Zach Thomas Samba Member
Joined: August 12, 2008 Posts: 929 Location: Lake Stevens, WA
Posted: Sat Mar 01, 2014 3:21 am Post subject: |
They look good! It's too bad they didn't widen them as much as you wanted. _________________ 62 Rag - a little crusty |
iaccy Samba Member
Lucky Lager Samba Member
Posted: Thu Mar 06, 2014 2:22 pm Post subject: |
iaccy wrote: |
Where are you guys getting these widened? I got in touch with a guy over a month ago, can't get in touch with him now, won't return calls…very annoying. |
Talk to Joe
http://www.thesamba.com/vw/classifieds/detail.php?id=1172589 _________________ In the wild, health care is, Ow, I hurt my leg. I can't run. A lion eats me. I'm dead. |
ballt957 Samba Member
Joined: January 08, 2012 Posts: 14 Location: Greer, SC
Posted: Fri Mar 07, 2014 4:10 pm Post subject: |
What kind of backspacing are yall having to run with these? in running jer*fab 4in drop plates in the back of my 65. |
theastronaut Samba Member
Joined: November 19, 2007 Posts: 1631 Location: Anderson, SC
Posted: Sat Mar 08, 2014 3:02 pm Post subject: |
Another I found on Instagram, username is "plainpaul". No specs found except 135's on the front and the rear wheels are 8".
_________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
-Sir Henry Royce, co-founder of Rolls-Royce
'64 Beetle Sunroof OG Bahama Blue
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Sat Mar 08, 2014 3:09 pm Post subject: |
Zach Thomas wrote: |
Thank you for the info theastronaut! Those non-stepped lips look very nice, would love to see them with tires mounted and on a car! |
Here they are on my buddy Sam's '65.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
iaccy Samba Member
Posted: Sun Mar 09, 2014 10:04 am Post subject: |
iaccy wrote: |
theastronaut wrote: |
I've asked him once or twice and he doesn't share much information as far as rear tire size, etc. |
Right. I looked through all the comments to see if he posted sizes and that's all I found. Anyone at a show could look at the sidewalls and see for themselves; I don't get why some guys are so secretive about their setup. _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
zombie Samba Member
Joined: June 17, 2004 Posts: 1177 Location: Pothole City, CT
Posted: Sun Mar 09, 2014 11:15 am Post subject: |
I also asked that dude about his setup and didn't get a response.
Worth noting, those aren't the regular 135s on the front. They're some euro low profile 135s. _________________ I run two fuel filters in my engine bay. |
Posted: Wed Mar 12, 2014 1:57 am Post subject: |
[/URL] |
Turned out great!
And thanks for sharing the other pic of the 8's on Mr Secret Setups car, those look sweet. If I ever stop spending on my FC RX7 and my WRX I'll get a set of 8s for the ragtop My goal is 8s in the rear and 6s up front with the closest to stock width beam I can manage. I'll shorten the frame head enough to center the wheels so the front tires can rub up top like they're supposed to _________________ 62 Rag - a little crusty |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Wed Mar 12, 2014 6:52 pm Post subject: |
I 'just' had my 7.5" wide rear smoothies off and was measuring things figuring out width and back space for something else. IF those are 8" wide and he tucks like that:
You can see he has the tire stretched to fit the rim, probably something better suited for a 6-7" rim like a 205 wide tire. A wider tire with a straight sidewall would hit the fender lip, you can see it in the pic. He is surely running short early axles. Later axles need more backspace and don't look so nice and deep. My wheels at 7.5" wide have just over 3.5" backspace, not quite 3.75". I can fit a finger between the wheel and spring plate, and a pencil between the 225/55/15. I bet he is running the rim right next to the spring plate, with 3.75" back space, and has the tires stretched like that so they don't bulge and hit the spring plate.
