My daily driver baja bug build
Page: 1, 2, 3, 4, 5  Next
Bad_chopper
Bad_chopper is offline
PostPosted: Tue Nov 27, 2012 8:03 am    Post subject: My daily driver baja bug build Reply with quote
My name is Tony, live in Portland Oregon. Little about me I had a 69 Baja that I sold a few years back it was in project stages and I grew tired of working on it. Sold it and bought a jeep dumped a ton of money in it all along thinking " if I wouldst put all this money into that bug, if have the baddest bug in oregon". Well the jeep is pretty much done and I'm ready for a new project.
I bought a 69 that had already been bajad, turned out engine is rusted, brakes rusted, fuel tank rusted, pans OK, ended up needing more work then I expected.
Once I figure out how to post pics I invite you all to fallow my build, criticise, and give advice.
Till next time.[/img][/list]
Jon65
Jon65 is offline
PostPosted: Tue Nov 27, 2012 3:12 pm    Post subject: Reply with quote
Use this link to find out how to post pics.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6
Bad_chopper
PostPosted: Wed Nov 28, 2012 6:22 am    Post subject: Reply with quote
. OK I think I figured it out. This was my first Baja, bought it while deployed, drove it a bit when I got out of the military. Ended up selling it to buy a jeep and build it. Now that I know what to do to post I will upload some more photos later this morn.
Bad_chopper
PostPosted: Wed Nov 28, 2012 12:28 pm    Post subject: Reply with quote
As promised here are some pics.
Shortly after bringing it home, drivers door stuck (not the linkage like we thought)
Pads torn off shoes lots more wish I would have dug a little better.
Rusty valvetrain
Rebuilt and cut heads
Interior torn out. Was going to raptor line but found a couple small rust holes. Sprayed withospho going to just paint it black
Bad_chopper
PostPosted: Wed Nov 28, 2012 12:39 pm    Post subject: Reply with quote
Rest of the pics I took today nothing special
It has a pretty cool look about 17" of ground clearance 33's in the back and 31's up front.
I think its a thing front beam I was told that its better, why?
Bad_chopper
PostPosted: Wed Nov 28, 2012 1:32 pm    Post subject: Reply with quote
Thought I would throw in my last project. No I'm not expecting the Baja to do this.
Jon65
Jon65 is offline
PostPosted: Wed Nov 28, 2012 2:36 pm    Post subject: Reply with quote
Too bad. That would be awesome. Twisted Evil
Very nice project baja. Cool
Hamsterben
Hamsterben is offline
PostPosted: Wed Nov 28, 2012 3:28 pm    Post subject: Reply with quote
Your beam is from a vw thing. It is better because the balljoints both face down. It is reinforced from the factory and can take more punishment than a stock bug beam. The trailing arms are also longer giving more lift.
thext94
thext94 is offline
PostPosted: Wed Nov 28, 2012 3:29 pm    Post subject: Reply with quote
Car has an awesome stance! Cool start
chubby53
chubby53 is offline
PostPosted: Wed Nov 28, 2012 10:28 pm    Post subject: Reply with quote
looks like a great start. have fun with it. nice to see another guy from the northwest.
My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100
Bad_chopper
PostPosted: Wed Nov 28, 2012 11:08 pm    Post subject: Reply with quote
Thanks for the explanation and comments. I'm looking at having it on the road by the beginning of the year. Not going to paint it just cover some bare metal. Main issue is building the engine. Its a dual port 1776 single Weber c35 cam, has a built bug tyranny with a an aftermarket case ( can't remember brand)
Looking forward to getting it on the road. Hopefully I can remember to take pics of my progress.
ekacpuc
ekacpuc is offline
PostPosted: Wed Nov 28, 2012 11:55 pm    Post subject: Reply with quote
From that pic how could you tell it's a thing beam? Only way I really know is to look for a gusset on the shock tower... I thing the body is in the way, so the bug guys add a little gusset. I just see thing spindles on what's likely a vw beam.. Still an improvement, also the trailing arm tubing is of thicker material then the beetle's. Also the thing spindles give a 3" lift because the big stud is lower then a bug's. Just did the same to mine.
Nice bug and jeep, jeep reminds me of my old CJ5
Bad_chopper
PostPosted: Thu Nov 29, 2012 2:07 am    Post subject: Reply with quote
The lower link ballpoint sits above the mount so when the suspension cycles the lower mount pushes int the balljoint rather then pull the balljoint up. Beetle nut on top thing nut on bottom. I understand it that way at least.
GREG.M
GREG.M is offline
PostPosted: Thu Nov 29, 2012 12:52 pm    Post subject: Reply with quote
you need to post your picks thru the samba so we can see something beside red x's
"Patina" a cheap bastards codeword for a shitty looking rustbucket
Bad_chopper
PostPosted: Thu Nov 29, 2012 1:51 pm    Post subject: Reply with quote
OK. It doesn't accept pics off my phone so I'll have to try it from my computer later.
my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267
Bad_chopper
PostPosted: Sat Dec 08, 2012 6:55 pm    Post subject: Reply with quote
[img]
Started putting the engine together today. Missed one step and noticed it as I was admiring my work. Forgot the woodrift key. Hope I can get that in its little groove. Going to put a heater in the car tonight. Get to wire wheel the interior tommarow[/img]
Bad_chopper
PostPosted: Sun Dec 09, 2012 10:19 am    Post subject: Reply with quote
Well for some reason I am unable to upload my photos to the samba. They are JPEG format but when I try and upload them it tells my file type not supported. So for those of you that can't see the pics sorry
Bad_chopper
PostPosted: Tue Dec 11, 2012 11:00 pm    Post subject: Reply with quote
I was putting the jug studs in and used the same goop on the threads that I used on the case half's. The studs never set up hard so I removed them cleaned the threads an used blue locktight. Do any of you see issues with that?
Bad_chopper
PostPosted: Mon Dec 31, 2012 4:34 pm    Post subject: Reply with quote
cc'd the heads, deck hight taken, im right about 8.4 for the compression ratio. 1776 dual port, c35 cam, all balanced. single 32/36 weber. exhaust is going to be normal baja type but with heater tubes, and a 40 series flow master i have laying around. been a slower build then i like, but its been fun to let my girlfriends son be involved.
interior has been por 15'd new headlights and buckets, new to me gas tank, have braided stainless brake lines, need to run new hard lines, install new brake parts. little paint on the interior put the doors back together should be able to be driving soon. pics to come.
Bad_chopper
PostPosted: Tue Jan 01, 2013 5:13 pm    Post subject: Reply with quote
Well some what good news for me today, I drained the transmission and there was no water contamination or metal pieces. One thing out of the way. Any one give me a heads up on how to tell ring and pinion without taking it apart and without knowing transmission gear ratios.
Page 1 of 5
