Voiden Samba Member
Posted: Fri Jan 25, 2013 11:31 am Post subject: Super beetle baja - daily driver project |
I'm building a baja bug based on a 1302 from 1971.
Will be used as a daily driver and only used on normal roads.
No offroad driving at all.
I use a baja kit for standard beetle so it does not really fit.
I use this kit instead of a kit to super beetle because I think that super beetle kit looks like ####.
But with a saw and a few hours later, it looks like this.
The tires are 235/75-15 on the original 4 "rim.
Same front and back.
A little larger than the original
STOICH Samba Member
Joined: November 26, 2004 Posts: 1100 Location: Fallbrook
NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Fri Jan 25, 2013 12:27 pm Post subject: |
Looks good. I always wanted to see if a standard kit could be made to fit a super. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
thext94 Samba Member
Joined: April 11, 2010 Posts: 1003 Location: Manhattan Beach, CA
Posted: Fri Jan 25, 2013 12:38 pm Post subject: |
NJ John wrote: |
Looks good. I always wanted to see if a standard kit could be made to fit a super. |
x2, do you have a little more info on that? I'm sure a couple guys on here would be interested to see how you did it, me included
Cool start. |
wbrown45 Samba Member
Posted: Fri Jan 25, 2013 3:33 pm Post subject: |
That looks good. I know you don't plan to off-road your baja, but when you cut off the nose of the car you are losing some of the structure for the front suspension. You should think seriously about bracing between the strut towers so they don't start pushing in towards the middle of the car. Even a simple bolt in bracket that mounts on top of the struts, or through the sheet metal will keep it from folding in on itself. I have seen it happen on several light duty street bajas made out of Supers that had no reinforcing. Have fun _________________ OK Thang |
txdunebuggy101 Samba Member
Joined: January 20, 2011 Posts: 611 Location: Houston
Posted: Mon Jan 28, 2013 12:39 am Post subject: |
wbrown45 wrote: |
That looks good. I know you don't plan to off-road your baja, but when you cut off the nose of the car you are losing some of the structure for the front suspension. You should think seriously about bracing between the strut towers so they don't start pushing in towards the middle of the car. Even a simple bolt in bracket that mounts on top of the struts, or through the sheet metal will keep it from folding in on itself. I have seen it happen on several light duty street bajas made out of Supers that had no reinforcing. Have fun |
I agree with wbrown45 ..... you will need to add the strut tower brace to prevent flexing. I think they make a 3 point brace from the towers and the firewall, i think... _________________ I NEVER KNEW I KNOW SO LITTLE, TILL NOW.... |
Voiden Samba Member
Posted: Fri Jan 10, 2014 5:26 pm Post subject: |
Some progress
I have not decided yet what color I should have yet.
Either white or this
The advantage of the brown is coming rust will not appear as much like on a white car. |
Posted: Fri Jan 10, 2014 6:04 pm Post subject: |
Glad to see you are still plugging away with the Baja. Did they import the Rabbit pickups (caddy for you? Golf?) to Sweden? How are things in your "neck of the woods?" _________________ OK Thang |
Voiden Samba Member
Posted: Sun Jan 26, 2014 11:09 am Post subject: |
New exhaust
It has peed his territory like a dog, so I have to replace the valve covers as soon as possible.
HERC Samba Member
Posted: Tue Jan 28, 2014 7:51 am Post subject: |
That head's neither a stalactite, nor a stalagmite .
It looks more like a helictite or just a chunk of limestone. _________________ Herc |
Voiden Samba Member
Posted: Tue Apr 22, 2014 11:51 am Post subject: |
Headlights and indicators
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2675 Location: West Coast (Michigan's)
Voiden Samba Member
Posted: Thu Apr 24, 2014 1:11 pm Post subject: |
ORANGECRUSHer wrote: |
a front brush guard would really fill it out. |
I have not decided what type of bumper I want yet.
Think it will be a modified stock bumper
Tail lights
Side repeaters
tonychavalia Samba Member
Posted: Thu May 08, 2014 10:23 am Post subject: |
How did you get the larger tires on the front wheels without rubbing the front springs? Did you use a spacer? |
Voiden Samba Member
Posted: Thu May 08, 2014 10:31 am Post subject: |
I use 1" spacers with 40mm bolts |
Posted: Fri May 09, 2014 11:25 am Post subject: |
My stock wheels almost rub. I wont go to a 235 but i would like to run at least a 205 of the stock front wheel. |
Voiden Samba Member
Posted: Fri May 09, 2014 1:32 pm Post subject: |
I have tapered springs, bit I don't think it makes that much extra clearance. |
Posted: Tue May 13, 2014 3:43 pm Post subject: |
How do you like the bus mirrors? Did you have to drill out the passenger door. Are you able to fold them sideways? I have debated doing the same. |
Voiden Samba Member
Posted: Tue May 27, 2014 12:29 pm Post subject: |
Bumper brackets and extra headlights.
I used square tubing and welded them into position in the beam that connects the spring tower with the frame head
A little long so far, but will be shortened soon
Voiden Samba Member
Posted: Wed Jun 25, 2014 2:06 pm Post subject: |
Racing bonnet locks and handle
Side bars
