chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Posted: Sat Feb 02, 2013 10:26 am Post subject: winches |
was just wondering if a Harbor Frieght 6000lb winch would be worth the investment or is the something i should go for a known good brand??? _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
jsturtlebuggy Samba Member
Posted: Sat Feb 02, 2013 10:37 am Post subject: |
I am using one of their 5,000lb one on a buggy that weighs as much as a Baja or more and it works good for me.
It has pulled the buggy up a man made rocky hill at the off road park without any strain.
Also has pulled a Baja that high centered on rocks. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Feb 02, 2013 10:53 am Post subject: |
Almost all low end winches are made in China..... I have a 10,000 lb winch on my Jeep, and the Jeep weighs in at about 4,500 lbs and winch will pull jeep across flat ground with all four wheels locked....
We were stump pulling with winch/jeep and with all wheels locked we were able to snap 5/16 chain choker around stump when stump refused to budge.... Almost had winch cable through radiator...
Guess what I am trying to say is that most Chinese winches are pretty close to being what they advertise to be, though I am sort of anti-Chinese products there are a few that are reasonably well made....
You could buy Warn at double the dollars but most "stucks" are mere a matter of just to get vehicle to move some so it can get traction.....
A 5,000lb winch on a 2,000-2,500 lb car (assuming its either a rail buggy or Baja) should not cause any issue....
One thing I learned immediately was to take plug apart on remote control and reconnect the wires ......
GBHgpJON Samba Member
Joined: March 10, 2007 Posts: 73 Location: North Devon, England..........
Posted: Sat Feb 02, 2013 1:18 pm Post subject: |
Bit of a hijack here.....but I was thinking about getting a winch for my Glass Buggy, but will I be wasting my time as I'm running a dynamo? |
Posted: Sat Feb 02, 2013 1:47 pm Post subject: |
GB,
If you are worry your generator will not handle it, install a 2nd battery.
This what most people do if planning on doing a lot of winching.
Mine is mounted on a glass body buggy.
I will have to find pictures to show how I mounted it. _________________ Joseph
Elrod Motorsports
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Sat Feb 02, 2013 4:19 pm Post subject: |
rule of thumb in the 4WD world is winch should pull 2.5 times the vehicle weight. mud really, truly sucks and you need to have the beans to overcome said suction. _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5408 Location: Holland, MI
Posted: Sat Feb 02, 2013 6:42 pm Post subject: |
Where is a good place to mount one? My rail frame is powder coated, so I don't want to cut into it and weld mounts to the front. Can It be mounted on a steel plate bolted to the two brackets where the beam bolts to the front clip? _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Posted: Sat Feb 02, 2013 7:23 pm Post subject: |
Vanapplebomb wrote: |
Where is a good place to mount one? My rail frame is powder coated, so I don't want to cut into it and weld mounts to the front. Can It be mounted on a steel plate bolted to the two brackets where the beam bolts to the front clip? |
I would adapt a plate with clamps to front beams for a mount....Clamps I am thinking of is pretty much what sand/woods rail community use to mount beams to chassis...
Something similar to these....
http://www.aa-mfg.com/pdshop/shop/item.aspx?itemid=191
norcalracer Samba Member
Posted: Sun Feb 03, 2013 9:03 am Post subject: winch |
there was a article/comparrison in a past 4-wheel drive magazine and the harborfreight winch rated very well against Warn,Ramsey,superwinch. |
Posted: Sun Feb 03, 2013 9:26 am Post subject: Re: winch |
norcalracer wrote: |
If you start looking at all the low end winches ($500 or less), they all look like they come from same factory in China.....
Another thing you want to consider is "accessories"....
They make "recovery kits" (generally sell for about $100-$150)... But you can assemble something yourself...
A "recovery" strap... Usually a 20 ft long synthetic material that does not stretch under strain (like cheap nylon tow straps)... Yes there is a difference...
A tree strap.... 6 foot strap to go around tree so you do not have to wrap cable around tree and "cut" it (greenies hate this and you too for doing this) ...
A snatch block (pulley), it can double your pull or route winch cable around corners for you (check load ratings) ....
A couple of large shackles to "connect" everything up (check load ratings) ...
A pair of leather gloves to handle cable ( a winch cable after a couple of uses get whiskers that will eat you) ...
