glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Fri Feb 05, 2016 7:35 pm Post subject: Re: cable tubes ever wore through |
glideking wrote: |
The clutch tube...back end had broken loose. I rewelded with a thicker bracket. Yours? |
All mine have broke here.
I put criss-cross clamps to hold mine. Pic of bracket you made? I've never had a tube wear through although it sure seems possible where it curves. |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Posted: Sat Feb 06, 2016 11:47 am Post subject: Installing controls |
Here is the picture you requested.
Years ago when I did not weld very well I had a muffler shop
weld this bracket on to the torsion housing to repair my lose clutch cable tube.
Before and after. Can you believe this is the same truck?
I am slowly gaining control!
Welcome to 1959. There are many differences from other years. There are choke and fuel tap controls under the seat. The shifter is straight. Unique to this year +/- is the small steering shaft hole combined with the more rearward positioned hand controls.
What will I get done today?
Kurt _________________ "The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639 |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Tue Feb 09, 2016 2:25 am Post subject: Transaxle clean and paint |
I had been putting off the inevitable. Sooner or later I was going to have to clean those greasy parts. When I started I did not want to touch them because I would get dirty. Now I don't want to touch them because I will get them dirty.
Do they always end up looking like this?
Cleaned with Purple Power and a brush.
I used a wire brush here. Big mistake! The steel from the wire gets embedded into the magnesium and causes rapid decay.
So I media blasted the case to clean that up. Clean magnesium will oxidize into a pile of white powder with some gears in the middle unless it is protected by something.
Oxygen can get through paint so that will not stop the decay. I used chromium trioxide solution to passivate the surface prior to epoxy primer. That was a lot of effort to do safely. The stuff is extremely toxic.
Like a bronzed baby shoe.
I will install the axles and RGB with the transaxle in place.
Saul Koll Samba Member
Joined: September 28, 2008 Posts: 191 Location: Portland
Posted: Tue Feb 09, 2016 3:03 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck&quo |
Wow! That case looks amazing.
Well too, the rest of the the truck..
Not so funky truck.
Great work! _________________ "I wish you could smell the smell that's coming from the bus"... |
V-Dub Guy Samba Member
Posted: Tue Feb 09, 2016 7:41 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck&quo |
This turned out great Kurt!!! Every time I see a new post, it gets me motivated to get out there and work on my SC. Keep'm coming!!!!! |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Tue Feb 09, 2016 8:53 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck&quo |
I'd recommend putting the axles, tubes and RGB's together before putting the trans in, as you wont be able to accurately set the end play in the axles with the gaskets, in the bus. Also one of the side cover nuts is partially blocked by the frame horns. You dont want a leak in this area |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Feb 09, 2016 9:44 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck& |
chrisflstf wrote: |
Ditto. Plus you do not want those axles to be too loose or too tight, but just right. Doing that in situ will be a major pain. _________________ In Stereo, Where Available! |
Duder Samba Member
Joined: July 14, 2009 Posts: 39 Location: Torrance, CA
Posted: Tue Feb 09, 2016 11:44 am Post subject: Installing trans before RGB |
I had considered those issues too. Moving a fully loaded rear end in is no walk in the park either. I had heard it would be difficult to install axles and RGB with trans mounted but I had never tried it myself until now. It took three tries to get the end play right with the correct number of gaskets. I use a twisting motion to check. My box wrench was able to reach the bottom cover nut as well. I cannot say which I like better. Perhaps I had less chance of scratched paint this way. Each procedure has it's merits. I would do it again.
Parts clean, clean, clean!
I used a brake drum clamped to my steel table to hold the stub axle for torquing the nut. That is the breaker bar and socket I used. I almost forgot to put in the upper bearing first before I peened the new nut.
I used a large nut, washer and bolt to draw the axle out into the bearing far enough to get the circlip on. VW threaded the end of the axle. How thoughtful.
If you butter up both sides of your gasket it won't know which way to fall on the floor.
Inside of the RGB housing. I used Loctite 680 Bearing Retainer on all the bearings.
Bead of RTV around the bearing before the brake backing plate.
I used this photo the next morning to confirm I had put both O rings on and used sealer. (edit) Only small O ring was used.
Spring plates will have to wait until the rotisserie is off so I used the shock to hold the axle in place for now.
The driver side RGB is one of today's projects.
BarryL Samba Member
Posted: Tue Feb 09, 2016 7:19 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck&quo |
Killer and museumesque.
Did you use a gasket also between the RGB housing and the backing plate? Only the little o-ring (stub axle one) is used on bus, fwiw. |
Posted: Tue Feb 09, 2016 9:05 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck& |
Thanks BarryL. I did take that extra O ring out. Only had one gasket in the kit. Used only RTV on the back of plate.
The bug does not have an interesting history. Yet...
Transaxle nosecone and mount are stock VW.
I piled up the shims and O ring on the axle so I don't have to press off the bearing each time I do a test fit. I pulled each new gasket through the hole and torqued it down. When it had the right "feel" I used RTV on the O ring not the gaskets. I ripped the unused gaskets off. It took four gaskets on this side and only one on the other.
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Wed Feb 10, 2016 11:43 am Post subject: Re: Transaxle clean and paint |
Very nice. Very, very, very nice. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
tonyx Samba Member
Joined: March 10, 2012 Posts: 15 Location: Nanaimo B.C.
Posted: Wed Feb 10, 2016 5:49 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck&quo |
Kurt I think you broke the view counter , I hope the silicon brake fluid doesn't taste as bad as the regular stuff |
