TX-73 Samba Member
Mr.Duncan Samba Member
Joined: May 12, 2012 Posts: 3542 Location: Houston, TX
TX-73 Samba Member
Posted: Mon Jan 26, 2015 7:06 am Post subject: |
You guys are sharp lol!
I have plugs courtesy of McMaster Carr that I haven't installed yet. Also I was going to use that little tab with a tie-wrap to ensure the wire loom was held at the bottom.
thanks! _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
Posted: Mon Jan 26, 2015 7:08 am Post subject: |
TX-73 wrote: |
thanks! |
Are the McMaster Carr ones "just plugs"
The stock ones, have a little slit, so they allow water to leak out.
_________________ (Owner) www.vintagecarleds.com
Red 1971 Squareback Thread
Red 1966 Beetle Thread
1971 Green Super Beetle (sold)
1966 Ghia (sold)
1971 Blue Super Beetle (sold)
1966 Java Green Std Beetle (sold)
1971 Red Squareback (sold)
1966 Red Beetle |
NewTechnicIan Samba Member
Joined: May 28, 2013 Posts: 367 Location: Burlington, VT
TX-73 Samba Member
TX-73 Samba Member
Posted: Sun Feb 01, 2015 10:35 am Post subject: |
Started to put the CV's together, that first one was really a learning curve for me. I used Lobro CV boot kits, nice quality and very complete, including new bolts.
Here's the kit, I've taped up the splines to make sliding the boots on a bit easier. I use transmission assembly lube on things like this, as it does not affect anything. Of course the CV joints got the supplied moly grease. Note that in the kit you get 2 different styles (and thicknesses) of snap rings and concave washers. This is what goofed me up initially.
These are the concave washers supplied in the kit - they go on the shaft first to give some preload to the joint, I think to keep it from moving in/out on the shaft. I didn't snap at the time and installed the one on the left. Problem was that it could not seat all the way onto the inner shaft shoulder.
Here's that washer installed, if you look closely, you can see a slight gap under it. That caused an issue in that I could not push the CV joint in far enough to install the outer snap ring.
I also applied a very thin smear of gasket sealant where the boot cover sits (overlaps) on the CV joint itself. My thinking was to maybe avoid grease seepage from this area.
I had made a gizmo to help compress that inner concave washer. The openings allowed me to use snap ring pliers to get the outer ring installed when the CV joint was pushed down far enough to clear the groove.
Action pic This is where I discovered my mistake on the washer. I could feel that the CV joint was fully seated yet there was still 1/16" needed to access the groove for the snap ring. After a bit of head scratching, I realized that I had used the wrong washer. Replaced the washer and all was fine.
This was as far as things would go with the wrong washer.
This is the correct washer for my application. I also double checked with what I had originally removed at disassembly.
Here's the installed clip when the correct washer was installed. 3 more to go but I'm a bit smarter now lol. Always verify that snap rings are fully seated into the groove.
And remember that the bolts take an 8mm 12pt socket.
peteandvanessa Samba Member
Joined: July 01, 2009 Posts: 931 Location: Sacramento
TX-73 Samba Member
Posted: Fri Feb 06, 2015 4:46 pm Post subject: |
Kind of slow going with recent work demands, gotta get rid of that day job
Anyway, CV's are finally done. I looked up info and found recommendations to clock (orient) them to allow for full movement, so that's what I did. Here's info on clocking the CV's:
http://www.thesamba.com/vw/forum/viewtopic.php?t=593685&start=0
This is not clear but the rod I used to help line them up is through the "big" part of the race wall on this side.
It goes through the "small" part of the race on the other CV.
Overall, pretty straightforward.
Both done, ready to install. I tagged them when they were removed as to driver or passenger side, but looks like I can swap them without any problems to allow for even wear. To be honest they both looked really good when I cleaned them up so all they needed were new boot kits. I'll wait till they are installed before crimping the boot clamps.
TX-73 Samba Member
Posted: Fri Feb 20, 2015 4:29 pm Post subject: |
Slow going these days but that's ok, it will all eventually get done, I'll get a cycle of more time to make good progress to get to the interior.
CV shafts installed. Here's the hardware, shows the new 12pt bolt, Bellville washer and attachment plate for each attachment point. Little dab of anti-seize makes the job complete.
I've started using more of the Bellville washers in applications where I used to use split washers. I think they hold torque better and don't dig into the surfaces as much. In this case these washers came from McMaster-Carr online. I use the type that have serrations on both top and bottom.
I had already chased and cleaned all the threads, makes it easy to install the new bolts and I think that final torque is more accurate with clean threads. Minor thing I guess but I like to try to cover little details.
CV shaft installed, turns really nice and smooth.
Aside from any small stuff that pops up, I "think" I can finally get to the interior, weather temp and work schedule permitting _________________ My 1973 Standard Beetle Build SOLD
beetlenut Samba Member
Posted: Fri Feb 20, 2015 4:42 pm Post subject: |
TX-73 wrote: |
...These are the concave washers supplied in the kit - they go on the shaft first to give some preload to the joint, I think to keep it from moving in/out on the shaft. I didn't snap at the time and installed the one on the left. Problem was that it could not seat all the way onto the inner shaft shoulder.
