martin18152 Samba Member
Joined: October 21, 2012 Posts: 36 Location: s.t. louis
Posted: Sun Jan 20, 2013 11:51 am Post subject: 73 ghia lock stuck |
My key will no longer turn the lock cylinder, and unlock the steering wheel. I read several articles on how to replace the switch and cylinder, however, they all say to turn the key to the on position in order to pull out the cylinder. The cylinder will not turn, so thats not an option.
Has anyone had this exact stuation? I have not pulled anything apart yet. I dont think the key is worn out, its most likely the cylinder. Most of the articles pertain to a supper beatles. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Sun Jan 20, 2013 12:56 pm Post subject: |
I have but eventually the key came out after fooling with it.
Try spraying some wd-40 down the lock. _________________ Ghia Owner Emeritus |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Sun Jan 20, 2013 1:22 pm Post subject: |
liquid graphite is great for makin sticky tumblers move |
Posted: Sun Jan 20, 2013 3:03 pm Post subject: |
I sparayed some WD in there, been moving steering wheel, pushing the key in and out. If I could just get it to turn, I would pull the battery , and take the whole thing apart. |
Lucatero Samba Member
Posted: Sun Jan 20, 2013 4:15 pm Post subject: |
I have this happen every now and then. Keep pulling the key in and out slightly, while rock the steering wheel back and fourth, and eventually you will be able to undo the lock. It's frustrating but keep at it. _________________ 64 Beetle Type 1/Totaled
64 Beetle Type 1/Totaled after owning 5day!
71 Beetle Type 1
70 Karmann Ghia |
Posted: Sun Jan 20, 2013 4:21 pm Post subject: |
Now that I have it completly apart, I see why you need to turn the key, its because the steering lock tab keeps the cylinder from comming out. I have a new lock on order, once I get it, I will probably just get a dremel tool, and cut the locking tab off , then it should just slip out with out a problem. If it wasnt for the stuck lock, this whole proceedure would take about 20 min. The hardest thing you have to do is pull the washer hoses off, count on them breaking, so just buy some new ones, or cut them at the nipple, there is enough slack to put them back on.
I know the saying "if its not broke, dont fix it" , but my advice is, if you have an original key lock, replace it now while its easy.
if anyone sees somthing fundamentaly wrong with doing this, let me know, I probably won't get the new lock for a week or so. I appreciate any advice. |
Posted: Tue Jan 22, 2013 6:50 am Post subject: |
after watching numerous Utube videos, none were exactly like the 73 ghia, I have a better Idea. Since what I have ordered is a lock core only, I don't want to destroy the outer assembly. There is a small hole that I think you can insert a paper clip, and push in the cam that holds lock core in, so I'm hoping to just pull the core out, and not the whole assembly. |
Posted: Tue Jan 22, 2013 2:30 pm Post subject: |
The little hole worked, you can barely see it with assembly still in the column, pushed it in with 3/32 drill bit, and she came right out. |
