58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sat Feb 23, 2013 3:39 pm Post subject: |
well, life has gotten in the way again......looks like the engine project will be on hold for a bit _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
58Dub Samba Member
Posted: Wed Mar 12, 2014 3:03 pm Post subject: |
Good news...the project is alive again....although with some changes.
The 1.9 is being sidelined...and going with a 2.1 case. Spoke with Rocky Jennings and there seems to be a few advantages of the 2.1 over the 1.9. So the plan is to use thick wall 92 cyls with JE pistons, have the crank ground to a 80mm stroke, a turbo from Shag and some E85 injection. Got my set of 5.5 CB H beams today.... Cant wait to start pulling this all together.
58Dub Samba Member
Posted: Mon Mar 17, 2014 3:39 pm Post subject: |
IT was great to get a visual update from Rocky today. Here is a pic of the waterjacket milled off, head stud pattern drilled and plugged and now ready to have the type 1 pattern drilled.
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Mon Mar 17, 2014 4:16 pm Post subject: |
keep this as detailed as possible, want to know exactly what goes into this conversion! _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
58Dub Samba Member
Posted: Mon Mar 17, 2014 4:56 pm Post subject: |
VWporscheGT3 wrote: |
keep this as detailed as possible, want to know exactly what goes into this conversion! |
Rocky has a lot of pics of the process on his website. http://www.rockyjennings.com/
Ive been waiting to do this for a few years....so Im pretty stoked to see it in progress.
58Dub Samba Member
Posted: Tue Mar 18, 2014 11:02 am Post subject: |
always good to see freshly machined parts
58Dub Samba Member
Posted: Tue Mar 25, 2014 4:37 am Post subject: |
Another minor change....I ordered a set of the 94mm squishy pistons from Aircooled.net.... so that will make the engine a 2221.
Hope the cam and turbo will be delivered today. _________________ 58 Beetle (now just a pile of parts in the corner)
58Dub Samba Member
Posted: Tue Mar 25, 2014 4:39 pm Post subject: |
a few more parts showed up today.
58Dub Samba Member
Posted: Tue Jun 03, 2014 2:59 pm Post subject: |
progress is slow but steady. Got a message from Rocky, sounds like my parts are ready to come home! now i need to figure out for sure what im going to do for heads.
58Dub Samba Member
Posted: Tue Jun 24, 2014 5:22 pm Post subject: |
Got the rest of my parts back. Looks good. Need to collect a few more parts and it will be time for assembly. The engine case work was done by Rocky Jennings and the crank was done by DPR.
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Wed Jun 25, 2014 6:42 am Post subject: |
Looks Good!
Should be a nice engine.
What cam / lifters are you using? |
58Dub Samba Member
Posted: Wed Jun 25, 2014 8:44 am Post subject: |
Thanks
I got the cam and lifters from Shag when I got the Turbo
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Wed Jun 25, 2014 8:51 am Post subject: |
Looks great!
I really like the modified oil pick-up that Rocky provides. Had I known about that, I'd probably never have dry-sumped my engine! _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Anvil Samba Member
Joined: September 28, 2009 Posts: 248 Location: Golden, Colorado
Posted: Wed Jun 25, 2014 10:00 am Post subject: |
Maybe a stupid question, but what is the advantage of using a WBX case for an air-cooled engine over the aftermarket aluminum cases that don't require all the mods? _________________ A man with any character at all must have enemies and places he is not welcome—in the end we are not only defined by our friends, but those aligned against us. |
58Dub Samba Member
Posted: Wed Jun 25, 2014 10:07 am Post subject: |
My understanding is its stronger, has a wider case deck, improved thrust brg config, better flywheel attachment, larger oil sump and has built in provision for a filter. _________________ 58 Beetle (now just a pile of parts in the corner)
AlteWagen Troll
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Wed Jun 25, 2014 12:18 pm Post subject: |
That boxed and screened oil pickup is slick! |
58Dub Samba Member
Posted: Wed Jun 25, 2014 7:18 pm Post subject: |
Thanks... Yes I thought he did a pretty great job on the pick up. fairly simple and should be very effective. _________________ 58 Beetle (now just a pile of parts in the corner)
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Jun 25, 2014 7:31 pm Post subject: |
Anvil wrote: |
Maybe a stupid question, but what is the advantage of using a WBX case for an air-cooled engine over the aftermarket aluminum cases that don't require all the mods? |
Because it's the T1 case the factory SHOULD have built to start off with, for all the reasons stated above. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
morymob Samba Member
Posted: Thu Jun 26, 2014 3:44 am Post subject: |
Is that bottom left stud hole cut out into cyl 3 hole, sure seems so. |
