rking6 Samba Member
Joined: June 08, 2010 Posts: 140 Location: Long Beach Ca.
Posted: Fri Feb 01, 2013 10:33 am Post subject: Heater control |
Help,, while replacing my twisted heater cable in my 63 EZ ,non-walkthrough, I noticed there wasn't any pin in the cylinder that keeps the threaded sleeve/cable from being twisted around. The pin allows the threaded sleeve to go only straight up and down..Has anyone tried to peplace the pin in the cylinder ?? Does anyone know how far down the pin should be placed.. I can't find any evidence as to where the pin was before I sheared it off 25 yrs. ago.. Thanks for your help. Bob KIng, 63 EZ, Long Beach , CA |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
rking6 Samba Member
Posted: Fri Feb 01, 2013 6:24 pm Post subject: |
Sorry for the confusion,, No, it is where the threaded sleeve slips into the body of the Bus..There is a notch in the sleeve , when inserted, the pin,keeps it from rotating.. And only allows the sleeve to go straight up/down .. Hope this helps.. Thanks for your help.. Bob KIng 63 EZ, Long Beach, Ca |
rking6 Samba Member
Posted: Tue Feb 05, 2013 10:37 pm Post subject: heater control |
Hey,, thanks Everett,, I thought I was going crazy.. I can't even feel a nub on mine.. I am the second owner, bought it in 69.. I kind-of remember forcing the threaded sleeve down the cylinder many years ago, and breaking something off.. anyway thanks for your help.. You are the best !! Bob King,63 EZ, long Beach, Ca.. Maybe see you at OCTO, the 23 rd,,, |
rking6 Samba Member
Posted: Thu Feb 07, 2013 7:55 pm Post subject: heater control |
Hey, thanks for the photo,, I can see it.. Do you think that nub keeps the threaded sleeve from being twisted ?? I put mine in, with lots of grease. It seemes to be working OK if I turn it very slowly. Anyway it is only cold in Long Beach a few days a year. Thanks again, Bob King, 63 EZ Long Beach,.Ca.. |
rking6 Samba Member
Posted: Fri Feb 08, 2013 12:42 am Post subject: heater control |
I need a nub......Thanks for your help,,,Bob, KIng 63EZ, Long Beach , Ca. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Feb 08, 2013 10:42 am Post subject: |
Do the heater cables come pre-bent/divided in lengths or do you have to decide where to bend it? |
rking6 Samba Member
Posted: Fri Feb 08, 2013 10:50 am Post subject: Heater control |
Yes , they do come pre-bent,, The longer side goes on the right. Good Luck... Bob King 63 EZ ,long Beach , Ca. |
stevo Samba Member
Joined: January 22, 2004 Posts: 908 Location: the eugeniverse
Posted: Tue Aug 26, 2014 3:04 pm Post subject: |
i'm seing my nub worn enough to allow the threaded sleeve to turn and twist my heater cable, ..again. g'dang that's a tough spot to build up a nub. looking like a seasonal wired/unwired heater life for this northern bus. anyone notice the same on theirs? |
rking6 Samba Member
Posted: Tue Aug 26, 2014 3:45 pm Post subject: |
Hey,, I have the same problem.. My NUB is gone. But mine works fine...I searched everywhere for the best quality cable I could find,,, Some of the cables are stronger than others .. The best one I found was super strong,, almost seemed thicker than the others... Also very shiny ,,,I made sure the cylinder moved smoothly up and down ,,lots of grease in the cylinder..,,.. Because the cable is sooo strong the cable did not twist when turning the heater knob, pulling open the heater boxes... I just turn it very slow.. I live in southern Ca.. so rarely use it,,, I can't remember where I got it... If I can find where ,,I'll post it,, Anyway,, good luck !!! If you get it working, post how you were able to do it.. Thanks, Bob King 63 EZ, Long Beach, Ca... |