So what do you suppose the washer on the left with the inner spline-like indentations is for? I had that same dilemma when I reassembled mine. It even looks like it sits flatter and would compress better. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
TX-73 Samba Member
Posted: Fri Feb 20, 2015 6:46 pm Post subject: |
Others will be more knowledgeable but I think the CV kit includes 2 different washers and snap rings to cover several model years. The snap rings I didn't use were thinner than the ones on my particular car. I just figured that it's easier to keep everything in one kit. _________________ My 1973 Standard Beetle Build SOLD
TX-73 Samba Member
Posted: Sat Feb 21, 2015 7:29 am Post subject: |
Also, you had mentioned that the splined washer looks like it sits flatter but that's because it was the (wrong) washer I had first tried to use. My press helped to flatten it out when I first tried to install the CV. I could tell when I installed the second (correct) washer that everything felt right getting that outer snap ring installed. _________________ My 1973 Standard Beetle Build SOLD
TX-73 Samba Member
Posted: Sat Feb 21, 2015 2:33 pm Post subject: |
Finally started on the interior
First up was I glued the headliner pad to the roof. I wasn't that worried about the pad not extending all of the way to the edges as it still provides sound-deadening and elimination of that oil-can feel.
I bought the pad kit from TMI - the yellow colored foam. I also bought a 1/2" thick piece of higher density closed cell foam in case I didn't like the feel
of the TMI foam.
I also made sure I covered painted areas to protect them from glue drips.
vamram Samba Member
Posted: Sat Feb 21, 2015 2:45 pm Post subject: |
Love your attention to detail. Which foam are you going with? TMI? Or the cell foam? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
TX-73 Samba Member
Posted: Sat Feb 21, 2015 2:47 pm Post subject: |
Vamram, I'm not sure it will depend on where the material is installed and if I think I need to make up some thickness. Going to figure it out as I go. From past interior work I learned that sometimes too much backing is worse than not enough - I want to be sure the padding all looks consistent. I'm going with original style (multi-piece) headliner and it already feels like it's going to be a challenge to get it done lol.
Next was to glue some foam pad to the door pillars. I looked at some online info and found that the recommendation was to roll the foam in order to put a soft edge at the headliner cover. I used the 1/4" TMI foam since it was going to be doubled up to a 1/2" thickness.
I put some tape marks on the pillar to remember where the attachment holes were for seat belts and hand-loops.
Gued the foam piece in place. It's 3" wide and will be about half that after I double it back.
Here's the piece doubled back - you can see metal on the right that will be glued to the cover material. The cover material is not glued to any of the foam. This also makes a soft edge on the right so that there's (hopefully) not a line showing under the cover material.
When I doubled the foam, I went to the edge of the little body clamps that will retain the cover material. My thinking was that this will help to hide the clamps after the material is stretched into place.
TX-73 Samba Member
Posted: Sun Feb 22, 2015 10:25 am Post subject: |
Well I looked at that foam on the posts and decided I wasn't happy with it, seemed too thin and really not filling that post area with a nice roll, so I removed it. I contemplated using 1/2" jute padding in all areas where I had planned to use foam, but I may give that 1/2" high density foam I bought a try. Seemed to work nice for my friend Pete:
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...;start=300
I'm also trying to figure the attachment areas of this multi-piece headliner, even with researching it seems pretty complicated. So with all this running through my head it seems like a good time to stop for just a bit and think things through. Even if I went back and got the one-piece headliner it would be ok for the extra cost if it saved me some install headaches. I'm currently using the vinyl headliner, also considering the tweed version.
Sometime it just doesn't go that fast lol. _________________ My 1973 Standard Beetle Build SOLD
TX-73 Samba Member
Posted: Sat Mar 21, 2015 4:04 pm Post subject: |
Got home long enough to get a bit more done. I glued in the 1/2" high density foam padding in preparation for the headliner installation. Turned out good. I made some cardboard templates for the foam which made it easy to get the pieces cut accurately. I also used blue painters tape to mask off adjacent areas from glue spray. I really liked working with that higher density foam, cuts nice and has a good surface (closed cell).
Despite finding some info on original style headliner install, I'm still struggling a bit to understand how exactly some of the sections are attached into place. I understand the door pillar install, but the rear window and the other side sections are not clear to me. My understanding is that you don't glue the backside of the headliner onto the foam pad areas, just at the edges. My car doesn't have the teeth at the rear quarter sections that are on earlier models so I'm not sure how those headliner pieces attach at that seam, same issue for the rear window section. I'll just have to look for more info and give it a shot - if worse happens I can always get the one-piece headliner. _________________ My 1973 Standard Beetle Build SOLD
Posted: Sat Mar 21, 2015 6:47 pm Post subject: |
If I remeber correctly, the rear quarter window areas do not have teeth.
I BELIVE the headliner is glued at that area where the spot welds are in the windows.
And the lip of the new window rubber holds it in.
I could be wrong, I will research it and let you know.
I'm just going off memory. _________________ (Owner) www.vintagecarleds.com
1966 Ghia (sold)
1966 Red Beetle |
vamram Samba Member
Posted: Sat Mar 21, 2015 8:01 pm Post subject: |
TX- check out this Chircostore article. The whole thing is explained, step-by-step, w/pictures.
http://chircoestore.com/wordpress/?page_id=63
Victor _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
