10.9 grade bolt worked great and earned a permanent spot in my drawer of homemade tools.
_________________ 66 Riviera |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Sat Nov 24, 2012 7:04 pm Post subject: |
Hi all,
I have the rivet "buck" from WW and was thinking about using a round punch with it's conical, sharp point set dead center on the flat surface of the rivet and striking the punch to deform the rivet in all directions away from center to further smash the rivet to the rim. Anyone do it that way, or is mashing the rivet head directly with a sledge hammer sufficient? Your photos?
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Sat Nov 24, 2012 7:26 pm Post subject: |
BulliBill wrote: |
Hi all,
Bill |
As said a few posts back
DubStyle wrote: |
Tip: If you use a ballpeen hammer the ball side you can control where direction you move the material. A large hammer is nice to start it, but the ballpeen helps fine tune where the material is actually going. Learn that from an old sheet metal guy. |
exciter Samba Member
Posted: Sat Nov 24, 2012 7:34 pm Post subject: |
I buck my rivets from the ball side. I install a large peice of round stock in my vise to rest the backside of the rivet on. I then use my air chissel gun. I bought a rivet bucking bit from my snap on gut that has a dimple in the middle of the bit. I just turn my air gun down on low and tap the trigger a couple times and shes bucked!! _________________ Joe
419-236-9781 |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Sat Nov 24, 2012 7:37 pm Post subject: |
I have a large punch that I rounded off to flare the rivet. It works great and no needed for the ball peen. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Sat Nov 24, 2012 8:00 pm Post subject: |
I know it is not stock, but you can skip all the riveting and hammering etc. A flat head machine screw inserted from the back side of the rim, a lock washer, some thread lock, and a nut. Each clip takes about 2 minutes (or less) and, in my experience over the past 3 years, is permanent. Tools required: phillips screwdriver and small end wrench. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
65Nsqback Samba Member
Joined: September 17, 2004 Posts: 1256 Location: Grantsville UT
Posted: Sat Nov 24, 2012 8:22 pm Post subject: |
OB Bus wrote: |
I know it is not stock, but you can skip all the riveting and hammering etc. A flat head machine screw inserted from the back side of the rim, a lock washer, some thread lock, and a nut. Each clip takes about 2 minutes (or less) and, in my experience over the past 3 years, is permanent. Tools required: phillips screwdriver and small end wrench. |
x2 I smashed my hand ONCE trying to do these damn rivets and that was enoght for me I did the sams thing nut and bolts ....oh ya and when the clips brake AGAIN because they WILL I will just undo the nut and replace it
But this would be the way to go if you want the OG rivet look _________________ Wow look at that THAT'S A "SHOW CAR"!!
you can't be something your not...be your self by your self stay away from me
__________________________________
I'm Trying to help you.......but you don't hear me... |
type241 Samba Member
Joined: June 02, 2006 Posts: 972 Location: MOSES LAKE, WA
Posted: Tue Nov 27, 2012 4:46 pm Post subject: Clip Fixture |
Here is my fixture for holding wheel, clip, and rivet all at once(handsfree).
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Tue Nov 27, 2012 6:24 pm Post subject: |
BulliBill wrote: |
Hi all,
Bill |
Large hammer to get it started. Then ball peen hammer to spread it more evenly. I still had the clips a little on the loose side, so my final was to put a piece of metal tight against the backside of the rivet and hammer the "buck" a few times, tightened it the rest of the way. _________________ 63 Double Cab http://www.thesamba.com/vw/forum/viewtopic.php?t=443823&highlight=deanos
66 Bus Click to view image - SOLD
73 Thing http://www.thesamba.com/vw/forum/viewtopic.php?p=8111202#8111202
70 BusClick to view image |
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1561 Location: stoughton, WI
Posted: Tue Nov 27, 2012 7:05 pm Post subject: Re: Clip Fixture |
Awesome! I am copying this.
type241 wrote: |
_________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
Long-roofs Samba Member
Joined: March 20, 2002 Posts: 2295 Location: Millwood, Wa
Posted: Tue Nov 27, 2012 7:55 pm Post subject: |
I've been using this since the '90's, works great.
_________________ ---
I have been on a treadmill drinking vodka, maybe more than once.
"No, I do not own a bleepin' leaf blower"
Posted: Fri Feb 15, 2013 7:57 pm Post subject: |
I am having a bunch of wheels P/Ced so I went ahead and made the bucking jig, like I said I would! I smash the rivets with a drift and big hammer.
Works great! _________________ Josh The Bus Guy formerly known as JOGR
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sat Feb 16, 2013 7:52 pm Post subject: |
I made a jig a few years back, but now I just use the nut and bolt method mentioned earlier. I am no longer a purist. _________________ nothing |
