BDubVdub Samba Member
Posted: Tue Mar 26, 2013 3:23 pm Post subject: |
Steve Arndt wrote: |
The reason I used the Porsche shifter when I wrote the install article hosted at aircooled.net and germanlook was to retain the spring loaded reverse/1st gear lock out. |
Oh ok. With the 901 trans, I don't feel like the lockout is necessary. Considering 1st is where 2nd would be and reverse is where 1st would be you'd just have to be careful not to jam into reverse when going for 2nd. |
-Alex77- Samba Member
Joined: December 09, 2008 Posts: 513 Location: Finland
Posted: Tue Apr 02, 2013 12:59 am Post subject: |
915 close to 200hp, you are quite wrong. Carrera 84-86 models have 231hp 3.2 liter engine (europe) and they have 915 transaxle.
Even Lambo replicas with chevy uses sometimes 915 transaxle. 915 can handle around 300hp.
If you want trans that handles over 400hp, then probably 915 and 091 isnt good choice, even if 091 is successfully used with 300-400hp at dragracing.
ambrynmc wrote: |
I think realistically the 923 is too rare to consider.
this is the logic i went through to come to my conclusion.
I looked at the 901/915 transmission and both are expensive and do not appear to be able to handle a lot of horsepower/torque. I am NOT an authority on this, but based this off a lot of reading on the internet.
Several people say that the safe 901 limit is around 150 hp and the 915 is close to 200 hp. I stock 2,0L WRX engine stock puts out +/-220hp and can easily be pushed close to 300 hp. To get a rebuilt 915, you are looking at $2,000 + the conversion parts to mate to subaru is close to $1,350 (nose cone $250, front mount $250, trans flanges $300, shifter $450, shift rod/cable bits $100) plug adapter plate and clutch $800 ($480 plate+flywheel, 215mm clutch $320) and an Subamount engine mount ($300). Total of $4,450 for a trans that I wouldn't push past 250 hp without worrying...
Another option is the bus 091 trans. Biggest minus to me is it's still a 4 speed. I was really wanting overdrive. I called and found out that you would be a fool to not have the trans rebuilt also (same as the 901/915). And the guys recommend getting welded 3rd and 4th gears and you might have to change the R/P ($450 I think?). You also need the Berg nose cone. So figure $800 for the core, $800 to rebuilt it, $700 for welded 3rd/4th, $500 for the GB nose cone = $2,800. Again, if you are mating it to a Subaru engine you need the clutch/flywheel/adapter plate $800 and an Subamount $300. Total of $3,900 for a trans that I probably wouldn't push past the same 250 hp and no over-drive.
So if you go Subaru transmission you need a good TY754 core ($800) plus the Subarugears kit (currently on Group Buy, but I'll use the normal price ($2,500 including the Subamount). Add $200 for bearings/seals, etc. You also need a clutch, I'm assuming a hot one ($450). Total of $3,950 for a trans that can go +350 hp. This price is high since the kit is on sale (see bottom of post) and I can find good cores cheaper than $800, but I didn't include labor for the install, so I would call that a wash (you tell me if that sounds fair).
Honestly, if you aren't planning on running a turbo/hot rod Subaru engine and keep it close to 150 hp, I would look closer at the Berg 5 speed. I read that you can get one put together for about $3,000. But then you need the flywheel, adapter plate and clutch again (but the clutch can be a cheaper Type 1 unit). Still looking at close to $3,700.
Again, I'm NO expert. This is just the logic I went through when I was looking at what transmission to use for my own project. I've been meaning to do a comparison on these transmissions for a while and this seemed to be good opportunity to do it.
Anyway, in case anyone is interested in the Subaru transmission, a few of us put together a group buy over on the STF. We did one last year and it was a good deal for everyone.
http://www.shoptalkforums.com/viewtopic.php?f=19&t=141928
Sorry for long post...I've been thinking a lot about it... |
_________________ Lasercut parts and CAD design |
markhuebbe Samba Member
Joined: March 08, 2006 Posts: 379 Location: St. Louis, USA
Posted: Tue Apr 02, 2013 6:39 am Post subject: |
BDubVdub wrote: |
$6500??? Ouch! |
Yeah that seems about right when I had my 5 speed done. With close ratio racing gears, a 901 or 915 box was quoted starting at 10k and going up.
$275 shifter
$1700 Berg kit
$3500-4000 build cost (Rhino case, Weddle gears, R&P...)