A 8-10 foot length of heavy duty chain with hooks on both ends (good from "connection" up to a vehicle with no dedicated anchor points)...
A bag to put everything in....
If you have a winch but no way to anchor it to a tree or another vehicle its just a useless piece of dead weight on buggy....
The biggest no-no of all is wrapping winch cable around a tree or vehicle bumper and putting hook back on its self... This causes a kink in cable and it is forever damaged and weakened and will probable fail when you need it most....
GA_Boy Samba Member
Joined: October 10, 2006 Posts: 1405 Location: Jefferson, GA
Posted: Sun Feb 03, 2013 12:20 pm Post subject: |
Nice post Dale. Another thing is on a hard pull throw a blanket or a couple of coats or towels over the tight cable so if it breaks the backlash will be reduced. A snapped cable can remove your head, windshield, or anything else that gets in the way. Before you hook up you can thread the cable through an old coats sleeves and it won't fall off.
Marvin |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sun Feb 03, 2013 12:21 pm Post subject: |
Old Subarus had a light duty winch option, Might be hard to find though.
_________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
Posted: Sun Feb 03, 2013 1:09 pm Post subject: |
GA_Boy wrote: |
Marvin |
OOPS .... Forgot to mention that.... Recovery kit has "blanket" with pockets you fill with dirt or rocks to create weight ( instructions state about 5 pounds) to prevent "back lash" if cable snaps or you loose "connection"...
Posted: Sun Feb 03, 2013 2:58 pm Post subject: |
Here a couple of pictures of my winch mount.
Roller fair lead is mounted through front skid plate and to winch mount.
I welded brackets to front axle for winch mount since the axle beam is different than a stock Bug front end.
Elrod Motorsports
Posted: Sun Feb 03, 2013 9:38 pm Post subject: winch |
joseph, ditch the cable and get you a rope cable with a smooth fairlead so much better than cable, and stronger |
Posted: Mon Feb 04, 2013 7:28 am Post subject: Re: winch |
Do you know what a "synthetic winch cable" costs?... They ain't cheap......
Posted: Mon Feb 04, 2013 8:22 am Post subject: |
Jerry,
The amount of use and how long the cable will last as compared rope, I am going to stay with what I have.
That is unless someone decides to donate one to the cause. _________________ Joseph
Elrod Motorsports
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Mon Feb 04, 2013 8:46 am Post subject: |
You should always bring winches along. They don't eat much and they sure look good in bikinis. Oh wait, that's wenches. My bad!! _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
josh7652 Samba Member
Posted: Tue Feb 05, 2013 2:24 am Post subject: |
I use a Warn M8000 on my Jeep and absolutely love it. I've pulled myself, and others out of some really tough situations. Also good for pulling stumps and fence posts too! I did upgrade to AmSteel blue synthetic line, and whew is it expensive, but at 8lbs WITH the hook, the weight savings is unreal. If you decide to go synthetic line, make or buy a cover. You don't want the UV rays to degrade the fibers prematurely. As mentioned before, it's expensive! The supplied cable works just fine, with no real maintenance requirements other than a regular shot of WD-40.
I too entertained the cheaper Chinese winches, but when you NEED it, you need it to work! Recovery is not a place to skimp out on, especially if you like to explore alone. Save your pennies and buy quality. You'll be glad you did. I also mounted my solenoid under the hood with a gigantic home brewed harness to ward off trail damage
I got mine through Amazon, free shipping, and every now and then they go on sale. Mine had a Warn factory rebate ($50 or $100, I can't remember right off hand)
http://www.amazon.com/WARN-26502-M8000-8000-lb-Win...warn+m8000 |
mutantfab Samba Member
Joined: September 09, 2012 Posts: 85 Location: Bay Area
Posted: Tue Feb 05, 2013 3:36 pm Post subject: |
Chubby
I have a build I'm working on right now putting a 4wd syncro drivetrain into a fiberglass buggy. My projected weight is 1800lbs trail ready. My goal is to keep it as light as possible. After searching I settled on a utv 4500lbs superwinch with synthetic lead. I got this on amazon for $260. With synthetic it should weigh 22lbs, 16" long and 5" in diameter. While I can't attest to it's performance, superwinch is know for building a good winch. 1800lbs X 2.5=4500lbs. Compact, light weight, good planetary gear set and decent amp draw. Hope this helps.
Brian |
