rammintwins Samba Member
Joined: September 30, 2011 Posts: 124 Location: carson,ca
Posted: Sat Feb 02, 2013 12:51 pm Post subject: Assembly lubes what do you use? |
Just lookin to see what everyone uses for assembly lubes, sealants etc etc
use arp lube for torquing down ? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sat Feb 02, 2013 1:12 pm Post subject: |
I use white lithium grease on stock builds and Torco cam lube in hi-po builds.
For the case I use Permatex Aviation.
Around the cylinders I use Permatex Ultra Copper.
For the flywheel seal I use white lithium. _________________ Glenn
Member #1009
#BlueSquare |
kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Feb 02, 2013 1:26 pm Post subject: |
For me:
What ever oil you use (for me 20/50 bradpenn) 50/50 mix with lucas oil on all bearings flywheel seal ect..
Cam lobes and lifter faces: lots and lots of moly grease
Lifter bodys: little bit of moly and 50/50 mix on top of it
As for cylinders head/case nuts/washers... either grey black or copper works fine... all does the same shit. But only copper silicone on exhaust flanges. No more gaskets for me.
Case halfs yamabond
Oil pump grey black or copper on case side, and curil on cover side. With moly grease between pump gears. And sealing nuts (RED SIDE DOWN!!!) _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
modok Samba Member
Joined: October 30, 2009 Posts: 26740 Location: Colorado Springs
Posted: Sat Feb 02, 2013 1:37 pm Post subject: |
Remember that when dealing with engines, the torque specs assume you lube the fastener with engine oil unless it says otherwise. If you use ARP's lube, you should drop the values maybe 10% since it has less friction. If you use regular oil on a rod bolt instead of arp lube, you will have to increase the torque by 10% or more.
Best thing to do is follow the darn instructions
valve guides/pushrods/rockers/lash adjusters and other stuff that needs EP lube, please use GEAR OIL instead of engine oil or grease. |
Posted: Sat Feb 02, 2013 1:39 pm Post subject: |
lol modok, istructions? Men don't read instuctions |
slalombuggy Samba Member
Posted: Sat Feb 02, 2013 6:07 pm Post subject: |
LUBES
Valves - white lithium assembly lube
Springs 5w30 before firing engine
Rockers - straight white lithium assembly lube
Pistons - WD-40 (mixed with 5w30 if engine won't be fired for a couple weeks
Crank, rods and piston pins, endplay shims - white lithium lube mixed with 5w30
Rear main - white lithium assembly lube
Lifters - white lithium lube/oil on body, moly lube supplied by cam grinder on head.
Cam - lithium assembly lube/oil on bearings, supplied moly on lobes
Oil pump - pack lightly with straight lithium assembly lube just enough so the gears have a good coating to seal them
Sealants
Barrels/shims, Generator stand, fuel pump block, case washers, deep sump to case - Permatex Right Stuff
Head studs that are open to the inside of the case - Permayex thread sealant
Full flow fittings - Permatex thread sealant
Case plugs - Loctite Blue
Case halves - Permatex aviation gasket shelac
brad
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Sat Feb 02, 2013 6:57 pm Post subject: |
I use Lucas for assembly lube. Sticky, stays in place, and never had an issue. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sat Feb 02, 2013 7:14 pm Post subject: |
Just changed over to Lucas Assy Lube for my builds, I like what I've seen so far _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Kevinx Samba Member
Joined: November 08, 2012 Posts: 186 Location: Gainesville Florida
Posted: Sat Feb 02, 2013 7:16 pm Post subject: |
Permatex red liquid assembly lube for bearings and CRC Moly-Graphite engine assembly grease on everything else.
NEVER EVER use white lithium in an engine build; on an engine with a element style filter. It WILL fill the pours in the element, and not break down under pressure or heat to a passable soluble. White Lith is for door hinges _________________ In life there is but one way out |
58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sat Feb 02, 2013 7:17 pm Post subject: |
Ive always used CRC moly assembly lube. Better or worse than others??..I don't know, but Ive never had an issue with it. _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
flyboat Samba Member
Posted: Sat Feb 02, 2013 7:25 pm Post subject: |
GM EOS (Engine Oil Suplement) for the entire build, unless it's going to sit for a while then I use white lithium grease _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Feb 02, 2013 7:29 pm Post subject: |
58Dub Samba Member
Posted: Sat Feb 02, 2013 7:37 pm Post subject: |
yep, thats it _________________ 58 Beetle (now just a pile of parts in the corner)
downsbs Samba Member
Joined: July 17, 2009 Posts: 540 Location: Avondale, AZ
Posted: Sat Feb 02, 2013 8:01 pm Post subject: |
Lucas assembly lube. I have been using it for a couple of years now and am happy with it. _________________ 1956 Rag W/ Semaphores |
Posted: Sat Feb 02, 2013 9:45 pm Post subject: |
i was goin with lucas on the assembly lube
cam shield for the cam as well
brad penn oil
blue and red loctite
copper gasket sealant
curil t of the case and oil pump |
SRP1 Samba Member
Posted: Sat Feb 02, 2013 11:07 pm Post subject: |
Worst assembly lube on the planet, well maybu good for oil filled wheel baerings.
Heres the deal guys, the bottom line is the engine will live its life on what????????????? OIL! Plain and simple.
Use what to use a high quality oil that has a little more viscosity than what you will be normally running. So a 20-50 is good for assembly.
I have my preferences, it happens to be Amsoils 15-50 Dominator race oil for assemly, or GM's EOS, both really good stuff. Bearings, valves, rockers, everything except for the rings which I only use the Ackerly & Childs Xtreme ring oil on.
The reason is you want the assembly lube to flow out, and blend in with the engine oil your running almost immediately to keep the bearing cool and lubricated. If it does not do that the engine will lock up, and or score the bearings on start up.
Fire it, build pressure and be gone, that is a good assembly lube. The grease as stated above or with lithium grease, hell any grease does not flow out well, nor does it give the hydrodynamic barrier that oil will.
Now cams, that's a little different, but not much. You need a little EP protection for the first couple revolutions, but that too needs to be gone (well it will be gone) almost immediately on start up. So it's all about the oil and quality of the oil your using.
Besides I hate building an engine that feels "tight" because it has some sticky grease crap stuck in the bearings. You can't get a good feel for it, I like the bottom end to float as it turns, if it doesn't it aint right.
So again, high quality motor oils with a good ZDDP add pack are your best choices for engine assembly. I have seen first hand the unnecessary wear that grease will put on the rotating assembly, vs high quality motor oil time and again. It's not worth it.
And of course you always prime the darn engine before firing it right! |
Posted: Sat Feb 02, 2013 11:11 pm Post subject: |
Nice right up srp! |
Posted: Sat Feb 02, 2013 11:20 pm Post subject: |
The moly grease only belongs on lifters/cam and in oilpump for priming reasons. I use a mix of bradpenn and lucas because I too believe in high quality oil for assembly lube and lucas gives it a little extra stick so nothing runs or drips too easy, and stays put when sitting on the shelf or what not. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sat Feb 02, 2013 11:44 pm Post subject: |
I use brad penn assembly lube and have.been happy as a peach with its consistency , stickiness and quality. Aviation permatex on the case sealing edges and grey ultra on the cylinders. I put aviation on tube seals too. I mix bradd penn and whatever cam assembly lube on the lifter faces. I use castrol gtx and zddp additive in my oil. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
laker Samba Member
Posted: Sat Feb 02, 2013 11:54 pm Post subject: |
Permatex aviation on case |
