darkfox89 Samba Member
Joined: January 20, 2012 Posts: 13 Location: Burleson, TX
Posted: Fri Feb 08, 2013 3:59 pm Post subject: Simple question about oil temp sender |
Is this:
A place I can put this?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VDO-323-064
What is that plug called? I am guessing this is what you have if you have dual relief? The one on the pulley side is the oil relief plug, but is there a separate name for this one on the other side?
(thanks goes to neil68. this is his picture) |
Posted: Fri Feb 08, 2013 4:58 pm Post subject: |
Anyone? |
74autobot Samba Member
Joined: January 31, 2013 Posts: 65 Location: Texas Corners, MI
Posted: Fri Feb 08, 2013 5:13 pm Post subject: |
if it does fit there how accurate would the readings be? mine is located on the bottom and seems to give an accurate reading. im not an expert with acvw and am just thinking out loud. _________________ For once you have tasted flight you will walk the earth with your eyes turned skywards,for there you have been and there you will long to return. |
owdlvr Samba Member
Joined: June 23, 2008 Posts: 684 Location: Squampton BC
Posted: Fri Feb 08, 2013 5:27 pm Post subject: |
That's where I've got one of my sensors.
From another post I made on the samba:
owdlvr wrote: |
I can confirm that the relief plug sensor reads lower due to air moving over it.
My setup includes three sensors, and a rotary switch to select which one shows up on the oil temp gauge.
Sender in the Feed line to engine "F":
Sender in the dry sump Tank "T":
And a third sender in the Oil pressure relief plug position (flywheel end) "E". (not pictured). You can see a significant difference between the three sensors as the engine heats up. Obviously the oil tank is the slowest to come up to temperature with 10L of oil in the whole system. Once the system is up to normal operating temperature (200deg), the temp stays relatively stable across all three sensors. The setup allows me to watch the tank to determine when the system is fully up to temp and ready for racing, I use the engine sensor to monitor temps normally, and switch to the feed if I'm seeing increased oil temps and/or want to diagnose the cooler/fan setup.
But my post started with being able to confirm the relief case sensor reads cool due to airflow over it. How?
I run a skid plate underneath my engine. With the plate installed, my oil temps are essentially exactly the same across all three. Remove the skid plate, and the sensor in the relief plug will drop 15-20deg. The amount of temperature drop is directly related to the traveling speed of the vehicle. Stop-and-Go around town and the temp senders match, hit the highway for a length of time and 20deg cooler. The airstream _does_ effect that sensor location.
-Dave |
I will add that I've got a 1776, with all tinware installed, factory thermostat and flaps.
-Dave _________________ ---
Instagram: @DaveHord
1971 1302s - Salzburg Tribute the #RallyBug
1958 Beetle
1975 Beetle
1973 Super Beetle
1993 C3500 with Cummins swap
1967 MGB
1963 MG Midget |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
