Single two barrel Dellorto 36 DRLA for a Baja Bug?
chvyhs
chvyhs is offline
PostPosted: Sun Jan 06, 2013 9:14 pm    Post subject: Single two barrel Dellorto 36 DRLA for a Baja Bug? Reply with quote
I'm in the process of helping my son set up his Baja Bug. We have a used 1835cc dual port engine, 110 cam and a Dellorto 36. It'll mostly be a street Baja with some desert time. Is this a good choice for his Baja? Is there a better choice of carb for this application (that won't cost me a couple of hundred dollars)?
Thanks,
Richard
Bashr52
Bashr52 is offline
PostPosted: Mon Jan 07, 2013 7:40 am    Post subject: Reply with quote
The single Dell will work ok, as long as you have a good manifold with pre-heat. I would try and source another sigle DRLA to match, and run them in a dual setup. Best bang for you buck.
chvyhs
chvyhs is offline
PostPosted: Tue Jan 08, 2013 9:10 am    Post subject: Reply with quote
Thanks,
I've been searching Craigslist for another Dellorto. I haven't found one yet but I've seen a lot of Webers with intake manifolds. Maybe I'll just switch over to Webers.
wbrown45
wbrown45 is offline
PostPosted: Tue Jan 08, 2013 3:19 pm    Post subject: Reply with quote
That single 36 will give you very good low, to mid range power for a mild 1835. If you find another 36 Dellorto you would have to make sure that it is a dual carb Dellorto. The single and dual Dellortos had markings on the base that identified them as either one. It has been awhile since I sold a new Dellorto (about 1996!) so someone on this site could tell you where the markings are, but there is a difference. I bet you could find a buyer for your carb and pick up a set of duals, but my old 1776 with a single Dellorto 36 was an excellent on/off road setup with good torque, and decent mileage.
OK Thang
Paul Wilson
Paul Wilson is offline
PostPosted: Tue Jan 08, 2013 6:34 pm    Post subject: Reply with quote
If you already have the complete single set up----run it. Keep an eye out for another single. You mentioned your budget. Been there ----still there. You'll have a lot of fun with that set up. But duals are lots better.
Paul
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Tue Jan 08, 2013 6:46 pm    Post subject: Reply with quote
If you can get the Dellorto Tech Book by Bob Tomilson of CB Performance.
It is good start to setting it up to run well off road.
Joseph
Fair Oaks/Orangevale, CA
Elrod Racing
Motion Tire Motorsports
Into Volkswagens since 1960
chvyhs
chvyhs is offline
PostPosted: Wed Jan 09, 2013 10:02 pm    Post subject: Reply with quote
I'm going to buy the book and the rebuild kit.
The only issue I still have is making the throttle cable work. It doesn't quite line up with the throttle linkage.
wbrown45
wbrown45 is offline
PostPosted: Sat Feb 02, 2013 8:17 am    Post subject: Reply with quote
Hopefully you have a single Dellorto carb.. CB Performance sells a slick single cable set up with an sheathed cable that routes over the fan shroud.
OK Thang
Paul Wilson
PostPosted: Sat Feb 02, 2013 8:32 am    Post subject: Reply with quote
X2 Works great.
chvyhs
chvyhs is offline
PostPosted: Mon Jun 03, 2013 10:40 pm    Post subject: Reply with quote
Finally got the engine running and drove the Baja Bug down the street but the carb still isn't ruing quite right. I still don't know if we have a single or dual Dellorto carb. I've read the Superformance Tech Book and still couldn't figure out how to tell the difference. Anyone here know how to tell the difference? I'm going to call CB Performance tomorrow and ask when I place and order for other parts.
Thanks
Paul Wilson
PostPosted: Tue Jun 04, 2013 4:42 pm    Post subject: Reply with quote
Some single Dells have a hole in each butterfly. You can take two singles and make duels. You can also take a set of duals and make two singles with the right parts. I have done this many times. Singles require smaller venturies than duals and need different jetting. Post your engine specs and your carb specs and I can get you close.
uglyoffroader
Paul Wilson
PostPosted: Tue Jun 04, 2013 4:50 pm    Post subject: Reply with quote
Ok, 1835, 110 cam I see. I would start with, 28-30mm vents, 60-65 idle jets, 135 mains, .2 emulshion tubes and 160 air jets. You may need to go up or down with jets, change only 1 thing at a time.
chvyhs
chvyhs is offline
PostPosted: Tue Jun 04, 2013 10:21 pm    Post subject: Reply with quote
I called CB Performance today. They've got great customer service! Their carb tech talked to me for a little bit and we came up with this.
32mm venturis
160 air correction
160 and 170 main jets (2 sets for tuning)
70 idle jets
60 pump jets
Currently the car has,
28mm venturis
170 air correction
150 main jets
60 idle jets
55 pump jets
When we ran it this weekend we couldn't seem to keep enough fuel in the engine and the exhaust got really hot. Almost glowing. That's why I went a little fat with the carb tuning parts.
I also bought some of their velocity stacks. They look much better than the empi ones and I didn't have any at all.
chvyhs
chvyhs is offline
PostPosted: Thu Jun 06, 2013 9:56 am    Post subject: Reply with quote
After reading my Dellorto book again, I understood the section that mentions that the carburetor may get too cold and possibly ice over. When I was adjusting the idle mixture screws I noticed that they were extremely cold to the touch. The Dellorto book goes into detail about running the proper intake manifold with provisions to heat the intake and carburetor. The intake manifold on my sonís Baja doesnít have the tubes that go from the intake manifold to the exhaust. His Trimill exhaust also doesnít have any provisions to get heat to the intake manifold. Any ideas on how I can fix this? Do I need to fix this immediately or can I just make sure I take care of it before winter? The Baja doesnít need to be on the freeway and itís not leaving southern California any time soon.
Thanks
Bashr52
Bashr52 is offline
PostPosted: Thu Jun 06, 2013 12:02 pm    Post subject: Reply with quote
The key to running a center mounted carb is good preheat. You need a quality manifold like this one:
http://vwparts.aircooled.net/Bugpack-IDF-DRLA-Centermount-Manifold-1-1-2-p/1018-11.htm
When the manifold gets too cold, the fuel will fall out of suspension and cause the engine to run too rich.
chvyhs
chvyhs is offline
PostPosted: Thu Jun 06, 2013 5:27 pm    Post subject: Reply with quote
Looks like I'll have to buy a new exhaust system too.
chvyhs
chvyhs is offline
PostPosted: Thu Jun 20, 2013 9:55 pm    Post subject: Reply with quote
We finally got the engine run right! The timing was way too advanced causing the engine to run bad. We ended up going back to the 28mm venturis and tuning according to the example engine in the book. Just like the pros always preach. Less carb is better.
