zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Thu Jun 05, 2014 7:37 am Post subject: |
John, thanks for looking.
I so wish i was heading out west with you guys - I had plans on going and was trying to get the best price on airfare, but ended up waiting too long. I was at 450 round trip last thursday, I checked friday....750 then yesterday...931...
maybe next year.
I know you guys will have a blast. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Thu Jun 19, 2014 5:26 pm Post subject: |
a few more pics when I carefully removed the interior
58 15 window
56 westy |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Thu Jun 19, 2014 8:33 pm Post subject: |
Didn't look back all your photos, but did they overlap weld an outer long rocker on the bus? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Fri Jun 20, 2014 4:11 am Post subject: |
j.pickens wrote: |
Didn't look back all your photos, but did they overlap weld an outer long rocker on the bus? |
John , the previous owner had the bus "restored" about 8 years ago and they just beat in themetal and lapped it with new metal, tacked it and smoothed it with filler.. When I purchased the bus i was not aware of the crapy work. It was not until I started taking the interior out that I noticed the spot welds. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Clara Samba Member
Posted: Sun Jun 22, 2014 7:00 am Post subject: |
zuggbug wrote: |
My Jan 56 camper has the same wood bracing screwed into the bus.
It gives the long panel some support. They didn't use the J channel till later. The microbuses have metal tabs welded in to keep the bottom edge of the interior panels from flopping towards the metal wall in between the uprights.
When we took it apart I marked where each piece went. There was more under the panel behind the cargo doors.
The corner panel looks pristine! |
Braukuche Samba Member
Posted: Sun Jun 22, 2014 8:02 am Post subject: |
Wow, haven't followed this thread on over a year, just spent part of a nice Sunday morning checking it out. Super cool bus Paul. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Tue Jun 24, 2014 7:02 am Post subject: |
Very nice, I just learned something new about Westys again. I didnt realize that they installed those attachment blocks/spacers along the floor and over the wheelwells for the panels to have a nice attachment point. |
Posted: Mon Jun 30, 2014 5:30 pm Post subject: |
Thank you Dan and Bill.
Decided to make all new blockimg. Also made an extra set for a future pattern. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Tue Jul 01, 2014 5:42 am Post subject: |
I carefully removed the rear rubber mat and this material was under it. Not sure what kind of material it is. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Tue Jul 01, 2014 7:28 am Post subject: |
Looks like burlap. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Jul 01, 2014 7:30 am Post subject: |
does it smell like coffee beans? _________________ regards
Uli
Stocknazi Samba Member
Posted: Tue Jul 01, 2014 7:54 am Post subject: |
zuggbug wrote: |
I carefully removed the rear rubber mat and this material was under it. Not sure what kind of material it is. |
I believe that is burlap or some other similar material like someone already suggested.
It's og and helps hold water and rots the rear deck on 58 and earlier westys. Why they did not just use the rubber mat is beyond me. It's not like you need the extra cushion b/c your not sleeping in that area. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue Jul 01, 2014 9:47 am Post subject: |
StockNazi wrote: |
zuggbug wrote: |
I carefully removed the rear rubber mat and this material was under it. Not sure what kind of material it is. :?: |
It's og and helps hold water and rots the rear deck on 58 and earlier westys. Why they did not just use the rubber mat is beyond me. It's not like you need the extra cushion b/c your not sleeping in that area. |
Sound deadening?
I thought it was felt. |
Posted: Tue Jul 01, 2014 1:38 pm Post subject: |
I cut strips of 1/8" adhesive foam foil faced duct insulation to fill the gaps below my rear deck hardboard panel from Clara.
This stuff:
http://www.homedepot.com/p/Frost-King-E-O-12-in-x-.../100028603
Levels the deck really nicely. Here is the end result:
Might work for your application as well. _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Thu Jul 03, 2014 6:01 am Post subject: |
I think Greg is right, it appears to be woven felt. Fortunately the majority of mine is in good shape. I will still need to try and source some for a small repair.
John, I really like the material u used. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Jerry Samba Member
Posted: Sun Jul 06, 2014 6:38 pm Post subject: |
The structurals are installed on the long rocker & I'm fitting panels
_________________ Looking for SO34 parts.
thevwcompound *instagram* |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Sun Jul 06, 2014 7:24 pm Post subject: |
Why was that hole hacked into the sidewall? PO-hack? I bet that made the engine annoyingly louder. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Mon Jul 07, 2014 5:38 am Post subject: |
Maybe something to do with the fridge? Looks pretty rough though. |
Posted: Mon Jul 07, 2014 7:28 am Post subject: |
PO hack - I have not idea why
Jerry you are doing a great job on the bus, I am stocked. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
jjjjack Samba Member
Joined: August 08, 2005 Posts: 1013 Location: Gainesville, FL
