Touch Nicks Thing Samba Member
Joined: May 21, 2003 Posts: 2029 Location: Alexandria, VA
Posted: Fri Apr 04, 2014 3:51 am Post subject: |
Paul, please let me know where I can buy a sweater like yours! |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Fri Apr 04, 2014 5:13 am Post subject: |
Touch Nicks Thing wrote: |
BillCosbySweaters.com _________________ Paulie
63 Standard OG paint |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sat Apr 05, 2014 8:38 pm Post subject: |
Jerry wrote: |
Paul & I went over the bus last Saturday & decided to get the frontend support repaired & fitit is reflected Ied. Paul, with his attention to detail, noticed the indentions on the early support were supposed to be flat, so he got those sorted out.
The early floor quarter did not have the tabs around the clutch pedal hole either, (we addressed that also)
We drove to the garage around 6 or so, & what seemed like an hour later we were leaving around 5.
What a great day but time flies when you're having fun!
Here's a few pics...
Paul also looked at all the places that was down to og westfalia paint on the bus & made a decision on the paint scheme.
I love working on this old bus! |
Jerry, I had a great time working in your shadow. I really appreciate the passion have for these old buses, It shows in your work.
Nick, if I told you, I would have to k!!!! You..its cool isn't it? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Jerry Samba Member
Posted: Mon Apr 07, 2014 6:10 pm Post subject: |
The metal on the "v" of the nose is beat up pretty bad.
It's gonna take some doing to get it close for sure.
Every cavity will have 2 coats of epoxy primer that closes up.
_________________ Looking for SO34 parts.
thevwcompound *instagram* |
Stocknazi Samba Member
Posted: Tue Apr 15, 2014 4:05 pm Post subject: |
zuggbug wrote: |
Long-roofs wrote: |
Here is a hatch I have, only numbers on it are 488. Looks like the same cream over-spray.
Do you know what the original color is on the exterior of the hatch? |
Here are a couple pics of my hatch.
Are the screws used on the wood panel the same as the front door screws w/o the washers?
The po decided it was a good idea to replace the screws with pop-rivits.
Anyone have an idea how to remove these rivits w/o leaving part of the rivit on the inside of the hatch?
_________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Tue Apr 15, 2014 6:04 pm Post subject: |
Doug, thanks for sharing pics of your hatch - I see the PG paint - just another indicator that the sub-hatch on my bus was not DB.
I cannot help you with the rivets, I would hate to drill them out and then have the backs of them rattling in the hatch.
here are pics of the front door panel screws and the sub-hatch screws. As you can see they are a lot small on the hatch as well as brass in color. the same material as the long and cargo door panels.
58 15 window
56 westy |
Posted: Thu Apr 17, 2014 5:41 pm Post subject: |
Here are some pics of when I was taking the interior out
Front Bench removed
Aluminum L bracket that mounts to the center leg of bench
Floor under front bench
Bulkhead removed. MOLD
58 15 window
56 westy |
vw7266 Samba Member
Joined: April 28, 2004 Posts: 3038 Location: the point, ohio
Posted: Thu Apr 17, 2014 8:59 pm Post subject: |
yuck! |
Posted: Sun May 18, 2014 7:24 pm Post subject: |
Is it my imagination, or do I see the curtains snapped together in the center? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
Posted: Mon May 19, 2014 2:58 am Post subject: |
It sure looks like the front two are snapped to the post and the ones further back are snapped to each other. Do they correspond to those little round marks in this image?: _________________ Jack Stenner
1959 Mango Westfalia SO-23
1953 Porsche 356 Coupe
IG:j.stenner |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Mon May 19, 2014 5:51 am Post subject: |
From camping in mine this weekend I can tell you that having the two side curtains snap to each other would be a huge benefit, otherwise they like to stay scrunched up from the being in the curtain straps. Not sure on how this might be different on buses with the long curtain rod, presume it would still be beneficial. Also without a bungee like so23 and later curtains had, they hang out away from the window a bit. |
aah57 Samba Member
Joined: October 23, 2003 Posts: 433 Location: Roswell, Ga
Posted: Mon May 19, 2014 7:15 pm Post subject: |
look snapped to me. _________________ Looking for white cabinets for a '61 camper
Need westy parts so-34 and so-22! |
Jerry Samba Member
Posted: Tue May 20, 2014 5:57 pm Post subject: |
Posted: Tue May 20, 2014 6:45 pm Post subject: |
Lower valance looks nice.
Any fitment issues with the funky green? _________________ WANTED:
Thomas Jefferson |
Jerry Samba Member
Posted: Tue May 20, 2014 6:59 pm Post subject: |
StockNazi wrote: |
Any fitment issues with the funky green? |
Thanks Stocknazi, the best answer I can give you is you always have fitment issues. Sometimes, for whatever reason, panels fit a little better than others. The green metal & what little AC metal I've used proves to me that both manufacturers actually want the panel to be close for the customer. WW metal is horrible, even their rockers. The black panels are even worse.
This nose will turn out as good as the 21 did if not better. _________________ Looking for SO34 parts.
Posted: Wed Jun 04, 2014 6:35 am Post subject: |
I have been busy working on the bus and not posting in the thread. I am sure I am like most and would rather work on the bus than post in the thread.
Here are some pics of the tent for my bus. I am in the process of getting the fabric reproduced.
I am in desperate need of 4 tent poles. I have 4 of the 8.
here is what I have
58 15 window
56 westy |
Cuņado Wear Samba Member
Joined: December 10, 2006 Posts: 1142 Location: The "O"
Posted: Wed Jun 04, 2014 10:27 am Post subject: |
Paul,
any updates on bus? bodywork wise? _________________
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe |
type47fan1 Samba Member
Joined: December 03, 2011 Posts: 828 Location: McDonough GA
Jerry Samba Member
Posted: Wed Jun 04, 2014 6:28 pm Post subject: |
Cuņado Wear wrote: |
Paul,
any updates on bus? bodywork wise? |
The ice cream bus is going to be finished Saturday... Monday, the 56 will go on the rotisserie.
Sorry for slacking, I'll be WFO Before you know it. _________________ Looking for SO34 parts.
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Wed Jun 04, 2014 9:25 pm Post subject: |
zuggbug wrote: |
here is what I have
I'm unable to sleep since I'm heading to OCTO in the morning and am like a kid on Christmas Eve.
So...I looked through the interwebs for tent canvas to match your tent.
Bad news is that nobody seems to have your style fabric.
Best I could find is this:
http://www.housefabric.com/Chico-Wine-Outdoor-P5229C97.aspx
I'll keep looking. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
