seizure66 Samba Member
Posted: Fri Nov 09, 2012 6:12 am Post subject: Grease injector needles |
Has anyone used these grease injector needles that fit the tip of the grease guns? I was recommended to inject my cv boots that way as a sort of first line of defense, before actually tearing down to get the boots off etc. And if so, would it be necessary to make a few injections in each boot? Or will movement make the grease make it go where it needs to go?
Something like this... http://www.newegg.com/Product/Product.aspx?Item=9S...-_-NA-_-NA
What do you think? Thanks. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Fri Nov 09, 2012 9:11 am Post subject: |
First how would you get it behind the boot without tearing it or making a hole? Assuming you could perhaps slip it in under the boot at the axle side, I can't think you would get enough grease from that in the right places to make much difference. _________________ Ghia Owner Emeritus |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Nov 09, 2012 9:51 am Post subject: |
Yep, works good to fill the boot up with grease then what? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Fri Nov 09, 2012 10:29 am Post subject: |
Yeah, kind of what I thought. The dude at NAPA told me just to poke it in and fill the sucker up with grease. Hmmm?? |
Posted: Fri Nov 09, 2012 10:46 am Post subject: |
It's a messy enough job to clean and repack without outside help from the local flaps _________________ Rick
tasb wrote: |
sb001 wrote: |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Tue Jan 01, 2013 11:41 am Post subject: |
Those needles are great for packing wheel bearings. It is a lot cleaner than hand packing or using a packing "cone". I use high-temp bearing grease and get every little nook and cranny filled. Zero problems. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
JerryB Samba Member
Posted: Thu Jan 03, 2013 1:34 pm Post subject: Dont have a "siezure" just yet.....wait !! |
Firstly do not use chassis grease in a CV joint. Use a grease that is specific to CV's.
And....unless the boot is leaking grease either at the small end or at the flange end of the boot, you don't want to add more grease. (assuming whoever assembled the boot and CV used the proper quantity of grease in the first place). A torn boot needs a new one of course.....with the attendant package of grease and will have the proper quantity of grease to use.
If there is no indication of leaking grease you are prob. ok. Just leave alone. |
Posted: Thu Jan 03, 2013 1:44 pm Post subject: |
It's all good, thanks! |
