s60088 Samba Member
Joined: January 25, 2013 Posts: 159 Location: New York City
Posted: Sun Feb 03, 2013 8:29 am Post subject: Where to buy L90D Pastel White paint? |
The L90D Pastel White? I've seen PaintScratch.com only ans read that Wolfsburg West hassome. I've read about using Rustoleum under final coats. Is that really acceptable? |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Feb 03, 2013 9:51 am Post subject: |
www.towerpaint.com will mix it spray cans/clear coat & touchup paint. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ncstagger Samba Member
Joined: June 04, 2010 Posts: 284 Location: Fayetteville, NC
Posted: Wed Feb 13, 2013 7:32 am Post subject: |
Wolfsburg West does have it available in spray can, for interior only. _________________ 71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking |
ccpalmer Samba Member
Joined: September 17, 2006 Posts: 3850 Location: Ann Arbor, Michigan
Posted: Thu Feb 14, 2013 6:24 am Post subject: |
Your local automotive paint store should be able to mix you up some. _________________ '71 Westy |
antech Samba Member
Joined: December 27, 2013 Posts: 1 Location: MORRO BAY
Posted: Sun Aug 09, 2015 8:16 pm Post subject: L90D paste white, it's not the same white anymore |
Just a bit of heads up on L90D aka pastel white. I have been dealing with this issue and it's a big headache. The original Pastel white that is on your van will not match any L90D that you will have mixed to code at any paint suppliers. It will come out as an ugly yellow/white, vanilla like color. If you were to compare, put them all next to each other any 82-91 vanagon or westfalia with the L90D paint code, you will notice that they vary in color also, however they are a much brighter white as compared to modern day paint code L90D. The solution and the only solution is to have them color match to your existing white , use the door jamb areas as a comparison.
VW had a wide variety of ways to mix their batches of paint way back when, we are talking 1000's gallons of paint mixed per batch, thus many variations in white although they had the same exact paint code of L90D.
I have the same problem with Savanah beige metallic, modern day code will be off, but I do like the new Savanah beige metallic mixed to code, it's a much richer metallic color.
However if you have any other colors like bordeaux red, orly blue, wolfram grey metallic, the color match is pretty darn good if you were to have your entire van repainted using just the paint code provided. |
