tmcdade Samba Member
ALB Samba Member
Joined: August 05, 2008 Posts: 3480 Location: beautiful suburban Wet Coast of Canada
Posted: Mon Jan 28, 2013 9:09 am Post subject: |
Not much real info there, just sales/marketing hype....
Bruce- I didn't see your post above until now; how's the trip going? If you have time pm me... _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!!
dalland Samba Member
Joined: September 03, 2010 Posts: 70 Location: norway
Posted: Mon Jan 28, 2013 9:10 am Post subject: |
coolrydes wrote: |
tncsparky wrote: |
coolrydes wrote: |
Hey the day a 2180 makes 200hp without a turbo or NOS is a day I'll stand corrected.
Here is a 1603 NA that makes 195hp
and a 1915 that makes 24ohp
Whoever is running that dyno needs to read the set up manual. I have a 3000hp chassis dyno and I can set it up to show a stock 36hp engine making 100hp. Ill say both engines sounded good, however the jetting or float leve
May have been off on the first engine because you could see a few flat spots on the graph late in the pull. It must be the spark
Plugs making that extra 100 hp or maybe just the set up. |
You really don't know that you are talking shit about probably one of the worlds greatest engine developers in the vw community..
You are shitting you self so hard that it will take months before you are clean again.
And if you want to know, both the 1603 and 1915 engine is still going strong and the 1603 is actually for sale right now... |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Mon Jan 28, 2013 9:13 am Post subject: |
Guys..... let's stay on topic. This is about 5 speed transmissions, not a engine topic.
Expect some posts to be removed. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Jan 28, 2013 9:28 am Post subject: |
Sorry Glenn, "but somebody is wrong on the Internet"
But as to get back on topic, for now people have mentioned, the berg5, the 915 and mendola. but what about other gearboxes?
G 50 for an example?
And are there any good writ ups about installing different boxes, was thinking about bus boxes in bugs or Porsche maybe? |
coolrydes Samba Member
Posted: Mon Jan 28, 2013 9:31 am Post subject: |
Look guys all kidding aside, I too have been in the VW seen since 87' (35 years) building all of my own stuff since then, in fact a VW engine build is what got me into VWs in the first place before that it was all V8 stuff. So for 35 years I have been a hardcore VW guy. I have read everything in print as to how to make hp out of these 4 cylinder engines. I find it very hard to believe that a 1603 or 1915 engine can put down those type of numbers. If you truly can devolve those numbers you should write a book, it would sell like hotcakes. You should also consider competing in the Dyno test that Hot VWs puts out every year, it would be great free publicity.
As for the Rhino cases, the first ones were made due to very poor mag being used in a way of trying to make them stronger, later others improved the mixture of metals and thus made the case much stronger, however they are mostly used in off road applications to help keep the bell housing attached to the main case (these break off with the pounding off of off road racing).
I still stand by my statements regarding the mechanical limits or a type 1 trans and the Berg 5 speed conversion to the type 1 trans. Also I will stand by my disbelief that a normally aspirated type one below 2000cc can make anywhere near 200hp, at least until I see it in person. By the way the dyno contest is flywheel hp not rear wheel hp, so that 1603 or 1915 should be able to blow the rest of the comp away since they can make that type of hp at the rear wheels while driving an entire drive train.... _________________ Kevin "Coolrydes" Zagar
COOLRYDES So-Cal CUSTOMS
MENDEOLA SUSPENSION
THE HOME OF STYLE AND PERFORMANCE
www.CoolRydescustoms.com |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4848 Location: sanger ca
Posted: Mon Jan 28, 2013 9:40 am Post subject: |
Wow! I've been building vw's since 1984. And thats only 29 years |
volkyoo Samba Member
Joined: July 26, 2010 Posts: 417 Location: dominican republic.
Posted: Mon Jan 28, 2013 9:46 am Post subject: |
Noobie Question!
