kjvforme Samba Member
Joined: September 11, 2009 Posts: 222 Location: Oregon
Posted: Sun Feb 17, 2013 2:43 pm Post subject: The new solid state Voltage regulator by Bosch |
My Sister-in-laws 73 Super had a red gen light come on and she asked me to take a look at it. I looked at the the wires which appeared to be fine. Replaced the brushed as they looked worn down and still had the same problem. I had seen an advertisement for the new solid state voltage regulator from Bosch on CIP1 and decided to order it. Got it in, it was a direct replacement, mounting holes the same and the terminals were labeled exactly like the original. Started the car red light off after starting and put out 13.8V in idle. If your a purest and have to have an original equipment regulator then pass this by, but if you want an upgrade with out paying the price for an alternator with solid state components than this is the one for you. |
jlex Samba Member
Joined: January 23, 2009 Posts: 2902 Location: NW Pennsylvania
Posted: Sun Feb 17, 2013 4:37 pm Post subject: |
I've been running my SS regulator for 3 years now and it holds right at 14.1 v at speed. Reliable so far... _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17285 Location: Left coast, Canada
Posted: Mon Feb 18, 2013 12:11 am Post subject: |
Is this a regulator that goes under the back seat? _________________
jlex Samba Member
Posted: Mon Feb 18, 2013 5:25 am Post subject: |
Yes.... _________________ jlex.
'70 std. "Elsie"
'88 Carrera |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Mon Feb 18, 2013 7:01 am Post subject: |
They really aren't that "new" anymore. I was working at a VW parts shop back around a dozen years ago when those regulators first started showing up. I decided I'd be a guinea pig as to if they were any good or not, and put one on my Baja bug. And it did fine - no more fluctuating voltage, longer brush life. The only two things I don't like about the solid state regulators is the fact that the whole top "cover" of it is D+, unregulated generator output, so you have to be careful to never let anything metal contact it when the engine is running or you'll get a short. The other thing is that they are kind of ugly compared to the originals, but that's only a concern where you mount it on the engine.
-Andy |