I personally like to see a tire fit the rim well, and then fit the car well. |
durfeec Samba Member
Posted: Wed Mar 12, 2014 7:07 pm Post subject: |
A 205 wont stretch on a 8" rim. That is most likely a 195. The fronts possibly a 165/50-15 or similar. A 225 is a bit of overkill for a 7.5" rim. You could get away with a 205 or 215 and have a ton more space in the rear. _________________ 1960 Bus Panel/Camper |
hewica8 Samba Member
Posted: Wed Mar 12, 2014 7:09 pm Post subject: |
Long time lurker, but finally have some results to post up. This thread inspired me to go widened smoothies. The rears are 6" with 205/70r15s lowered one inner spline. Front is standard adjustable beam, drop spindles, with stock smoothies and 145r15s. I still have some work to do before its on the road, but the look is finalized.
Posted: Wed Mar 12, 2014 7:23 pm Post subject: |
Turned out great!
And thanks for sharing the other pic of the 8's on Mr Secret Setups car, those look sweet. If I ever stop spending on my FC RX7 and my WRX I'll get a set of 8s for the ragtop My goal is 8s in the rear and 6s up front with the closest to stock width beam I can manage. I'll shorten the frame head enough to center the wheels so the front tires can rub up top like they're supposed to |
Funny (to me atleast) that guys are ditching the super-narrowed beams and running wider wheels that fill out the fenderwells now. I have 5.5's Mangels and 195/50s on a 3" beam that barely rub like you're talking about, up top. Way better than the old 4.5's and 145s. Plenty of room for 6" up front (or move the backspacing 1/2") and run narrower tires for less of a tucked look.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
Posted: Sat Mar 15, 2014 6:28 pm Post subject: |
Finally finished my set of 4's and 5.5's. Hoping to eventually get another pair banded to 7" for the rear and move the 5.5's to the front.
Smoothed the letters of the tires so the portawalls will lay flat. Smoothie wheels need smoothie tires.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sat Mar 15, 2014 7:18 pm Post subject: |
Awesome, can't wait t see them mounted on the bug _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sun Mar 16, 2014 1:58 am Post subject: |
Wheels look great astronaut! And yeah, I've never been a fan of the extremely narrowed front beams. Mine is a 3 inch with chrome 5.5 inch stockers. I need to find a stock beam eventually now
I would also love it if we had a good option for stock style smoothies in a 16 inch. Would look a little more subtle than the 17s and lots of tire options. _________________ 62 Rag - a little crusty |
Posted: Sun Mar 16, 2014 6:58 am Post subject: |
zuggbug wrote: |
Awesome, can't wait t see them mounted on the bug |
Will send you pics later this week once they're mounted.
I would also love it if we had a good option for stock style smoothies in a 16 inch. Would look a little more subtle than the 17s and lots of tire options. |
Thanks! I'm restoring a '55 International pickup that has 16's with barrels that would fit smoothie centers with about a 1/16" thick "shim" to take up the difference in the ID vs the OD of the smoothies (Int wheel is about 1/8" bigger ID). They have a really cool 45* step in the lip, much like stepped lips for 3 piece wheels. They're only 5" wide though, would have to have the rears banded.
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Mar 16, 2014 9:32 am Post subject: |
I'm an IH fan myself and have a 1979 Scout. Do you have and pics and are you on the Binder Planet forums? _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Sun Mar 16, 2014 10:20 am Post subject: |
sixfootdan wrote: |
I'm an IH fan myself and have a 1979 Scout. Do you have and pics and are you on the Binder Planet forums? |
The original build thread is here, it's copy/pasted on Binder Planet and OldIHC as well.
http://67-72chevytrucks.com/vboard/showthread.php?t=509519 _________________ Strive for perfection in everything. Take the best that exist and make it better. If it doesn't exist, create it. Accept nothing nearly right or good enough."
'63 Beetle Vert
'66 Beetle
'88 Festiva L
'89 Festiva L
'64 Chevy C10
'66 Chevy C10 |
