ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
54ovsemi Samba Member
Posted: Sun May 10, 2015 12:31 pm Post subject: |
Really nice... _________________ 2013 Jetta
2009 Rabbit
2006 GLI
1955 Semaphore Oval |
thebucket Samba Stockbroker
Joined: April 06, 2004 Posts: 3734 Location: Houston Texas
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
Posted: Mon May 11, 2015 10:37 pm Post subject: |
Between yours and Envious's bug.. love the depth and shine in both!! _________________ Be kind to all critters. America's "H8TERZ" can drink sludgy used Motor Oil!
oemwolf |
Posted: Sat May 16, 2015 6:37 pm Post subject: |
Got the fenders and hood mounted. I put some temporary fender beading in. The black beading and black running boards are just not doing it for me. I am sending them out to have them professionally colored. Also mounted the rear decklid but it's not the one I am running, I have a vert lid that still needs to be painted, when thats done I will swap them out.
_________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
Khova Samba Member
Joined: September 09, 2009 Posts: 224 Location: St. Thomas VI
Envious Samba Member
Joined: January 08, 2003 Posts: 1821 Location: Toronto, Ontario, Canada
Posted: Thu May 21, 2015 5:48 pm Post subject: |
ConcreteAce wrote: |
Got the fenders and hood mounted. I put some temporary fender beading in. The black beading and black running boards are just not doing it for me. I am sending them out to have them professionally colored. |
What color are you changing them to?
Looks great. _________________ 71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225 |
Posted: Thu May 21, 2015 11:05 pm Post subject: |
Envious wrote: |
I did a spray out card for the interior shop so they could color match them to the car. I already got them lighter than the body color but did not like them, so I am thinking of trying the same color as body color but in a satin finish, then if I don't like that I am going to a slightly darker color than body color. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Sun Aug 30, 2015 5:44 pm Post subject: |
Well I have not worked much on the 61 the past few months due to it being the busy season at work. I did get some parts painted today.
That is pretty much the last of it. I'll start making the pan a roller. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
4130_nasa Samba Member
Posted: Tue Sep 01, 2015 8:51 am Post subject: |
Love that color!
Coming along nicely... |
Posted: Sat Oct 31, 2015 3:34 pm Post subject: |
Well been slow going these past few months but my Dad came into town and we got a few things done on the pan.
Started out by installing one piece axle boots.
As I assembled the tranny Dad tackled the installation of the brass shift rod bushing.
that thing was a nightmare to install.
I also cleaned all the rust off of the shift rod while it was out.
got all the solid mounts installed..
I still have a torque/kafer bar to install but it will go on after the body has been mated.
The spring plates gave us hell to get on correctly. We started out by fabbing our own loader tool. Jeremy, Dad, and I spent about an hour making this beauty..
It worked like a charm and only cost me 11 bucks.
new brakes installed out back..
Front leaf springs narrowed and dimpled
checked shocks to make sure they cleared everything
Ryan and I went in halves on a reamer for the delrin bushings.
I ran into a major issue when installing my new german king pins into the new set of Airkewld dropped spindles. The hole was way undersized and egg shaped.
I stopped by Joe's shop and he honed them to proper spec.
but I lost one of the thrust washers and I am stalled until I get one.
Started the plumbing on the brake lines,
I'll post another update soon. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Sun Nov 01, 2015 3:47 am Post subject: |
Very nice work. Are you running Socal rear shocks? I'm running them and I really like them. They look good too. _________________ 71 Type 1302 Custom
64 Type 151
64 Porsche 356c
52 BSA C11G
Posted: Sun Nov 01, 2015 7:47 pm Post subject: |
Envious wrote: |
Very nice work. Are you running Socal rear shocks? I'm running them and I really like them. They look good too. |
I had planned on it but I was not sure what size to order for the rear, what size did you order? _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Mon Nov 02, 2015 1:53 am Post subject: |
Looking nice! |
Posted: Thu Nov 05, 2015 1:41 am Post subject: |
Got my kingpins in and have started on the front beam. I didn't catch that I had an early and a late control arm. I had two sets and didn't pay attention, I just picked out the best four. So I had to take care of that. Joe gave me an extra set of carriers so I was able to replace the carrier that got messed up due to the new dropped spindles being undersized and egged.
Late:
Early:
kingpin rebuild:
finished installing the driver side brakes before I called it a night..
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
1966vwfan Samba Member
Joined: April 22, 2014 Posts: 8 Location: QLD, Australia
Posted: Tue Nov 17, 2015 1:53 am Post subject: Re: ConcreteAce's 61 build |
Love this car so far!! |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Tue Nov 17, 2015 12:43 pm Post subject: Re: ConcreteAce's 61 build |
tiz a thing of beauty. _________________ If you can't join them, beat them! |
ballbag Samba Member
Joined: January 01, 2006 Posts: 204 Location: Cheshire, UK
Posted: Wed Nov 18, 2015 6:11 pm Post subject: Re: ConcreteAce's 61 build |
WOW, that's amazing dude. I love Anthracite grey
Here's my old '63, unfortunately I don't own it anymore
_________________ I never learned that much at school, but i've taught ladies plenty!! |
vwnut1 Samba Member
Posted: Wed Nov 18, 2015 7:16 pm Post subject: Re: ConcreteAce's 61 build |
Love your attention to detail, the build is awesome. Reassembling the car without scratching anything with hand tools, etc. will truly be a challenge, so stay focused!
I know your checkbook must be on fire at this point. Have you entertained restoring a tired late 60's or early 70's air-cooled Porsche 911 to this level of detail in the future? You would do well financially if you flipped one, air-cooled 911's are fetching top dollar.
Keep up the great work, I can't wait to see it finished. _________________ 1957 VW Oval Resto Mod |
joel55bug Samba Member
Posted: Wed Nov 18, 2015 8:19 pm Post subject: Re: ConcreteAce's 61 build |
Wow, loving the attention to detail. I can't wait to see more updates on this build. Really looking forward to seeing the final product in person in the near future. Quality workmanship at its finest. |
