SamT Samba Member
Joined: April 17, 2009 Posts: 1761 Location: Rule, Tx
Posted: Mon Mar 11, 2013 8:19 pm Post subject: |
I'm going to my parents for spring break (wife is a teacher) I need to scavenge my donor cars for a gas tank, or atleast the sender, tail lights, maybe a steering colmn thats nicer, blinker relays and other electric crap I need. I have a 66Ghia that has a cherry balljoint beam on it I think I will grab, It has 5 lug hubs on it too so they will match the rims I bought. Don't worry, the ghia has terminal cancer and no title.
[/list] |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Tue Mar 12, 2013 5:04 am Post subject: |
Spring break....those were the days....
I'm taking that week off too so I can watch my kids and maybe work some on the buggy, between crisis. The Ghia should have disk brakes, nice upgrade. Donor cars, plural, that will help a lot too. Sounds like a fun week ahead for both of us. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
SamT Samba Member
Posted: Tue Apr 02, 2013 3:11 pm Post subject: |
well got my donor parts, ghia gas tank with mechanical sender and gauge, Balljoint beam with 5 lug hubs. (I ordered new clearance ball joints, going to cut and turn the beam)
IRS trailing, short sway-away axles and spring plates (use late swing axle torsons) .
My wife almost has the shell sanded down and has a paint color picked out at the local auto parts store.
I was mocking up the ride height and fender clearance, The 2x4 between the shell and chassis is about where it will site with my bodylift I'm incorporating into the chassis. It will sit a touch higher after I cut and turn the front beam (and redo shock towers) and notch the rear so I can take mostly full advantage of my bus CV joints on the downward stroke since I will have to leave up travel stock due to the big tires. I'm not really looking for huge travel over bumps and stuff, just offroad capabilitys and some street manners. I cant decide weather or not to cut the swaybar off.
Hogzilla Samba Member
Joined: May 26, 2013 Posts: 1 Location: The Great Corn Desert
Posted: Sun May 26, 2013 4:06 pm Post subject: |
SamT wrote: |
Can anyone identify the body maker for this one? It looks just like the one we had when I was a kid. |
SamT Samba Member
Posted: Wed Jan 01, 2014 4:23 pm Post subject: |
Well guys im back to work on this car. I have nailed down my goals and purpose. I did quite a bit today. Pics to come.
Purpose: all terrain vehicle, something you can jump in and drive a few hours, but if you see a river you wanna ride. Just pull off and go. Will also be used to chase pigs hunting. Kinda like a RZR and kinda like a jeep hybrid.
Goals: safely drive 70mph, ground clearance for offroading, suspension good enough to handle small bumps at speed (like chasing pigs through a field or grass), reliable enough for a road trip.
Basically i want it all! Im not going to spend a ton of money, but i don't think i need to. I have alot of the parts bought.
I build the floor of the chassis from new metal left over from old projects. |
SamT Samba Member
Posted: Wed Jan 01, 2014 4:42 pm Post subject: |
I used the pan to build my tube chassis on. This way i get and extra couple inches of ground clearance when i chop the pan off.
That was a pita. Hope whoever cut it down the first time did good keeping it straight.
I used some pretty heavy tube 1.5x2.5" its good thick wall. Should be a good ridgid base and give good side impact protection. I laid a piece of 1.5 inch .125 wall tube down the center of the chassis. I was surprised it felt lighter than the factory pan. |
SamT Samba Member
Posted: Wed Jan 01, 2014 5:28 pm Post subject: |
Here is where im at. Still need to add some beam supports and work on the bottom side. |
SamT Samba Member
Posted: Wed Jan 01, 2014 5:32 pm Post subject: |
I think i can fit a Atv winch up front below the gas tank. Do yall think a 2500lb atv winch is enough? |
jspbtown Samba Member
Posted: Wed Jan 01, 2014 6:02 pm Post subject: |
How are you gonna run your shift linkage? |
SamT Samba Member
Posted: Wed Jan 01, 2014 6:19 pm Post subject: |
Im using a bus trans, it would be above the tunnel. Im running a super shifter also. |
Posted: Thu Jan 02, 2014 6:39 am Post subject: |
I'm using a $50 2000# HF winch and it seems to have plenty of pulling power, geared low so it's also slow. Comes with a remote control key fob. I'll try to post a picture later. _________________ Gary
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Thu Jan 02, 2014 9:21 am Post subject: |
Did you leave the VIN# unmolested????
Without that it might be difficult to get it registered unless going for custom built. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
SamT Samba Member
Posted: Thu Jan 02, 2014 12:21 pm Post subject: |
Yup, thats why i left that ugly little piece of the tunnel in place. Im in kansas, so no inspection or anything since the title is kansas. Its kinda wierd though, title just says A 71 "Volk" but the VIN matches up. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Thu Jan 02, 2014 2:08 pm Post subject: |
- is there going to be additional chassis structure on the side rails or center tunnel? Current chassis pics look like a motorized & suspensioned extension ladder...
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Posted: Thu Jan 02, 2014 5:20 pm Post subject: |
This originally came in "cool green camoflage" but I kept 'not seeing it' on my workbench so I shot it with "blend in black" and made a bracket to attach it to the beam with the frame head bolt holes. (custom frame). I used it to tug the buggy up on a trailer, slow but no strain. I replaced the cable that came with it with a 20'X2" ratchet strap that I also bought at HF for $8 and tossed the ratchet and original cable in a drawer. The strap is a lot easier to work with than the cable. I wired it through a DPDT switch on the dash but it also came with a remote control key fob which is pretty cool too. I can use either as needed. I'm pretty happy with the results. _________________ Gary
SamT Samba Member
Posted: Thu Jan 02, 2014 5:33 pm Post subject: |
didget69 wrote: |
bryan |
Defintely going to be a roll cage, but as is it is more rigid than a stock Vw pan. |
Posted: Thu Jan 02, 2014 7:20 pm Post subject: |
I built a similar chassis and liked the idea of a little more side impact protection and the serious stiffness the second tier of square tubing provides. The buggy body snugs in nicely. _________________ Gary
SamT Samba Member
Posted: Thu Jan 02, 2014 9:54 pm Post subject: |
gr8cobbler wrote: |
I built a similar chassis and liked the idea of a little more side impact protection and the serious stiffness the second tier of square tubing provides. The buggy body snugs in nicely. |
So does you body sit inside of the chassis? How do you attach the body? |
Posted: Thu Jan 02, 2014 10:40 pm Post subject: |
SamT wrote: |
didget69 wrote: |
bryan |
Your current design as shown will suffer from torsional twist with the tunnel removed. This is why I was curious to know if you planned to build your chassis similar to that of gr8cobbler.
