doc hopper Samba Member
Joined: December 08, 2006 Posts: 588 Location: California
Posted: Tue Jan 22, 2013 7:57 am Post subject: Go From Dual to Single Carb Setup? |
I've been driving my 64 Micro for the last 14 years with a dual Solex setup. It's a 1641 engine with high lift rockers. When I got the bus it had a single carb configuration (different engine) and sometimes I just long for the simplicity of a single.
Thoughts on a conversion? _________________ "Honesty hath no fence against superior cunning" |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Jan 22, 2013 8:49 am Post subject: Re: Go From Dual to Single Carb Setup? |
doc hopper wrote: |
Thoughts on a conversion? |
does not sound like it would be a problem? what are your concerns? _________________ regards
Uli
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Tue Jan 22, 2013 9:35 am Post subject: |
I'm running a single carb on my 1835 with a mild stroke and cam. Heck in the past I ran a 1641 with a single carb with zero issues. If you decide to ditch the duals, let me know maybe we can work a trade + cash your way. I'd be running duals if I had the extra cash to spare. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Braukuche Samba Member
Posted: Tue Jan 22, 2013 9:44 am Post subject: |
You will notice quite a drop in power, but probably better mileage. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
jeffreyned Samba Member
Joined: June 23, 2012 Posts: 207 Location: Eugene, OR
Posted: Tue Jan 22, 2013 10:57 am Post subject: |
I'm currently running a single PICT-2 on a 1641 dual port. It was supposed to be temporary, while I blow a bunch of air through the PICT-3 and try to get it to idle right. But I've loved the simplicity of the carb and don't mind the power loss, so I'm in no big rush to pull it off. _________________ '69 Bay Window Deluxe
'67 Single Cab Dual Chester |
Posted: Tue Jan 22, 2013 11:39 am Post subject: Dual Carbs |
My bus is primarily an around town kinda rig. Rarely take it on the freeway, not much in the way of hill climbing.
I'm just getting on in years to a point where climbing inside the ass end of the bus to adjust dual carbs and linkage isn't nearly as exciting as it was years ago.
(For that matter, neither is rolling around on the concrete floor doing valve adjustments) _________________ "Honesty hath no fence against superior cunning" |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Tue Jan 22, 2013 12:39 pm Post subject: |
I run a PICT 34 on my 1776, and I agree it is much easier then constantly tuning the duals. Go for it.
The power loss was slight, the gain in mileage was slight, but the joy of not having to adjust the duals for altitude is awesome! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Posted: Tue Jan 22, 2013 12:58 pm Post subject: |
peaceful warrior wrote: |
The power loss was slight, the gain in mileage was slight, but the joy of not having to adjust the duals for altitude is awesome! |
Interesting. I also had a PICT 34 on my 1776 and when I went to the dual Kadrons the power difference was huge. And the mileage sacrifice was also noticable. Maybe it has a lot to do with driving style With those Kads I am tempted to do 70mph plus of the freeway whereas with the PICT 34 I was happy to be at 65 and that is in a '65 bug with freeway flyer trans and big nut RGBs. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
zombievws Samba Member
Joined: July 14, 2012 Posts: 136 Location: greeneville tn
Posted: Tue Jan 22, 2013 6:52 pm Post subject: |
oldschool holley bugspray on my 1835. it starts on a dime. idles and is great around town driving. it has decent power on the hwy. fuel mileage is so so. most people scratch there head or ass and ask why are you using that? it works for me thats why. _________________ unique is what we seek, bizarre is what we are. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Tue Jan 22, 2013 7:29 pm Post subject: Re: Go From Dual to Single Carb Setup? |
doc hopper wrote: |
with a dual Solex setup. |
So they are already single port heads? If not you would have to cut a single manifold and use boots to connect to your dual port heads or else change heads and tins. |
Posted: Tue Jan 22, 2013 7:46 pm Post subject: |
Braukuche wrote: |
Interesting. I also had a PICT 34 on my 1776 and when I went to the dual Kadrons the power difference was huge. And the mileage sacrifice was also noticable. Maybe it has a lot to do with driving style With those Kads I am tempted to do 70mph plus of the freeway whereas with the PICT 34 I was happy to be at 65 and that is in a '65 bug with freeway flyer trans and big nut RGBs. |
You live at sea level, I live at 7000'! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
