TX-73 Samba Member
Posted: Tue Sep 16, 2014 8:06 am Post subject: |
The back end sat a bit higher when I took the car apart, but I will look at it again when everything is back in place with full weights. Thanks for that link! _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
TX-73 Samba Member
Posted: Sat Sep 20, 2014 1:51 pm Post subject: |
Odds and ends sort of work.
Brake reservoir and feed lines installed.
Rear license cover and bracket in place, new seal and license lamp too.
Started getting organized on the wiring. I've built harnesses from scratch before but I thought the Wiring Works harness was more cost effective in regards to my time. I will be adding some additional circuits and relays depending on what I decide to add into the electrical system.
I had kept and labeled everything from the original electrical harness, plus I have pics and notes, so I'm not too worried about the new stuff.
flyboy161 Samba Member
Joined: December 26, 2009 Posts: 2091 Location: Perry, GA
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
TX-73 Samba Member
Posted: Fri Sep 26, 2014 2:21 pm Post subject: |
Thanks all,
Pete, I love that color combo you've got, and your posting pics helps me tremendously.
Started laying out some wiring - I like to intially get it generally in place, then come back and see where I need to tighten things up.
Got the end plugs on the MC connectors, had to get new boots but re-used the plastic connectors. Not shown but I also use 3M fabric tape, same as what OEM's use to wrap harness joints and ends at connectors.
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
TX-73 Samba Member
Posted: Fri Sep 26, 2014 2:32 pm Post subject: |
I'm going with H4 headlights, so I bought a set of Hella-Mexico lamp assemblies from WW. Same tri-connector set-up as the OEM sealed beams. I will be adding a dual relay setup to feed the lights so the switch simply energizes the relays.
I had mentioned plugs before, here's an example of the closed grommets that I get from McMaster-Carr, I've got them in most common sizes. This was part #9750K31.
Here are plugs installed into the holes for ac lines.
While I was at it, I also picked up nylon vaccum-rated, fuel resistant tubing from McMaster, same dimensions as original, reasonable cost for a 25 ft roll. Part #5173K89. I'll get same stuff for the slightly larger diameter sections of the evap system.
TX-73 Samba Member
Posted: Fri Sep 26, 2014 2:43 pm Post subject: |
sweet! I got the same headlights, the are delivering in the mail today. _________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sat Sep 27, 2014 3:12 pm Post subject: |
I've got the same lights but in RHD and they are very impressive with 100/90w globes in them. _________________ Quick little bug, you got a Porsche motor in that?
1974 Germanlook 1303 2.5 Suba-Beetle |
Her74buggy Samba Member
Joined: September 29, 2013 Posts: 367 Location: Houston
Posted: Sat Sep 27, 2014 8:44 pm Post subject: |
TX-73 wrote: |
For reference, here's the wheels that have been on the car for the last 20 years or so, as you can see they pretty much filled out the fenderwells, never had any rub issues with them, but I plan to go with smaller tire than that 205/75/15. I always thought they were just a bit too big.
Really nice build, I've been following the progress and can't wait to see the finished car!
Love the new wheels! I'm in Houston and may be interested in buying the old wheels if you're interested in selling and still have them.
Keep posting! Nice work. |
TX-73 Samba Member
Posted: Sun Sep 28, 2014 6:27 am Post subject: |
I thought the Mexican Hella quality was decent, certainly much better than the bargain basement versions I've ready about. We'll see, but this gets me down the road a bit.
Her74, I can do that. I'm using them as roll-arounds for the time being but I was planning to sell them. Tires are toast but the rims/caps are in nice shape. _________________ My 1973 Standard Beetle Build SOLD
Posted: Mon Sep 29, 2014 5:24 am Post subject: |
TX-73 wrote: |
I thought the Mexican Hella quality was decent, |
They are, Look at the LENS, you will notice it says "Made In Germany" The lens is made there, the rest is Hella of Mexico.
Here are my 100% German units, (back reflector is German) and so is the Front glass.
Your Mexican ones should have the same German glass as mine.
1966 Ghia (sold)
1966 Red Beetle |
TX-73 Samba Member
TX-73 Samba Member
Posted: Sat Oct 04, 2014 6:14 pm Post subject: |
Got the wiper stuff cleaned up and back into the car.
Original didn't look terrible.
Pulled the pivots apart, they were a bit gunky.
Cleaned up the contacts and greased the wiper gearset.
All cleaned up.
TX-73 Samba Member
Posted: Sat Oct 04, 2014 6:18 pm Post subject: |
Got the front headlights in place, I'll wait to install the trim rings for now.
These were the H4 conversion set, bolted right in and use the same connector as the sealed beam. As I've mentioned, I'll power them through separate relays (hi/lo).
Got the front turns connected up as well. They're going to need new lenses.
TX-73 Samba Member
Posted: Sat Oct 04, 2014 6:22 pm Post subject: |
I had started on the tailights a few days ago but noticed that this type of seal really wasn't going to work very well.
So I bought the right one for the base plate.
Got the lights in place (I hope I got right and left correct)
All these lights going back on start to make it look buggy again lol. _________________ My 1973 Standard Beetle Build SOLD
TX-73 Samba Member
Posted: Tue Oct 14, 2014 5:13 am Post subject: |
Few more items.
Got the expansion tank in place, most of the front end wiring is there now, I'll tighten it up after the gas tank is back in.
Starting to slowly fill up the area behind the dash. There's going to be stop and start as getting one thing done leads me to something else. Example is I need to install the speedo, but first want to disassemble, clean up, and add the foil strips for better lighting, so it's a bit back and forth now going forward.
I was looking at the fuseblock and looks like it's easy to include a couple more relays for the high and low beams. I'll cut the tabs off of the new relays before I install. I'll probably add a small connection block for additional relays as well so I can route a second battery feed up to the front as well as to the back area. All feeds from the battery will route through a main circuit breaker at the battery.
Posted: Tue Oct 14, 2014 7:34 am Post subject: |
I like that fuse block! _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
