Father and Son Baja Bug- Daily Driver
Page: Previous  1, 2, 3 ... 11, 12, 13 ... 24, 25, 26  Next
HERC
HERC is offline
PostPosted: Tue Apr 22, 2014 7:50 am    Post subject: Reply with quote
Me too...Sheesh, you'll have kids of your own soon... Cool Wink
Herc
BajaRag
BajaRag is offline
PostPosted: Fri Apr 25, 2014 11:37 pm    Post subject: Reply with quote
Hopefully not too soon Smile I still have to get through college.
The Magnaflow exhaust that we put on the car is perfect for my liking. It idles at low decibels and isn't loud at low RPM's, but when you get on the throttle, you can hear the car coming from a mile away.
Before we can get it on the road we need to:
Mount the Front windshield
Mount the Rearview Mirror
Spray paint over some raw metal ( we left the car our for one evening and it surface rusted pretty bad)
The floor pan also rattles alot at high RPMs. Any tips to decrease that would be very much appreciated.
Bad_chopper
Bad_chopper is offline
PostPosted: Sun Apr 27, 2014 12:03 pm    Post subject: Reply with quote
Cover the floorpan in a dynamt type material, I think someone makes a spray able type also.
my build page http://www.thesamba.com/vw/forum/viewtopic.php?t=536267
BajaRag
BajaRag is offline
PostPosted: Sun Apr 27, 2014 12:27 pm    Post subject: Reply with quote
Alright ill look into that, thanks chopper
BajaRag
BajaRag is offline
PostPosted: Wed Apr 30, 2014 4:32 pm    Post subject: Reply with quote
I have a few more pictures of its first journey, but they won't load onto my computer. The only one that loads is this one:
It was awesome to finally get to drive the car! We need to get a different transmission though. Ours has a very short 2nd and 3rd gear, so the car is in 4th running around town.
We got the Speedometer working, and are about to figure out the tachometer. The car has already seen some dirt, and 90 MPH speeds. Soon it will see the school's parking lot.
We Dynamated all of the aluminium panels that were in the front of the car so now the rattling noise is tolerable... After our first trip in the car both of our ears felt like we had just left a rock concert because the rattling was so bad.
I don't think we are planning on painting the body any time soon, but we are going to need to paint all of the raw metal to prevent surface rust.
HERC
HERC is offline
PostPosted: Thu May 01, 2014 6:51 am    Post subject: Reply with quote
myaswell just lay down some high build primer for the time being
Bitchin pic dude
Herc
Island Bumpkin
Island Bumpkin is offline
PostPosted: Thu May 01, 2014 12:53 pm    Post subject: Reply with quote
Sure didn't waste any time getting it sideways!
Vehicles:
1971 Baja Bug, 1600dp, summer/winter/summer project
Follow my progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=556996
1988 F250 SC/LB 7.3 IDI/ZF5/Dana 50 front, Sterling 10.25 rear. 4" lift -Daily-
1976 F250 Reg cab/LB Stock 300/NP435/NP205 -Long Term Project-
Axitech wrote:
My rail is basically my "I can't take civilized life anymore this month, so I'm going camping" vehicle
BajaRag
BajaRag is offline
PostPosted: Sat May 03, 2014 4:01 pm    Post subject: Reply with quote
Yeah, we just wanted to check and make sure that the 15 months of work was worth it. Wink
I most definitely think it was worth it.
Stingray250
Stingray250 is offline
PostPosted: Sat May 03, 2014 4:49 pm    Post subject: Reply with quote
Remember this???
"Although your engine mount seem to be sufficient enough to do the job, you might want to strongly consider taking the point where the mounts meet the frame rail and replace that part of the tube with a larger tube size that will accept some sort of poly bushing"
"With all those solid mount points I can guarantee the vibration you are going to experience "in car" is going to drive you out of yer skin!!! I have poly trans mounts as well as poly mounts on the engine and I still have a vibration that is annoying as heck"
Just sayin!!!
Glad to see it finally moving...
BajaRag
BajaRag is offline
PostPosted: Sat May 03, 2014 6:39 pm    Post subject: Reply with quote
Yea, I was 90% sure you were going to come back on here and give us an "I told ya so"
Since that experience we have dynamated most of the car and it has quieted down to a sufficient level. Tomorrow we are going to dynamat all of the plates around the rear bench seats.
Also, our fuel pump is incredibly noisy. It seems louder than the motor. Any tips on mounting it differently?
WrRider
WrRider is offline
PostPosted: Sun May 04, 2014 12:28 am    Post subject: Reply with quote
How do you like the EPS? I guess you would have to turn it off to know the difference
My build page
http://www.thesamba.com/vw/forum/viewtopic.php?t=508856&highlight=wrrider
1fastbigguy
1fastbigguy is offline
PostPosted: Sun May 04, 2014 8:14 am    Post subject: Reply with quote
WrRider,
We have put about 60 or so miles on the car (would be more but we are dealing with a fuel cell issue) and the EPS works very well. We wired it on a toggle so if desired it could be turned off. After some short around town test drives we headed up Hwy 33 above Ojai to see how the car handled the twisty stuff...
