61 T1 rear seat mounting?
thekera
thekera is offline
PostPosted: Sat Feb 16, 2013 11:55 am    Post subject: 61 T1 rear seat mounting? Reply with quote
K, just got my headliner done in the 61. The rear seat was just sitting in there since I bought the car. How does the back rest portion bolt on? Looks like just 2 holes on each side of the car unthreaded. Is it supposed to be threaded or a bolt nut stack up, and if so what size? Thank you
ottvw
ottvw is offline
PostPosted: Sat Feb 16, 2013 12:00 pm    Post subject: Reply with quote
It takes a special bolt. One on each side at the bottom of the door panel. Not sure on the size though.
Save a tree eat a beaver
RareAir
RareAir is offline
PostPosted: Sat Feb 16, 2013 2:24 pm    Post subject: Reply with quote
The holes on the sides to mount the rear seat back usually has a welded nut on the backside. It is a 8mmx1.25 nut-
The mounting bolt is usually a shouldered style.-
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
thekera
thekera is offline
PostPosted: Mon Feb 18, 2013 6:34 am    Post subject: Reply with quote
K, my threads look striped. Might need to just tap them. I'm missing those bolts. WW the place to get those shoulderd bolts?
wayne1230cars
wayne1230cars is offline
PostPosted: Mon Feb 18, 2013 8:16 am    Post subject: Reply with quote
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111885591
Wolfsburg West stocks this part.
1960 beetle
1970 beetle convertible
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Feb 18, 2013 3:06 pm    Post subject: Reply with quote
The originals didn't look quite like that, but those are the ones that are available new. This is what they originally looked like...
wayne1230cars
PostPosted: Mon Feb 18, 2013 5:06 pm    Post subject: Reply with quote
Another option from the Samba classifieds. http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
Notice that there are seat mounting bolts and also seat belt mounting bolts. They are different. Your 1961 would not have had seat belts from the factory.
1960 beetle
arizonabuckeye
arizonabuckeye is offline
PostPosted: Sun Jul 26, 2015 3:25 pm    Post subject: Reply with quote
On those WW bolts... Anyone know the length of the shoulder?
arizonabuckeye
PostPosted: Mon Jul 27, 2015 8:32 am    Post subject: Reply with quote
I should say - I bought a rear seat from another Samba-er and there is a pretty decent gap - around 1" when pushed to one side. Just wanting to see if those will work or if I need to figure out something else.