What about the 901 porsche tranny? how is it with the synchros and alll that? the same trouble hard shifting or speed shifting?
what are the Pros and Cons to doing that conversion?
thanks!! |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Mon Jan 28, 2013 9:58 am Post subject: |
mcmscott wrote: |
see what you are missing...you need to step up to the "New Math" _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
Type 5 Joe Banned
Joined: January 18, 2003 Posts: 1795 Location: Oregon
Posted: Mon Jan 28, 2013 10:00 am Post subject: |
I have into VW's since 1982.... 31 years
I also took math in school. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Jan 28, 2013 10:44 am Post subject: |
Rhino case:
I always hear guys mention the top ribbing as though that's the only area where the Rhino is beefed up. The Rhino has double the ribbing on the bottom, too. Show me another factory Type I case where this can be done: https://www.thesamba.com/vw/gallery/pix/296539.jpg
While the later (larger) pinion bearing may have some benefit, there is a trade-off … the later mainshaft needle bearing is pathetic. Either pinion bearing type has adequate aftermarket fastening hardware IMHO.
901 5-spd:
While I'd consider adapting a 915 because of it's added strength, the 901 5-spd has a very weak 1st gear, the same terrible Porsche synchronizing system (prone to catastrophic failure when speed-shifted), and is considerably weaker than the 915 (in areas aside from the 1st gear).
There is presently some effort being made to adapt a Borg Warner style synchro system to 915 transaxles. This will alleviate my main concern with the 915. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Mon Jan 28, 2013 11:15 am Post subject: |
58Dub wrote: |
mcmscott wrote: |
see what you are missing...you need to step up to the "New Math" |
See I've been reading this thread so long even I'm adding a extra 1 in my numbers...... Sorry even I make mistakes, I guess walking on water later is off my things to do list...... _________________ Kevin "Coolrydes" Zagar
MENDEOLA SUSPENSION
Posted: Mon Jan 28, 2013 5:18 pm Post subject: |
Just bustin balls, I have no dog in this fight. I have built berg 5's and many other vw trans. The berg has many shortcomings, venting, 5'th clutch hub ect. But you cannot tell a die hard berg fan that. I am also the only dealer for mendeola in central California, but thats another story we don't want to get into |
Glenn Mr. 010
Posted: Mon Jan 28, 2013 5:26 pm Post subject: |
mcmscott wrote: |
Venting problem has been resolved. _________________ Glenn
Member #1009
#BlueSquare |
Type 5 Joe Banned
Posted: Mon Jan 28, 2013 5:50 pm Post subject: |
You must make sure the oil level is correct with either the Porsche 5 speed or the Berg... Running them low on oil will result in a quick 5th gear failure. |
pupjoint Samba Member
Posted: Mon Jan 28, 2013 6:19 pm Post subject: |
coolrydes wrote: |
how are they "stronger" and an "upgrade" when they have the early style crossshaft, early 4 bolt pinion retainer and webs on top? why is the material superior to the original? are they using aluminium now, correct?
those using Rhino can shed some light on this? |
Type 5 Joe Banned
Posted: Mon Jan 28, 2013 6:32 pm Post subject: |
I think the best trans case is the really late 79 convertible
Anything with a 4 bolt style pinion bearing is a step backwards in durability.
The early Rhino cases were cast from weak material.... I think the newer ones are better. Still not my 1st choice.
I would build a late (76-79?) ssc core
2nd choice would be a 1970 case W/ large pinion bearing and one drain plug.
The Rhino case is for those that don't know better, or for looks.
jsturtlebuggy Samba Member
Posted: Mon Jan 28, 2013 6:59 pm Post subject: |
Show a picture of a 1970 Bug trans case that has no drain plug in differential area.
I really like to see one. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Type 5 Joe Banned
Posted: Mon Jan 28, 2013 7:02 pm Post subject: |
I don't have a picture of one. But I have owned several over the years... One was in an original 1970 bug.
If the case is 1970, the casting differs from the 69 and earlier trans case by having only 1 drain plug, using the late ring nut pinion bearing, and it will have the three locations (untapped) for the 1971 and later bolt-on guide tube for the TO bearing.
I was told that they are one year only. They might be found in some late 1969's or early 1971's.
Here is another thread that mentions the 1970 case...
http://www.thesamba.com/vw/forum/viewtopic.php?t=483151 |
Type 5 Joe Banned
Posted: Mon Jan 28, 2013 7:26 pm Post subject: |
This is a picture of the late style case (on the left)... I found it in the gallery.
