'69Custom Samba Member
Joined: September 16, 2008 Posts: 2497 Location: Ventura, California
Posted: Sat Feb 22, 2014 7:23 pm Post subject: |
I'm confused. You buy a '67 and want to turn it into a '65, but then add the '66 one-year-only "1300" deck lid emblem even though you aren't running a 1300cc engine?
I do love the color! _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote: |
Why tune a big round again and again????? For me.... 1 hour will solve the case |
www.endlesscustomz.com |
Goshen Samba Member
Joined: April 03, 2012 Posts: 833 Location: Miami. FL & Cartagena
Posted: Sun Feb 23, 2014 7:08 pm Post subject: |
'69Custom wrote: |
I do love the color! |
My '67 came with '65 front fenders, '60 headlights, '66 rear decklid
My motor now is a 1641 with mild cam and dual carbs
Ive done quite a number of mods to it...
Here is one of them
Wiper Motor Mod:
I was perplexed trying to figure out why have two separate switches one for the motor wiper blades and one for the electric washer pump.
This is where the washer bottle will go:
I custom made this bracket
Here it is
_________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
https://www.thesamba.com/vw/forum/viewtopic.php?t=659260
My '67 Split Window Bus project :
http://www.thesamba.com/vw/forum/viewtopic.php?t=634144
My '67 Maserati Blue Oceano Bug Build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=541870 |
Goshen Samba Member
jvulich Samba Member
Posted: Mon Feb 24, 2014 1:03 pm Post subject: |
Where did you get the washer switch? I'm building a 65 Beetle that I've installed a 67 2 speed wiper motor and switch and I'm thinking about hooking up an electric washer pump that I've got in my tool box. |
Goshen Samba Member
slo ride Samba Member
Posted: Thu Mar 20, 2014 8:38 pm Post subject: |
nice build thread.
I'm in the throws of my own build and I was curious about your wheel choice. With the 2.5" narrowed beam with drop spindles, drums and 17x7 wheels how do you feel about the clearance of the tires/fenders?
I'm contemplating a 17x7 wheel but I expect to have drop spindles and disc brakes...so maybe a little more offset. How much wider do you think your setup could be before you'd have problems? Ultimately I'm debating between 2 and 4 inches narrower. |
Goshen Samba Member
Posted: Fri Mar 21, 2014 6:04 am Post subject: |
slo ride wrote: |
nice build thread. |
Responses in Black Bold
with the earlier front fenders like what i have the wheels just fit well underneath and plenty of clearance. Doesnt even touch the buckets.
The only issue that i am having is that i didnt shorten the tie rod bars so one wheel turns up to 20 degrees and the other side about 10 degrees. This can be fixed though.
I suggest to call CIP1 and speak to Kris the owner who was able to give me the best tip. I wouldn't go with disc brakes unless you are building a high powerful motor that would require better stopping power but if you are not then no need for disc brakes.
If you do go with disc brakes then a narrower beam would be advisable.
The Radar wheels that CIP1 sells i feel are better quality than EMPI and a lot cheaper too.. i paid $209.00 each for mine.. tell him that you have the Hotvws magazine special..
deant Samba Member
Posted: Fri Mar 21, 2014 6:30 am Post subject: |
nice I like it is that purple or blue? |
Posted: Fri Mar 21, 2014 7:21 pm Post subject: |
The Jewish Guy wrote: |
slo ride wrote: |
Thanks for the info. Mine is a '65, so earlier style fenders for me as well. I haven't settled on an engine as of yet but I am building the pan to accommodate from stock to stroker as I expect to probably get it on the road with a 1600dp in the near term and build something more fun next winter.
Ultimately it sounds like the 4" beam shouldn't be dismissed just yet. |
Goshen Samba Member
Goshen Samba Member
Posted: Mon Mar 24, 2014 7:26 am Post subject: |
I'd be far more concerned about that wire cutting your oil hose from engine vibration than I would be them burning up from header heat. _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
tham64 wrote: |
Goshen Samba Member
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76907 Location: Sneaking up behind you
Posted: Mon Mar 24, 2014 2:26 pm Post subject: |
Here are photos taken today Sunday of my motor that was built by Marshall Painter
I would loose the clear blue cap. While it might fit you're color scheme, they tend to arc and hurt performance. Get a Bosch cap and paint it to match the engine paint. _________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Goshen Samba Member
Posted: Tue Mar 25, 2014 9:48 pm Post subject: |
Beat me to it, Glenn. Good job! _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
tham64 wrote: |
Goshen Samba Member
Posted: Tue Apr 01, 2014 4:27 pm Post subject: |
after 14 months of having to deal with some ripoff body shops i finally get the bug back to put it together..
I started to buy parts for the bug back in Sept 2012 and just now have gotten around to opening the packages and as i open the package that has the outside window scrapers i find them bent... I bought these from Gary Claxton from Bug-Eyed.net in Georgia.
It was hard to believe but after a year of having them i just now got around to opening the makeshift box they made out of cardboard which was not rigid like the boxes Wolfsburg west sends their merchanside out in.
I called up Gary Claxton and told me my situation and he wasn't buying what i was conveying to him because it has been over a year.. i told him to look up my trials and tribulations with my build and google David Hernandez of Oldie Goldie Restorations so he will have an idea of what i have gone through.
So now i have to buy a new set...
I will from Wolfsburg West.
I guess i will have to put these on for now and then replace them after the show n shine vw show _________________ My '64 Pan Meyers Manx Dune Buggy "Lady in Red"
Goshen Samba Member
Posted: Thu Apr 03, 2014 11:07 am Post subject: |
Is that a crooked license plate? _________________ -Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
tham64 wrote: |