$700-$1200 for used ZF LSD _________________ 1970 Beetle - Rally car
http://www.Rally-America.com
http://www.HuebbeRally.com |
Posted: Tue Apr 02, 2013 6:53 am Post subject: |
markhuebbe wrote: |
BDubVdub wrote: |
$6500??? Ouch! |
$275 shifter
$1700 Berg kit
$700-$1200 for used ZF LSD |
I talked to the fella here that built my trans for my turbo motor asking him what it might cost to rebuild my 901 if the time ever came and he said max it would cost to rebuild it with middle of the road stuff would be about $4,000. It cost me $2,100 to have that other trans built with all Weddle Sportsman gears, rhino case, super diff, etc. |
offrdbus70 Samba Member
Joined: August 23, 2006 Posts: 512 Location: Pine Valley-SD
Posted: Tue Apr 02, 2013 8:31 am Post subject: |
How about a 914 transmission? I have two and need more gearing for my bus. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Tue Apr 02, 2013 9:06 am Post subject: |
offrdbus70 wrote: |
How about a 914 transmission? |
Side sifter or tail shifter? _________________ Glenn
Member #1009
#BlueSquare |
coolrydes Samba Member
Posted: Tue Apr 02, 2013 10:29 am Post subject: |
Dam,
We're selling 915's rebuilt with a complete conversion kit to bolt into a type chassis including shifter and shift rod for $6500. And I know for a fact it will take 300+hp...... Maybe we are not charging enough..... _________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
mark tucker Samba Member
Posted: Tue Apr 02, 2013 11:17 am Post subject: |
thats too much for me, for sure,Im still waiting for the china 6 speed to hit the shore....... but would rather have a 5 or 6 speed automatic. |
Posted: Thu Apr 11, 2013 9:54 pm Post subject: |
Here are kits that will allow of either a Subi or Porsche 5 speed in a type one....
MENDEOLA SUSPENSION
helowrench Samba Member
Joined: August 27, 2003 Posts: 567 Location: dallas texas
Posted: Sat Apr 13, 2013 7:56 pm Post subject: |
And how much does that sweet kit cost. _________________ Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser |
reservoirdubs Samba Member
Joined: April 07, 2007 Posts: 177 Location: Calgary (pronounced Calgree)
Posted: Mon Apr 15, 2013 4:30 pm Post subject: |
I have a 901 tranny with the [email protected] nosecone, mounts, shifter, 944 flanges for $2200 if anyone is interested. |
vwluvrs Samba Member
Joined: May 11, 2002 Posts: 158 Location: Cental California
Posted: Thu Jun 13, 2013 11:47 am Post subject: |
coolrydes wrote: |
here is a link to the Subaru kit ......
Do you have to modify the Subaru trans in any way? Is it a reasonably simple conversion? _________________ AlwAys VW, (O\_!_/O)
Renovator, Resurrector, Resuscitator of old VW's
always buying and selling ; Specializing in Rust Free CaliFORNIA cars
>Click< to see my stuff for sale |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3467 Location: Charleston, SC
Posted: Thu Jun 13, 2013 12:11 pm Post subject: |
vwluvrs wrote: |
coolrydes wrote: |
Do you have to modify the Subaru trans in any way? Is it a reasonably simple conversion? |
Yes, the Subaru transmission requires a new ring and pinion gearset to reverse the rotation of the differential for rear-engine use. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Thu Jun 13, 2013 6:20 pm Post subject: |
cant you just flip the entire trans over?? |
Glenn Mr. 010
Posted: Thu Jun 13, 2013 6:22 pm Post subject: |
mark tucker wrote: |
Not sure about a Subaru, but a Porsche G50 can be run upside down. _________________ Glenn
Member #1009
#BlueSquare |
Subarugears Samba Member
Joined: January 03, 2012 Posts: 294 Location: Sydney, Australia
Posted: Fri Jun 14, 2013 4:40 am Post subject: |
Of course! Why didn't we think of that? Would have saved thousands of dollars in engineering and investment in parts. There goes the whole business plan..... _________________ http://www.subarugears.com |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2169 Location: HdG, MD & NJ
Posted: Fri Jun 14, 2013 6:56 am Post subject: |
Subarugears wrote: |
Of course! Why didn't we think of that? Would have saved thousands of dollars in engineering and investment in parts. There goes the whole business plan..... |
That funny! _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
