276995 Samba Member
Joined: February 20, 2008 Posts: 32 Location: AUSTRALIA
Posted: Fri May 01, 2009 7:11 am Post subject: Judson oil question |
My 40hp is now up and running with the Judson on it and am real happy with the result.
One thing I noticed today is that when it is revved up to full throttle it spits oil out of the breather pipe ( next to the oil filler ).
Is this normal for an engine spinning at high speed, or is something not right?
Whats a good way to block this up, or is this the wrong thing to do?
Steve |
Karly Samba Member
Joined: August 01, 2002 Posts: 641 Location: Australia
Posted: Thu Jan 24, 2013 3:57 am Post subject: |
I know this is an old post but I'm having the same issue with a 36hp + judson - is a non stock oil breather + catch needed?? Or is something not right with my set up? It doesn't happen when I'm just putting around town but get on the freeway and there's oil that gets splashed out of there and then goes everywhere. _________________ 1960 Beetle ''Heidi" daily driver
1964 Karmann Ghia project |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Thu Jan 24, 2013 10:11 am Post subject: |
Canni wrote: |
I know this is an old post but I'm having the same issue with a 36hp + judson - is a non stock oil breather + catch needed?? Or is something not right with my set up? It doesn't happen when I'm just putting around town but get on the freeway and there's oil that gets splashed out of there and then goes everywhere. |
I installed one of these gizmos:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111115450
Seems to work. |
cavscout Samba Member
Joined: September 17, 2011 Posts: 83 Location: PA USA
Posted: Thu Jan 24, 2013 4:23 pm Post subject: |
That is exactly what is needed to prevent the oil spraying out. _________________ "Thanks to you I'm much obliged, such a pleasant stay" RP
56 ragtop
57 ragtop
79 vert
2010 VW CC Turbo |
Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Thu Jan 24, 2013 8:04 pm Post subject: |
under normal circumstances, I'd agree... but I think I'd double check for blow-by as well. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
Karly Samba Member
Posted: Thu Jan 24, 2013 8:51 pm Post subject: |
thanks will give that a go! _________________ 1960 Beetle ''Heidi" daily driver