The steering with EPS/on has a lite, firm, positive feel and at varied speeds down long straits the car tracked perfectly and didn't wander. As I became more comfortable and trusting in the car I picked up the pace in the turns and once again the steering felt precise and very predictable. In the dirt the car handles like a dream, it feels like you could drive back roads all day without any fatigue. Looking forward to getting it out in the rough!
During part of the road test I turned the EPS/off and instantly felt the size and weight of the 33's at that instant the added cost, time to research and install the EPS was WORTH IT!!! More to come...
Cheers!
59 Ragtop
61 Ragtop Baja
69 Squareback
@Dustydrone
#Ohibaja
Our Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=545394
WrRider
WrRider is offline
PostPosted: Sun May 04, 2014 10:21 pm    Post subject: Reply with quote
That's good to hear. I have my unit already I hope they last.
I Hope you guys will be able to get a video up some time it makes me want to finish mine so much more.
My build page
BajaRag
BajaRag is offline
PostPosted: Mon May 05, 2014 6:42 pm    Post subject: Reply with quote
What exactly do you want a video of? I only have one short clip of us running it, But I will post it on youtube.
The link is: https://www.youtube.com/watch?v=p98hmi9cPdI
If you wanted something else let me know and i'll see if i can make that happen.
Hondub
Hondub is offline
PostPosted: Mon May 05, 2014 7:47 pm    Post subject: Reply with quote
Sounds good! Awesome to see you driving it. I'm sure that was a great feeling to drive it for the first time,
My Honda powered Class 5 car build.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6599511#6599511
WrRider
WrRider is offline
PostPosted: Mon May 05, 2014 8:05 pm    Post subject: Reply with quote
That's awsome I want to run mine so bad!
My build page
Team T&A
Team T&A is offline
PostPosted: Thu May 08, 2014 9:29 pm    Post subject: Reply with quote
Wow, VERY nice car and build!!!!!!! I was wondering if she is running and staying cool with the radiator behind the eng? And do you have a fan pushing or pulling air thru it?
BajaRag
BajaRag is offline
PostPosted: Fri May 09, 2014 4:34 pm    Post subject: Reply with quote
Yea it stays cool while we run it. The fan has only ever kicked on once and that was after we were running it hard for about an hour. I'm 90% sure the fan pulls air through the radiator. The placement of the radiator is working fine so far.
BajaRag
BajaRag is offline
PostPosted: Thu May 15, 2014 9:52 am    Post subject: Reply with quote
We are at a bit of a rough point right now- The fuel tank that we have keeps splitting at the weld so we're going to need to do something about that. It happened for the second time yesterday so the car is in the garage taken apart... again.
On another note, It would be awesome if some of you guys could help me get a better grade in Government. I have a B right now and the teacher offered us a grade bump if we asked people about their political background. Please Private Message me your answers to all of the questions if you want to help me by participate in the survey. (you must be at least 55 years old to participate)
Name:
Years residing in your current state:
Where were you born and briefly describe your young life (demographics, family, etc):
How far did you go in school? If applicable, what was your field of study?
What are some of your earliest political memories?
Looking back on your life, what events, people, moments, etc have been most influential on your view of the world today?
Has your view of the world, socially, politically, economically, etc, shifted significantly/somewhat as you have aged? If you don't mind, could you share a few examples?
Thinking about your life and your political participation, locally, at the state level, and nationally, are there any issues, politicians, initiatives, propositions, etc that you wish you had supported? Or had not Supported? If you are comfortable with sharing, would you tell me about a few?
How would you describe the American Government in general? That is, what is your opinion of the American system of government?
Who have been your three favorite presidents within your lifetime? why? if you would prefer, you can answer the same question with favorite politicians.
Who have been your three least favorite presidents within your lifetime? why? if you would prefer, you can answer the same question with favorite politicians.
What advice do you have for young people like me both in general and in regards to being an active political person?
Was registering for voting difficult when you registered?
How old were you when you registered to vote?
What was the first election that you voted in?
Thank you so much for helping me out.
Last weekend we went to a local off-road thing, there was an articulation ramp there and dad drove the baja up it.
Spaceman7Spiff
Spaceman7Spiff is offline
PostPosted: Thu May 15, 2014 12:55 pm    Post subject: Reply with quote
Good lord. This car gets me all hot and bothered. I'd love to see more of it in action. Well done!
69 Baja Bug- 1914cc. Mid-travel suspension.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=547916
Page 12 of 26
