Bliss13 Samba Member
Joined: July 28, 2009 Posts: 185 Location: Northridge, Ca
Posted: Fri Mar 01, 2013 10:30 am Post subject: |
Mike Fisher wrote: |
Drive it while you do the bodywork one fender at a time using a good spray can primer until you are ready to spray it all with epoxy primer. Have solid used fender/door/rocker pieces welded in. |
That was kinda the plan going into it. But I am now considering just stripping it down and putting it in the shop. Once I render it undriveable I will be past the point of no return. As it is, I've been teetering back and forth between hoodride and full restoration, depending on my mood... _________________ 1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro |
Bobnotch Samba Member
Posted: Fri Mar 01, 2013 10:35 am Post subject: |
Mike, what do you call "good spray can primer"? I'm only asking, as most primers absorb water and moisture, and I've had problems with epoxy "lifting" and "crazing" due to spray can primer being underneath the epoxy. This is mostly because the reducers in the epoxy are reacting with the spray can stuff. I prefer to just use the epoxy, and cal it good (for sealing). _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Mar 01, 2013 10:42 am Post subject: |
Bliss13 wrote: |
But I am now considering just stripping it down and putting it in the shop. Once I render it undriveable I will be past the point of no return. As it is, I've been teetering back and forth between hoodride and full restoration, depending on my mood... |
I'd leave it like it is, and drive it until you find the parts you're going to need to fix it. Then put it down for the work. It might be a month or more before you find the parts, or even have them for a shop. That's a month you could be enjoying it. For the cowl piece, you could always use aluminum duct tape to keep any water out. It won't hurt anything, since that section will need to be replaced. I've been doing that for several years, on my 65 Notch. But, this spring it's getting it's turn for work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Mar 01, 2013 10:50 am Post subject: |
Bobnotch wrote: |
Mike, what do you call "good spray can primer"? I'm only asking, as most primers absorb water and moisture, and I've had problems with epoxy "lifting" and "crazing" due to spray can primer being underneath the epoxy. This is mostly because the reducers in the epoxy are reacting with the spray can stuff. I prefer to just use the epoxy, and cal it good (for sealing). |
I buy everything at my local Automotive Paint store and follow their system. They do have or will load compatible spray can primers/sealers. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri Mar 01, 2013 12:14 pm Post subject: |
Bobnotch wrote: |
Bliss13 wrote: |
I'd leave it like it is, and drive it until you find the parts you're going to need to fix it. |
X2
Being that you're in SoCal, parts should be relatively easy to find but that can sometimes take longer than you think. Driving it is a nice perk while you're sourcing parts. It can be easy to get discouraged if you take the car apart and then can't find the part you need to get you into the next phase.
Drive it and enjoy it while it's in one piece, then when you've collected the parts, you can strip it down and do all of the body work at once and put it back together. |
Posted: Fri Mar 01, 2013 5:10 pm Post subject: |
Now, who says that common sense is the least common kind? Haha, thanks guys. That all sounds good to me. _________________ 1970 Sundial Camper
1973 SubaBeetle
Der Speed Shack Samba Member
Joined: April 10, 2010 Posts: 164 Location: Fullerton, Ca 92832
Posted: Fri Mar 01, 2013 6:45 pm Post subject: |
I might have that cowl peice, i'll take a look this weekend. |
Posted: Fri Mar 01, 2013 10:25 pm Post subject: |
vdubspeedshack wrote: |
That would be awesome. I'm thinking this will be the hardest part to find. Thanks. _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Sat Mar 02, 2013 7:50 am Post subject: |
Bliss13 wrote: |
That would be awesome. I'm thinking this will be the hardest part to find. Thanks. |
Joel aka Boo_Koo_Z up in Washington has a couple listed in the classifieds right now. They've still got the dash attached, but you could always have him cut that part out, to save some weight on shipping. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sat Mar 02, 2013 10:10 am Post subject: |
I have a really nice one, pm your cell and ill text a pic. I can probably pull that rocker out for you to if you want, with no holes drilled. Let me know, Randy |
Posted: Sun Mar 03, 2013 9:47 am Post subject: |
PM sent. _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Sun Mar 03, 2013 9:55 am Post subject: |
Pretty nice parts haul this weekend. Picked up hood, deck lid, drivers door (need to trade for passenger door) and two straight rear fenders. The fenders were stripped to bare metal and left outside for a while, so there is some pretty good surface rust on the outside, but I got a really great price for the pair. So I'm close...
1973 SubaBeetle
Posted: Sun Mar 03, 2013 5:31 pm Post subject: |
I havent received a pm from anyone, you can call me at 562-694-0787. Randy |
Posted: Sun Mar 03, 2013 9:51 pm Post subject: |
Damn, I thought you were just busy. I was hoping you'd call Saturday when I was traveling the earth scrounging for parts! I'll give you a call tomorrow. _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Mon Mar 04, 2013 12:05 pm Post subject: |
Bobnotch wrote: |
Bliss13 wrote: |
Joel aka Boo_Koo_Z up in Washington has a couple listed in the classifieds right now. They've still got the dash attached, but you could always have him cut that part out, to save some weight on shipping. |
I looked at the pieces Boo_Koo_Z has, and it appears that the vents are flush with the sheet metal of the cowl. Mine are sunken in. What year did that change? _________________ 1970 Sundial Camper
1973 SubaBeetle
vwfye Samba Member
Posted: Mon Mar 04, 2013 12:24 pm Post subject: |
are the doors from another notchback? i ask because the hinges are different for the notch than for most squares and all fastbacks. keep workin' hard... someone has to _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Posted: Mon Mar 04, 2013 12:25 pm Post subject: |
vwfye wrote: |
are the doors from another notchback? i ask because the hinges are different for the notch than for most squares and all fastbacks. keep workin' hard... someone has to |
I was told the door came off a '64 notch and I did notice that the hinges looked kinda strange to me. _________________ 1970 Sundial Camper
1973 SubaBeetle
Posted: Mon Mar 04, 2013 12:56 pm Post subject: |
Bliss13 wrote: |
vwfye wrote: |
I was told the door came off a '64 notch and I did notice that the hinges looked kinda strange to me. |
If it's off of a 64 you should be fine. 66 was the last year of the 3 bolt hinge for the Variant/Squareback but they continued for the Notchback.
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4190 Location: Pasadena CA/DTLA soon China
Posted: Mon Mar 04, 2013 1:03 pm Post subject: |
All notchback door hinges are the same. Early (pre '66) squarebacks share those same hinges. _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
